- Thread Starter
- #21
I'm using MMM (moving microphone method) described here. In REW you do it as RTA measurement with pink noise.
Here is an example how it looks with my left speaker:
This was taken from the point at LP where app my left ear is. Red line is a sine sweep and green line is RTA pink noise. As you can see they are practically identical.
This is RTA where I moved mike in a horizontal circle with a diameter of 20cm (so around the area where my head would be):
This is RTA where I moved mike in a horizontal circle with diameter of 1m (so around the area where my sofa is):
This is a single point sweep taken app 5cm behind the first sweep (shown on first pic). As you can see it differs from first sweep quite a bit.
This is sofa spatial sweep vs left ear sweep, for comparison:
With average of 9 sweeps I was getting pretty close measurement to MMM RTA but I consider MMM RTA to better represent spatial average as it has 80+ samples instead of 9. It is also easier and faster for me to make it.
Thanks for this description. Could you further describe your RTA settings and pink noise generator settings?
What are the 80+ samples? Does this refer to FFT block cycles? How long are the cycles?
In the paper they say
"So with long time scanning, FFT analysis and rms averaging, the method combines temporal and spatial averaging. But note that the averaging has to be done on the whole scan duration, not a gliding average, with some constraints on calculation."
I take that to mean no overlap of FFT blocks and no windowing, which makes sense as you don't want measurements "backing up" over eachother, and "Forever" averaging.
In that case, it seems to me you'd get better resolution by simply doing one continuous recording and then post-processing with multi-taper methods to reduce bin leakage. Then import the frequency response. But perhaps leakage is not very important in this method.
