Speakers for BACCH
Cardoid speakers have a fairly wide directivity. They would require acoustic treatment to use with Bacch for sure.
It's only large horn speakers and open planars that can achieve a very narrow dispersion. I'm working now on a horn design with broadband 70x50° directivity.
So your saying that ultimately then that the Neumann 120 ii I've been experimenting with are not narrow enough? would you say?
The horizontal directivity of the Neumann 120 ii various with frequency, thus it doesn't offer constant directivity. Above 2 kHz it's 100° which isn't narrow enough to avoid audible side wall reflections from both side walls. Below 2 kHz they become gradually wider and already at 1 kHz the direcitvity is approximately 200°, which is very wide. This means there's a major difference in the reflected energy. In order to achieve a correct tonality, such a speaker requires treatment that is effective to the Schroeder frequency. And this would also be important in regards to Baach.
Vertically, the speaker is a bit narrower with 80-100° directivity in higher frequencies and wider below. Because of the crossover, we see lobing/narrowing here. Vertical treatment is important as well with this speaker. Preferably use something that is effective to the Schroeder frequency or at least highly effective to 500 Hz.
Lol no wonders it wasn't working, thank you for explaining in plenty of detail!!
