These are speakers I’m considering at the moment, along with their local pricing:
- KEF LS50 Meta - 1500 USD
- KEF R3 - 1800 USD
The value propositions. I'm hoping that their relatively smooth directivity means that using Dirac and my SHD's EQ, I will be able to correct most of their imperfections. The LS50 Meta are on this list because I’m planning on offloading a lot of the low-end workload to the subs, and I don’t listen to my speakers at excessively high SPL. Their measurements make it seem to me like they would be quite competitive with the R3 above 100hz - maybe even better, since they have newer tech?
- KEF Reference 1 - 8400 USD
- Genelec 8351B - 8300 USD
These are the moonshot options. I’m willing to consider them if they perform significantly better than the “budget” options.
So, dear hive mind:
- What do you make of my upgrade candidates? Are there any other worthwhile candidates I’ve missed? Budget-wise, $9k USD is the hard limit, and ideally I’d like to spend significantly less than that.
- Are there any other suggestions for improving my listening experience? (Adding more acoustic treatment, different speaker placement, changing listening positions, etc.)
Thank you for you time and for your help!
