There are tons of threads here on ASR, with measurements. Soft feet can be beneficial if you have resonant surfaces, benches, desks where your speakers sits. But you do not need more than e.g. sylomer feet to prevent vibrations through.I would appreciate informed views on speaker isolation feet as I am considering examining this. I have a pair of B & W 802D speakers weighing 80kg each. I currently use them with their factory fitted wheels. Rest of the system is Cary DMS 700 streamer, Music First Baby Ref V2 passive preamp and 2 x Pass Labs XA 60.8 class A monoblocs. Yes, usual speaker cable, Shunyata Venom X and AVID SCT XLR connectors
The floor is Travertine tiles on concrete. I am considering Isoacoustics Gaia 1 Neo feet. I have quite a number of friends and acquaintances who say they have had a really noticeable effect on the soundstage.
Would appreciate informed opinions on the matter
Speakers.So where do you aim this "technology"?
Just get some rubber adhesive feet. You may already have some in a drawer somewhere. Or go get some at the dollar store.Speakers.
As I stated, for "basstands", when placing a speaker on top of a sub.
I replaced the spikes (and screw inserts) in my Rega speakers with some spare feet and inserts from Ikea Besta units and some suitable diameter foam pads. It's much easier to position the speakers now (and re-position after the cleaner has been!).Does the same go for spikes on floor protection disks on a wood floor? Are they of value? Could I just use easier to manage rubber feet?
A very long time ago, back when TVs had CRTs, I had a couple plants sitting on a TV (it was a tiny apartment). My wife decided to water the plants one day and overdid it a bit. The water ended up inside the TV and destroyed it. I would not advise using speakers as plant stands for similar reasons.Possibly slightly off topic, but connected to the issue of loudspeaker cabinet vibrations or their absence. Its often assumed that placing plant pots etc on top of speakers degrades the sound. I have never been able to discern any difference, but I’ve never done a blinded comparison and don’t see how one could (shut you eyes while assistant shuffles plants around?)
The ability to act as glorified plant stands has secured the acquiescence of my partner to the presence of a lot more loudspeakers than I’d otherwise get away with.
