speaker in briefcase
Orly67
France
Hello Guys, i have a project for to build a speaker in my briefcase. Dimensions are 6 cm P x 25 cm H x 36 cm L .how do we calculate the right speakers that will play correctly with these dimensions. Is there any software for that? Thanks so much and sorry for my bad english.
O
Orly67
France
i forget that i have a macbook pro i don't know if there are software for mac
Zek
Which speakers?
What's the purpose of speaker in briefcase?
Is the briefcase sturdy enough for the speakers?
mhardy6647
Or, at the other end of the speakers in luggage spectrum...
Electrovoice Sonocaster. EV "Michigan" MC-8 "fullrange" (twincone) drivers in Samsonite luggage-style enclosures.
High sensitivity and... not bad, actually. "Great for tube amps." :cool:
We now return you to your regularly scheduled thread topic.
paddycrow
Grand Haven, MI
Not sure why you're set on mounting speakers on a brief case. As a rule, briefcases are light and not designed for rigid walls. Once the speakers are mounted, it's not particularly useful for carrying anything. If portability is your goal, I would suggest making an MDF cabinet with handles mounted on top.
That being said, automotive speakers would probably be good candidates. Especially ones designed for mounting into car doors. They should meet your depth requirement and should produce decent sound. They are available in a wide price range depending on your budget.
andreasmaaan
We're going to need a lot more information to help here, I'm afraid :)
  1. How many channels do you want (one/mono or two/stereo would be the options, I presume)?
  2. Are you looking for a single full-range driver (per channel, if more than one channel), or to make a two- or three-way speaker? (My advice would be to make it two-way.)
  3. Where/how do you intend to use it (indoor or outdoor, desired listening level, etc.)?
  4. Does the briefcase need to also hold other things, or will its only function be as a speaker enclosure?
And lastly, why do you want to do this? (Not that it's a bad idea if your goal is aesthetic or similar, but it's just not the optimal way to do things if your goal is sound quality.)
O
Orly67
France
Thank you so much bro. You know some software for calculate the correct dimensions??
O
Orly67
France
am a tattoo artist and often travel with my big briefcase. I just don't like the original sound that was installed on this case. I thought to myself that maybe it was possible to improve it ??
To answer your question I would like a two voice and for use it will always be indoors in convention or in the studio.
Thanks so much bro.
O
Orly67
France
Thanks so much bro.
somebodyelse
With that case construction it's not hard to make a deeper lid which would give you more options, particularly if you want more bass. Maybe take something like the Carmody Isetta and alter the dimensions to suit your case, keeping the volumes the same?
O
Orly67
France
thanks Somebodyelse is good idea but i don't know if is suitable for only 2,36" Deep. What do you think about?
Adam Bernau
Yes, it is possible. Your limit is the size of the lid and its depth, you must be able to close the briefcase, so
you have to tear off the existing sound system and the upholstery and measure.
Let me know when you know the cavity dimensions, preferably in milimeters, and i will try to give you some good advice. Also please write the model and name of the amp device that is there, so we can decide if it should stay or not. :) IS there perhaps also some battery with it? Let´s find out.
