The question is which sub/price point?
A good point.
From what I can see, the JBL A 130 and the R3 are outliers as under rated in a modern enthusiasts system using the current ranking systems. Any method used to rank speakers will give some favour to one speaker or another, and the current ones fall short on these for my criteria. The distortion for the R3 is very low, whereas the lacking bottom end that lowers its score is not a factor if a sub is used. Of course this would reduce distortion further also, so is a win-win.
Given the vertical off axis advantage the coaxial design has, this design would likely top the chart under different weighting, yet is comparatively cheap against many of the top contenders.
I have the R3 and the ability to apply PEQ so this would be an interesting comparison if I normalized the bass below 80Hz. Given the price of the JBL 130 I might have to test this out sometime
I would personally cross over at circa 150hz and keep the sub close to the speakers to compensate (stereo subs even better!). You can also play with a Harman curve that raises the bass a couple of db at the bottom if it suits you. Bass accounts for 30% of preference in blind studies if I remember right.
