Speakers Recommendation for 500-600€ aprox
MerlynX
Hi, I'm new to this world. I want to buy a pair of €500-€600 monitor-type speakers. I'm going to listen to them for watching movies and, above all, for all kinds of music, from Dire Straits to dance music. I've seen the Dali Oberon 3, Elac Debut, Klipsch rp-600mk2, and Triangle Borea br03, and the more I look, the more doubtful I have, since they all have "flaws." Which ones do you recommend? Thanks.
Hi @MerlynX! Welcome to ASR.
Should the speakers be passive, so powered by an external Amp, or would you consider active speakers with built-in Amps as well?
Hi I'm thinking of buying a new Yamaha AS501 or second hand Cambridge CXA61 type amplifier.
It's also important to indicate which country you're in. Some recommendations aren't available everywhere.
In Germany the Elac DBR62 are almost always on sale and some retailers ship to Spain.
394€/pair, shipping via DHL to Spain is listed as 19,90€:
Review of the Elac DBR62:
Muchas gracias por sus respuestas. He estado considerando los Elac DBR62, que no conocía. Algunas reseñas, como las de WhathFi, dicen que no son dinámicos; son altavoces que no dan ganas de bailar. Me pregunto si eso afectará la música dance actual. ¿Qué opinan? Estos serán mis primeros altavoces y no tengo forma de probarlos antes de comprarlos. Tampoco quiero montar una discoteca en casa; mi salón tiene 20 metros cuadrados y tengo vecinos.
If you can stretch to 900 euros.
Hello, welcome to ASR; others have also welcomed you. We area welcoming community.
We suggest to post in English. We have able moderators who you can consult in dual language posting.
Your listening room, listening distance, and geometry strongly influences choice of speakers. After, you have choices in room measurements and room EQ in your system.
ASR has a library of speaker measurements. You can go to Review Index, select speakers, sort by preference score, go to your price and read reviews.
We have many discussions of measurement microphones like UMIK, free measurement software like Room EQ Wizard, and room measurement. Some ASR participants discuss their rooms and measurements.
