I'm rearranging my listening room, and need to make some new speaker cables for my LX521's. Cables will be 10ft long each. Everything with be terminated with Speak-On connectors.
I currently drive both the sub drivers in parallel, so each side needs a total of 4 pairs of speaker wires
Canare 4S11 - 4 x 14AWG -
https://www.redco.com/Canare-4S11.html - $1.59 per foot
Clark Wire SPKR1308 - 8 x 13AWG -
https://www.redco.com/Clark-Wire-SPKR1308-8c-13AWG-Speaker-Cable.html - $3.65 per foot
Would there be any audio difference in:
- Single Canare 4S11 for each pair of sub drivers, and a pair of Canare 4S11 for each upper section (3 x $1.59 = $4.77 per foot)
- Just using the 8 core Clark for the subs and upper sections ($3.65 per foot)
- Single Canare 4S11 for the subs, and Clark for the uppers ($3.65 + $1.59 = $5.24 per foot)
I'm tempted by option 2, as it's simple and cheap (just like me!) - is there any reason not to?
See edit below:
https://audiosciencereview.com/forum/index.php?threads/speaker-cables.31994/post-1127520
all my cables ( signal and speaker ) are DIY from Canare ...
Canare makes quality cable but the real reason to use their speaker cables is they are light, strong and flexible for applications where those things matter ... and with their round shape they're also designed to fit twist lock speaker connectors used in PA speakers and will not kink like a cable that isn't round ...
for home use Home Depot cable will work the same for a fraction of the price.
Canare is a quality product that is worth the price but the features it has are likely not something you need ...
that said my cables are about 15 years old and are same as new. some cheap plastic would disintegrate on their own in that span of time or lose flexibility but Canare stuff doesn't seem to be affected by time. just as flexible as it was new with the surface having exactly the same feeling as it did when new as well. very well made. would not hesitate to use again.
speaker cables have no sound of their own provided conductors are thick enough for the length of the cable and impedance of the speaker ...
now for microphone cable or very long signal cables rejection of electromagnetic noise becomes an issue and Canare Star Quad cable may actually be needed ... but in a home system you don't normally run 100 foot long interconnects.
use active speakers if you can and for subs just make sure the wire is thick enough - home depot carries all gauges of wire. there are formulas and/or calculators online that can help you determine the gauge you need. basically the total resistance of the cable should be under 5% or so of the sub's impedance. but realistically even if it's 10% or even 20% it wouldn't be the end of the world because as the driver heats up it will add that much resistance by itself. with a thinner wire you're just going to start out with a driver already compressing before it even gets warm
