Speakers for an untreated room with good transient response for mixing?
I tried room correction for my Kali's both in the studio and in my house. EQ doesn't change it. The Neumanns in the Studio do not show this problem. my Kali's do.
I don't really know how to help you since I grew up with chipboard speakers and the tweeter is of the same construction as the woofers.LOL
And it was pretty good sound.
That is my center channel behind TV.
The bottleneck in that time was magnetic tapes(Cassette) that has terrible noise,houling....
Thanks Good for digital audio....
Maybe some good ribbon tweater like RAAL croosed,if the 2.5-5khz region you are looking for.The ribbon dijafragma itself is made out of 8 microns thick aluminum foil, and weight several hundred times less than standard dome tweater?
That should be fast enough?
They are pretty poor in vertical dispertion but that is plus in this case.
Anyway best thing for me was two big bass traps in corners and one small in corner in celling that was problematic right above my head, I swear I could hear sometimes bass coming from there crazy how are mind works, and I can't localized woofer till 120hz crossover.
RT 60 is pretty good now.
Vertical lobing is definitely of less importance than horizontal errors. The KH120 II is fine.
Realistically, I would just work on headphones if your room is that screwy.
not with a desk in the proximity of the speakers in the equation. vertical lobing will be of big consequence unless you are willing to a put a big ol absorption panel on your desktop which i have seen work to great effect.
