Blumlein 88
- Joined
- Feb 23, 2016
- Messages
- 23,571
- Likes
- 44,651
I've been meaning to take my lsr 305s outside for some measures.
Will I guess the reasoning will be to try and create a consistent environment or set of parameters so our results are relevant to all across the board rather then just being a resource purely for ourselves as individuals.I actually find it relevant to measure speakers in the very environment I'm listeing to them. That way you see which figures actually matter and whcih don't.
I see no reason to do that for home speakers of all sizes.
You don't think measurements made at home with REW are precise enough for the speakers to be compared distortion wise?![]()
Is there a way you could average multiple sweeps in REW? I was thinking there is.
Yeah I guess I was just thinking about measuring speakers as speakers rather than measuring speakers plus room.By all means!
One thing I have learned so far is if I measure frequency response of my speakers while moving mic relative to my head at my LP left and right for 0.5m, up and down for 20cm and forward and backward for 30cm I get very consistent results. When I did speakers response correction based on those measurements I can measure again and see that reponse has flattened, and I can also hear it sounds better. If I repeat that measurements few days after I get the same results, which is how it needs to be. I believe everybody can do the same and have similar results.
I have yet to see if I can make consistent distortion measurement in that same manner. Althoug, ot be honest, that is less important than frequency response as you can't correct distortion. But it can still be of great help when choosing new speakers.![]()
All measuring fun is encouraged here though as long as it doesn't involve me lol
That is how it works when you measure frequency response with sweeps.
Yes, but you don't get many (or all) of the additional calculations available to a single sweep measurement (though that "single" measurement can have multiple sweeps). No distortion or impulse, etc., just averaged SPL.
That's true, you can't get impulse that way, but you do get very reliable frequency response measurement.
Single-point listening gives me a meaningful picture.
