Jiraya369
- Joined
- Sep 2, 2025
- Messages
- 564
- Likes
- 544
Hey guys I got the Adam T5V based on Amir's review and above ~200 hz to my ears it sounds phenomenal. But the bass is really wonky. For some reason it doesn't have much below 100 hz, and 100-200 hz it's quite boosted it feels like, or maybe 100 hz and lower is not there and 100-200 hz is normal and that is making it seem boosted? idk. I did some sine sweeps and below 100 hz i dont hear much but there's still some peaks and stuff and i did some eq to get rid of those. It sounds a lot cleaner but i feel like it's still not the greatest. I don't really know what to do. I was thinking perhaps putting em on the desktop flat was the issue, i have some pucks but decided to prop em up a little with 2 pucks in the front but it still doesnt feel like anything changed. Is the desk causing any issues?
Thinking of getting speaker stands to put behind the desk, will that be good enough or will the desk still be an issue? How far do i even sit from the speakers anyways? And how do i measure the distance between speakers? It's easy to measure the distance from my ears to the tweeter but what would be the point from speaker to speaker? cus they're toed in it's a bit hard to know.
I'm saving up for an RSL Speedwoofer 10e, Wiim Ultra (to manage the bass) and a UMIK-1. If i could just get a good response down to 50 hz it'd be nice. I get a random, really nice peak at ~48 hz but apart from that and a few peaks here and there i don't hear much under 100hz.
Room measurements :
Table : 120 cm wide x 60 cm deep
Height from floor : 29 inches or 75 cm (top of table)
Distance from ear desktop : 0.45-0.55m or 17.5-21 inches
distance from ear stands : 0.9-1.15m or 37-45 inches
Ear height : 46 inches from floor
Room :
Height : 272 cm
Width : 320 cm
Depth : 360 cm
the layout of the room :
^ just a rough idea. i pulled the table to the middle so i can listen from there, i have a bed and a cabinet behind me and to my left is a door so i need some space for it.
Right now I am 0.75m from the speakers. So if i get the stands it'll be around 1-1.5m. If I get to ~1.8m and in the middle of the room or a bit towards the final 3rd of the room, i get some strong bass response around 40-60hz. But still not as nice as i'd like.
EQ i used that sounded a bit nicer :
Preamp: -6 dB
Filter 1: ON HSC Fc 5500 Hz Gain -3 dB Q 1
Filter 2: ON PK Fc 56 Hz Gain 6 dB Q 2.2737
Filter 4: ON PK Fc 46 Hz Gain -8.5 dB Q 6
Filter 5: ON PK Fc 78 Hz Gain -6 dB Q 6
Filter 6: ON PK Fc 111 Hz Gain -7.5 dB Q 6
Filter 7: ON PK Fc 218 Hz Gain -7 dB Q 6
Filter 8: ON LSC Fc 90 Hz Gain 1.5 dB Q 0.9
first filter was based on amir, 2nd one was to get some low end back based on spinorama eq and the rest is just me eq'ing out frequencies based on a sine sweep and the low shelf is to just gain some low end back
Is a subwoofer all I can do or will getting stands and sitting a bit further back fix it? I tried moving the speakers back and forth from the wall, from 15 to 35 cm from the wall and i didnt really feel much changing. Honest to God bro it sounds so nice above 500 hz i cant trust anything underneath it properly. I tried using some random app to see the response on my phone but it doesn't look right at all. Any help will be much appreciated. Thank you.
Room measurements :
Room :
Height : 272 cm
Width : 320 cm
Depth : 360 cm
Preamp: -6 dB
