I am a bit confused about this so I need some guidance. Most documentation says you need to keep your speakers a certain distance from the wall. However, it doesn't specify whether the distance is measured from the rear of the speaker or the front.
For example, I have the Revel F208 loudspeaker. The speaker is 14 inches deep so when I place it such that the rear of the speaker is 7 inches from the wall, the front baffle is about 21 inches. I thought all measurements had to be from the front baffle given that is from where the drivers radiate. But if that's how it's measured, then speak a distance is a function of speaker depth and the speaker has to be "X inches from the wall" makes no sense.
Genelec recommends positioning of the speaker where the front is between 5 and 60 cm from the wall behind it. 60 cm translates to about 23 inches…given the depth of my speaker, that implies the rear of the speaker should be at most 7 inches from the wall.
For reference, this is a living room with typical living room furniture. I don't have any specialized treatments and the audio chain is Bluseound Node to DSPpeaker Antinode X2 to amplifier.
So, in a nutshell, trying to figure out my speaker position!
Thanks for any help.
