ctrl
This may seem a bit pushy, especially since I said in another post to let things rest, I must admit to being a nerd when it comes to measurements.
Thanks to the normalized measurement diagrams of user MZKM it can be shown that at least in the range of 5kHz to 10kHz a systematic measurement error is present in the current measurements done by Amir.
A systematic measurement error is an error which is also evident in the off-axis measurements of a loudspeaker with almost the same amount and which may be differently pronounced when measuring different loudspeakers, but is systematically present.
Systematic deviations thus produce a shift to one side, they always tend to mean measured values that are always too high or always too low.
Below is an example for normal radiation errors of a loudspeaker. The following measurements show a loudspeaker with wave guide. First the horizontal measurements from 0° to 90° and then the display normalized to 0°.
Caused by the tweeter and wave guide a small dip appears around 6kHz which does not disappear even off-axis and increases for large angles.
In the normalized display the error for small angles has disappeared, so the small dip can be corrected on-axis by equalization.
Around 3kHz there is a widening in the radiation, which is due to interaction between the wave guide and the edges of the speaker cabinet, which means that too much sound energy is emitted into the room in this area.
In the normalized representation this can be seen well. To counteract this effect, the on-axis measurement of the loudspeaker should have a slight dip in this area.
What is the problem with Amir's measurements?
There we have of course the normal radiation errors of the measured loudspeakers - as shown above.
But if there are errors that don't disappear even off-axis and different speakers always show the same errors in a certain frequency range, then we have a problem.
If then other independent measurements do not show this error, the probability is very high that it is a systematic error of the measuring device or calibration error.
Look at the measurements of the Neumann KH80, Kef LS50 and Harbeth30 in the 5kHz to 10kHz range. All measurements show a congruent ripple, which disappears in the normalized display.
KH 80
Harbeth30
LS50
Other independent measurements do not show this ripple. This was already shown in the KH 80 thread, here it will be shown with the LS50 as an example.
Measurements from Princeton Lab and a hifi magazine show no abnormalities, especially in the 8-15kHz range, in contrast to Amir's measurements.
KH 80
Harbeth30
LS50
