HighFutility
- Joined
- May 8, 2022
- Messages
- 234
- Likes
- 198
- Thread Starter
- #21
Thanks again for the back and forth, greatly appreciated. When you say spray, you are referring to HVLP and not airless paint guns, I take it?Learning to spray is several orders of magnitude easier than learning how to brush well. Toss your paint in the sprayer, let 'er rip, and like 80% of the time , you end up with a good result. Or, at least, you end up with a result as good as what you would have gotten if you brushed or rolled. Getting that perfect sprayed finish, free of any texture or orange peel, is usually just a matter of using the right tip size, slightly thinning the paint, using good products, and having good spray form.
I've sprayed Saman waterborne clear out of that gun and it comes out more or less perfect, with no modifications. Just remember it's always better to underspray than overspray, and get drips. And yeah it's $115 a gallon, but that's with a contractor discount, and it's the smallest size they make. No quarts.
But, if it were my speaker, I'd just slap three coats of tung oil on with a cloth, and call it a day.
Normally, I would stay away from cheap stuff, but given that this would be a new thing for me, I don't want to go and drop a ton of money for something I might use every few years. https://www.amazon.ca/Tilswall-Pain...8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
This "contraption" has 1800 reviews on Amazon, mostly positive. It's a gamble, but perhaps if it's totally crap, I can return it asap.
