Theta
- Joined
- Dec 30, 2023
- Messages
- 348
- Likes
- 200
- Thread Starter
- #61
I should explain why I am dishing accuracy.RE small two-way stand-mounts, that's what I figured: just a strawman argument, which you've now added to with concern about capacitors and passive filters, which further highlights the strawman aspect. So we can get that out of the way.
If you're dismissing stereo, and you're dismissing multi-channel, and you're dismissing 500k multi-way towers. I would return to my prior comment and echo the comments of some others in this thread: you're up against two problems, one of which is very difficult to address and the other of which it seems to me is categorically impossible to address:
1. The difficult problem is that you are limited by room size and characteristics. What you are looking for would seem to require a very large listening space that can at least begin to approach the scale of a small or medium-sized orchestral performance venue, and with acoustic properties roughly approximating such a venue. You'd also have to think carefully about the distance and height of the listening position, since where we listen from at home is usually radically different than where we listen from in a venue, relative to the source of the sound.
2. The nearly impossible problem is that you seem to be running up against the fundamental problem that listening to recordings of orchestral performances requires you to listen to an electrically recorded, electrically amplified version of acoustically performed instrumental music, converted to acoustic energy by some number of fixed-position transducers whose positions, number, and dispersion characteristics do not match the number, position, and dispersion characteristics of the original performers and instruments in the venue.
So like I said, good luck chucking out "accuracy," because based on the criteria you've set up here, there isn't any other characteristic you can replace it with that will get you to where you seem to want to go.
The closest I could imagine you getting to your desired result would be if orchestral recordings were made by close-miking every single instrument, along with miking the venue from a certain listening position to capture the ambient information. Then the mix would have to mix that ambient mic information with each instrument's individual recording track, at carefully calculated varying levels to account for the varying distance of the listening position from each instrument. Then the recording would have to be released as an N-track recording, with N=the number of instruments in the performance. And you'd need to listen to it in a space that somehow approximates the venue, maybe smaller but generally proportionally similar, and your own playback system would have to have the same number of channels/speakers, and you'd need to move each speaker to the position where each instrument was, relative to all the others.
If that sounds ridiculous, then I'd recommend you take a step back to consider how dismissive you're being of every practical playback setup (stereo, multichannel, the most expensive and high-quality speakers imaginable, and so on), and rethink your goal here, or at least how you're communicating it to the rest of us.
Oh - and if you believe that stereo is always or inevitably weak-sounding in the center, I'm sorry but you're doing it wrong.
Most comment and reviews talk about instrument separation and localisation. They call it accuracy, but it is actually pure BS
Stereo imaging requires lots of imagination.
In most non classical recordings the musicians are not even in the same room some times not even in the same country.
Accuracy in tone and timber is important.
I can deal with the room acoustics by measurements and trial and error.
I am dismissive of most highly recommended speakers on this site and others because even if they measure well, they dont stand out they are just spiting hairs and involve too many compromises.
Some one responded to my post, mentioning that Paul Klipsch was always lobbying for a center channel for hi fi. Home theater did not exit in his time, and he would not be referring to that gimmicky technology if he was still alive, so I am glad to hear that I have good company (PM) on my quest.
