HeadDoc12
Ever since learning about the Tylko shelving system with built-in custom speakers that fit perfectly inside all four sides of a rectangular shelf, I have started a thought experiment of my own: how can I have a system where the only component that needs to be on top of the top shelf is the turntable? Obviously, there are plenty of electronics (CD players, streaming amps, separates) that fit inside, say, an IKEA Kallax cube shelf, so that is the easy part. The question is, aside from speakers specifically designed to fit in these shelves (Devore Micr/O, Eversolo SE100, probably others), what are the sonic pros and cons of having speakers surrounded by all sides (except the front and back, of course) by shelf walls? Does a little bit of space make the situation worse or better, as opposed to a tight fit? Would this be especially problematic for cardioid speakers like the Palmer Orbit 11? Or does that not matter? Thanks!
