Hello Folks,
Please suggest a best match speaker for the following Vincent setup -- > Eversolo A8 -> Vincent SA-32 Pre -> SP-332 Power amp
I usually like melodious musics.
Thanks,
Rkn
a minimum 3 way floor standing speaker would be fine for me, my room size is 15 x 25 foot, i believe it is a medium size, I tried to listen a speaker called sonus faber Sonetto V G2, I like the sound, but it is above my budget, max budget is 3500$In my experience speaker size is determined by the room size and the volume I usually listen to.
Speaker position and distance to the listener matters too.
Does it need to be bookshelf, floorstander or doesn't it matter?
What do you have now and what makes that you want to change?
That isn’t really a very good distribution of money. You already spent like 5k on electronics, but rather should reserve the most budget where is actually matters: for speakers.max budget is 3500$
thank you appreciate your support.That isn’t really a very good distribution of money. You already spent like 5k on electronics, but rather should reserve the most budget where is actually matters: for speakers.
As to speakers options within your budget. Try some KEF. Q11 will easily fit your budget. R5 as well. Mofi Point source 888 perhaps (price seems te depend highly on location)?
Here is a collection of great speakers within your budget:
A collection of loudspeakers measurements
www.spinorama.org
Hang about! I would always recommend M&S underpants!Facts and figures about speakers may be a useful starting point, but in the end you have to hear them with you own ears.
Even better if you can hear them in your own room as the room/furnishings make a big difference.
This is one reason why many of us don't like to recommend any. Same for headphones, underpants, food etc.
philharmonicaudio.com
I always recommend Calvin Klein.Hang about! I would always recommend M&S underpants!![]()
At least until the police arrive, anyway.One's 'package' may determine suitability for underpants, but then my sequined thong will get me access to the ladies loos....![]()
They won't in the UK.... They only turn up if you've hurt someone's feelings online, usually by saying something true !At least until the police arrive, anyway.
www.audiosciencereview.com
Thank you.I see Philharmonic Audio speakers in your future. They punch WAY above their price tag and are extremely well reviewed. Generous sold out but you can get on a waitlist or pre-order and they will give you a good idea when you will receive the speakers upfront.
Philharmonic Audio
Thank you very much.Here, Erin has compiled a list of the floorstanding speakers he has tested and listened to, across various price ranges:
View attachment 547286View attachment 547287
These are within the TS's budget. They seem to be really good:
Monitor Audio Silver 500 7g
Nice measurements today from Soundstage hifi…someone get Amir the 100 7g https://www.soundstagenetwork.com/index.php?option=com_content&view=article&id=2685:nrc-measurements-monitor-audio-silver-500-7g-loudspeakers&catid=77:loudspeaker-measurements&Itemid=153www.audiosciencereview.com
Edit:
I missed checking if your amp handles the recommended speakers, but I’ve done that now. No issues at all with:
Nominal Output Power RMS / 8 Ohm: 2 x 150 Watts
Nominal Output Power RMS / 4 Ohm: 2 x 250 Watts
Vincent: SP-332
www.vincent-tac.de
how about Sonus Faber Lumia V? not listened yet, but I listened Sonetto vThat isn’t really a very good distribution of money. You already spent like 5k on electronics, but rather should reserve the most budget where is actually matters: for speakers.
www.spinorama.org
If you like bright…how about Sonus Faber Lumia V? not listened yet, but I listened Sonetto v
`thank you for sharing this info, even though it was a power amplifier, if that's the case, there seems to be some problem.I had a Vincent SAV P200 and found it really lacking the ability to pull difficult speaker loads, like really - even with its supposedly 6x200W in 8 ohm.
I tried to use it for a LAT500 subwoofer, and found it unable to control cone motion at higher levels, whereas my current amplifiers have no problems in this regard - you could literally see how the cone moved WAY more controlled and did'nt bottom out as easily with a better amplifier - played measurably louder and deeper with a "stronger" amplifier.
Even My old Dali Evidence 870 was a bit to hard on the Vincent, since I found out how more controlled everything became when getting rid of the Vincent.
I do not know if my then amplifier was problematic, if I pushed it too hard or other Vincent models have the same limitations, but I would definitely aim for an easy speaker with anything from this brand - IME.
