AC resistance? He means "Impedance". What he is plotting is the natural impedance of the cable, and that includes the 'inductive rise' that happens with increasing frequency- This first plot shown is NOT a skin effect plot. It rises just like that of a dynamic loudspeaker woofer or tweeter.
More inductance can rolloff the top-end, this is true as he says.
The reason the Kimber is more capacitive is that it has more spaced conductors, individually insulated, and braided. For this same reason, Nordost is also highly capacitive, as well as others of this same variety of multiple spaced conductors. This however is not necessarily a GOOD thing.
More capacitance can make poorer or unstable amplifiers oscillate. He is right in this statement. Like higher L values rolling off the treble, higher C values can also rolloff the bass.
Of course the balance of the C/L cable components are inversely proportional.
For the most part- I agree with what he is saying; That wire is wire, and the performance of most wire will be close barring DCR or insertion loss via higher resistance cables. Since that usually is the case, I like making my own, and how I want them to look, albeit inexpensively. A good 2/12 from Canare, Carol SJ/SO, Belden Brilliance, or even more expensive Mogami should make just about anyone in this hobby quite happy. Dress it as you like! Avoid CCA wire, and go with copper.
I will also add that when I was 25 in 2003 at Dayton DIY(43 now), I took a controlled audibility test for speaker cables involving what used to be known as cheap SoundKing speaker cable (from MCM or PE) and the (funny enough) Kimber 8C cable. Bob Cordell conducted the test with his developed gear on a pair of tower speakers called 'Moxy' built by a guy of the name Peter. Towers used Vifa XT25 tweeters and M series Vifa woofers, but I digress... I was instructed to position myself in the front row, and they gave me a relay box with a switch, and told me to listen briefly and see if I could discern any differences. I didn't even know what we were doing yet. After my time, I had to relinquish control of said box and let someone else do the (rapid-fire) switching behind me out of view. There was no way I could count the flips as operated.
It was either 7 or 10 trials, I can't recall for sure, but I was able to accurately guess the cable playing the signal in all of those trials. For me, a piece of music containing a saxophone was what I settled on during my control period. The test was conducted with this music portion piece while I took the test. I know it's cliche, but it did sound like a 'veil was lifted' going from the KK to the Soundking, even if minutely so. Like listening to removal of grill cloth from a speaker. Shocked, the rest of the guys present tried to duplicate my result, supposedly hearing no difference. I was the youngest guy there.
Just make them flexible, heavy enough, and preferenced as your own eye-candy. Also try to keep the number of conductors per connection to as few as possible. This keeps the C lower.
