What can be done, and is it even possible, to reduce low/muted signal speaker hiss?
Related threads (different focus):
Personal History Context
My conclusion is these things point to the noise being related to the noise floor or amplifier gain, and I strongly suspect I have to live with it. Hoping others can suggest alternative solutions to consider.
- https://www.audiosciencereview.com/forum/index.php?threads/powered-speakers-self-noise.41462/
- https://www.audiosciencereview.com/...ible-noise-hiss-in-loudspeaker-and-snr.41696/
- The system is: 5 channel active crossover, unbalanced into 5 2-way speakers.
- I can hear hiss in the speakers when there is no or low signal.
- The noise is not amplified
- The noise can change with ground changes, ie I can make it worse by inducing true 60 Hz ground loop, but I can't make the sound go away
- The room is on the small-mid size so rear speakers only a few feet away, and front speakers 6-8 feet away. Rear speaker noise is more annoying due to less audio content in rears and it being closer to the listener. Can technically hear front if listen hard in silent room.
- separate power line from circuit breaker that only the A/V equipment is connected to
- added additional ground with 8 foot copper bar into ground for the power panel
- ground run from amp chassis to preamp/receiver and also to active crossover case
- equipment connected to the same power strip
- different power strips tried
- amps connected through relay or non-relayed power strip
- amps connected through DC blocker, EMI reduction power strip
- disconnecting everything (power and RCA lines) but amps (with and without extra ground wires to other hardware)
- same/different tweeters directly wired to either amps, or preamp (actually a receiver) output
- different amplifiers
- different active crossovers (DSP and Op-AMP based tried)
