- Thread Starter
- #21
Hi again,
First of all, thanks a lot for the advice about drivers so far, it’s been really helpful.
Now I’m starting to look into the electronics side and I’m a bit confused about how to properly integrate amplification, crossover and TWS in the same system.
I’ve been looking at modules like the Wondom JAB2+ (https://store.sure-electronics.com/product/812), which seems quite convenient since it already includes Bluetooth and amplification. The thing is, I’m not sure how the crossover would be handled. From what I understand, if there is no proper crossover built in, I would need separate amplification channels per frequency band.
In that case, I guess I would end up doing something like using one amplifier for the woofers of both speakers and another one for the tweeters of both speakers. But that’s not really what I’m aiming for.
What I actually want is to have two separate speakers (left and right), each one being a 2-way system, and ideally each speaker would handle its own woofer and tweeter internally, while also having Bluetooth and TWS between them.
So basically I’m trying to understand what the “standard” approach is here. Is it better to use a DSP amplifier board in each speaker so the crossover is done there, or is it more common to use a single DSP with multiple amplifiers, or even just go with a passive crossover inside each speaker and keep the amp simpler?
I feel like I’m missing something fundamental in how these systems are usually implemented, so any guidance or example setups would really help.
