You don't need time domain to check if you have issues with room modes - MMM RTA with pink noise will do. If you choose to do it here is a nice video that explains how it should be done. It's very easy and quick procedure.
It is difficult to find exactly what the Gaia is. Maybe it is a ball in cup type, in which case it may well be good at decoupling horizontally but not vertically.The Townsends are very expensive but in addition, I can't find anyplace that they are for sale on this continent. Even if I was of a mind, I'd have to buy them on a dare. I thought the Gaia design wasn't based on polymers, that it was a tuned spring based system. To be honest, I know little about any of these dedicated devices except what I have read.
I decided to finally get rid of all the various mechanical buzzes and noises in my room. I ran tone at various frequencies between 20Hz and 100 Hz and just followed my ears to the various sources of mechanical noise in the room. This included framed pictures, a loose access panel in the ceiling, and a particularly obnoxious CD rack whose panels vibrated like a drum. One by one I eliminated these resonating objects,by damping them with various dime store rubber bumpers or tying them down. I finally got to the end of the noise but one buzz/vibration remained.
To my surprise I discovered that the speakers themselves (both of them) were emitting sympathetic noise, between 20Hz and 100Hz, the worst of which seemed centered between say 40Hz and 90Hz. Salon 2s weight the better part of 175 pounds and I also have a pair of heavy JL Audio Subs contributing to the energy but it's the speakers themselves that are emitting the noises. The subs are crossed over to the Salons at 40Hz but don't seem to actually be producing spurious noises of their own. They may be contributing energy to the general situation that is causing the Salons to resonate but they are not the audible problem per se. The speakers are on their spikes which then want to penetrate a thick carpet and pad. Unfortunately, the underlying floor is soft and you can sense that it is likely part of the moving system that is creating this problem.
I thought rather than to try to couple the speakers to the floor with their spikes, I might look into isolating (decoupling) them instead. If I tilt either speaker onto two (of the four) spikes, the buzzes are significantly reduced. If I balance it on just one spike, the combination of whatever damping I am physically applying with my hands and the suspension of the whole speaker onto just one spike reduces the vibrations almost to inaudibility.
Sorry for this long winded explanation but perhaps it explains my interest in decoupling the speakers from the floor to the extent possible. So I'm looking into what materials and approach I can use to accomplish this at reasonable cost. Companies like Isoacoustics offer rather expensive solutions that may work but I am hoping that this can be done in a clever (cheaper) fashion if indeed such treatment is the most practical solution.
In sum, your experience with taming mechanically transferred vibrations of this type is welcomed and encouraged. I wasn't the guy who thought that isolating all the components in a system (at great expense) was a practical or necessarily proven thing to do but between the way the floor and my speakers and subs interact, I think I've got I've got a problem I can solve but I'm not sure exactly what to use to do that.
I already dealt with the sympathetic resonances of the offending objects in the room. The remaining resonance is coming from the speaker. Quoting myself from my first paragraph, which you also quoted :The vibrations of objects in various locations in the room are caused by the acoustic sound in the room, not so much from direct mechanical coupling from the speakers.
Being cheap... and practical... for $16 I'd try:
Put a couple of these (or similar) on the carpet under the speakers.
Weight is 56 lbs each.
Try the speaker spiked or soft footered.
https://www.homedepot.com/p/Oldcast...-White-Concrete-Step-Stone-12052330/100427064
If mechanical vibration......................I'm hoping the above is generally in order, but before commencing if desired, you should wait to hear from Frank Dernie ( as he's a bonafide expert on this subject ) or hopefully another mechanical engineer on the forum will pipe in with corrections.
She actually said that!
Worth a peek. See below.
Thank you for that suggestion. I have a marble slab that can act as the base (concrete would be fine but I have the marble) and has been kept in my life for just such apurpose. It is not large enough to make a sandwich for two speakers but could act as a base for both. One problem I think somebody else mentioned is that at some point the Revel's tweeters, which are already pretty elevated, get uncomfortably high. Actually, the whole shooting match could get uncomfortably high given that it requires an inch of deflection from the springs which need to be sandwiched between something (presumably) dense.
My wife suggested that I just tear the floor up and start all over, sister some joists, stuff in some rock wool and go to town. I think she was kidding. At least I hope so because that seems terribly messy. However, I'm not kidding. She actually said that!
^I'm as confident as I can be that it's the floor, not the speakers. I tilted them onto a single spike (always a physical act of courage)while running tone to test the theory. I would have physically lifted them entirely off the floor if I could have but that ain't happening! Trying to reduce the effect of transfer/contact to the floor by putting all the weight on one spike while taking as much weight a I could off of that contact point reduced the vibes to virtual inaudibility. Drop the speaker back onto all four spikes and the harmonic buzz returns. It's to do with the way they interface to the floor and how the floor responds and the energy gets transferred back and forth. Or so I think.
Spikes couple the gear to surfaces in a manner analogous to a sound box.
If the surface has high enough mass and damping, transferred vibrations will be deadened. Suspended wooden floors are probably the worst case for transmission.
Check out sand box isolation on the WWW.
I ran tone at various frequencies between 20Hz and 100 Hz and just followed my ears to the various sources of mechanical noise in the room. This included framed pictures, a loose access panel in the ceiling, and a particularly obnoxious CD rack whose panels vibrated like a drum. One by one I eliminated these resonating objects by damping them........
Those are very good tests that you did. It is unclear to me whether the "harmonic buzz" you hear is a distortion of the sound put out by the drivers due to spurious vibration of the drivers, or whether it is due to some other part of the speaker vibrating. When you hold the speaker, can you feel vibrations through your palms that correlate with what you hear? Is it both speakers? For example, if you unplug each speaker in turn, does the harmonic buzz manifest itself for each? I assume the buzz is something you actually hear and not just a distortion of a pure tone on a measuring graph.
The problem may not necessarily be due to your floor being too elastic and resonating with the speaker. Your floor may be rigid enough, and the problem may manifest itself even with spikes coupling to a more rigid floor.
In spite of the results of your tests that I quoted, is it possible that the speaker is normally rocking back and forth and dancing or hopping on the four spikes due to some internal imbalance and not just due to the normal acoustic pressures of the music on the cabinet walls? Attempting to lift the speaker on a single spike or tilting it back on two spikes may have sufficiently altered the internal imbalance to damp it. Damping using absorbent matter would likely diminish the problem then, but the drivers may still be experiencing spurious vibration. It is highly unlikely that such top-notch (I assume) speakers would have a design flaw or that units would be shipped by the manufacturer with any resonance problems. However, it remains a logical if unlikely possibility that a joint in the cabinet or a driver fastener is sufficiently loose to allow relative motion. Though it is practically impossible that it would happen to both speakers.
Nonetheless, I want to thank everyone who is participating in this discussion and assure that I am hearing everybody's ideas. I will be reporting back on the efficacy of the cheap isolation devices I bought resulting from Kal's link and will entertain everybody else's notions.....including eq!.....with my simple biases intact but my mind open to your ideas.
If it is easy to unscrew the spikes, you could remove the spikes, and place the speaker directly on the carpet. Then the mechanical coupling will be very different - one larger flat surface vs 4 points, and this may pehaps be enough to eliminate the problem.
I realize that the spikes must be very sturdy (hardened steel, etc.) and their (metal?) seating into which they are screwed be very securely embedded into the speakers, but every material has its mechanical limits, be it wood or metal. The play may not be noticeable to the touch, but it may take only a little give to resonate with the woofer's excursions. Kvalsvoll's suggestion would also remove such a play issue.
