NE5532P bipolarny, oldschoolowyDlaczego? Z punktu widzenia inżynierii?
OPA1656 nowoczesny J-FET
Those are not engineering terms - you need to look at it in terms of the data-sheet specifications and ratings - and how those can impact the overall circuit performance in devices where the op amp is not the bottleneck for performance.NE5532P bipolarny, oldschoolowy
I'd be lying if I said I didn't like the 1656 opamp. I do. I've designed circuits for it and it's excellent! High value. Problem is, it's a spitfire. You just can't throw this thoroughbred in circuits willy nilly and not have it function as an oscillator once in a while.Why? In engineering terms?
Probably true, But when @Ggr used the word "difference" I'm pretty certain he meant "improvement". Not : "Completely buggered up by instability"I'd be lying if I said I didn't like the 1656 opamp. I do. I've designed circuits for it and it's excellent! High value. Problem is, it's a spitfire. You just can't throw this thoroughbred in circuits willy nilly and not have it function as an oscillator once in a while.
Sincerely, you have been gaslighting. The nitpicking and FUD-casting on other people's measurements and data. Jumping from topic to topic to keep from having to account for the things you are claiming. Misinterpreting. Not answering direct questions. Appeals to authority, and elitism. You seem to think you have unique access to stuff and experiences, which is odd given the forum you are posting at. For example, I have a box full of your unicorn OPA627. Let's check them out.
But first, briefly return to an example earlier in the thread, the OPA2604, and establish a baseline for distortion performance before I shoehorn some OPA627 into the preamp I have been using here.
I loaded pairs of NE5532, OP275, TL072, OPA2227, OPA2228, LM4562, OPA2604, OP270, OPA2132, OPA2134, and LF412C into the preamp. I swept the output to clipping. re are THD+N and THD for the group. I zoom in on THD to get a better view.
The NE5532 and a handful of OpAmps all stand out with best distortion performance in this application. The OPA2134 is among the best for distortion, which is great since I also have the OPA134, and I can make single- to dual-OpAmp adapters made two adapters since my preamp has two gain stages. The adapters prevented me from closing the lid on the preamp. But I see lots of OpAmp rollers who can no longer close lids on their gear.Cut holes.
Etc. So I'm fine.
To establish a baseline between the OPA2134 performance and the OPA134 mounted on my adapters, I did four runs. I did a run with all OPA2134 in the preamp, a pair of runs with just one OPA134 adapter configured with an OPA2134, and a run with both OpAmps using the OPA134 adapters. All of these are line on line matched for distortion, which I measured since you would have cast doubt on the validity of the result since my adapters are crude, not made from exotic materials.
I get the same results with the OPA134 as the OPA2134. Let's compare the OPA627!
Next, I measure the OPA627 across output voltage. The OPA627 has slightly lower distortion at 2-4V.
This is great performance, the differences are tiny, not audible.
To me you are wrong al 10mV thd is -80db and 100mV 95db the THD is audible , the yellow one in the first pic have lot thd then all othersSincerely, you have been gaslighting. The nitpicking and FUD-casting on other people's measurements and data. Jumping from topic to topic to keep from having to account for the things you are claiming. Misinterpreting. Not answering direct questions. Appeals to authority, and elitism. You seem to think you have unique access to stuff and experiences, which is odd given the forum you are posting at. For example, I have a box full of your unicorn OPA627. Let's check them out.
I loaded pairs of NE5532, OP275, TL072, OPA2227, OPA2228, LM4562, OPA2604, OP270, OPA2132, OPA2134, and LF412C into the preamp. I swept the output to clipping. Here are THD+N and THD for the group. I zoom in on THD to get a better view.
The NE5532 and a handful of OpAmps all stand out with best distortion performance in this application. The OPA2134 is among the best for distortion, which is great since I also have the OPA134, and I can make single- to dual-OpAmp adapters.
I made two adapters since my preamp has two gain stages. The adapters prevented me from closing the lid on the preamp. But I see lots of OpAmp rollers who can no longer close lids on their gear.Cut holes.
Etc. So I'm fine.
Here are OPA627 compared to OPA134 at 2V output.
Hey, since you were speculating, what other physical property determines how sound is reproduced?
Most people fail to detect distortion below -40 dB in real music even under ideal test conditions with quick switching and their best foot forward. With pure tones and using headphones, some lucky listeners reach a bit below -50 dB. Test it yourself.To me you are wrong al 10mV thd is -80db and 100mV 95db the THD is audible , the yellow one in the first pic have lot thd then all others
not a serius responce sorryMost people fail to detect distortion below -40 dB in real music even under ideal test conditions with quick switching and their best foot forward. With pure tones and using headphones, some lucky listeners reach a bit below -50 dB. Test it yourself.
-95 dB is literally the limit of audio CDs. If you think you can detect audible distortion which was not part of the original recording in correctly mastered 16 bit 44.1 kHz material, please share your ABX results supporting that idea.
Objective evidence and showing the ability to even verfiy it yourself is "not a serious response"?not a serius responce sorry
What it shows is a 6dB higher noise level, not higher distortion which is similar (and for higher frequencies even better) than OP2227.the yellow one in the first pic have lot thd then all others
please look thd at 20>>100mV is not the same thd at 2V ....What it shows is a 6dB higher noise level, not higher distortion which is similar (and for higher frequencies even better) than OP2227.
It is still is below audible levels as the noise that is measured is likely well above the audible bandwidth.
Most likely caused by its higher bandwidth.
maybe, can be crossover or loop gainActually the distortion goes down.
What you see is the S/N ratio getting worse as the signal is lower and noise stays the same.
There is no crossover distortion in a not substantially loaded op-amp (they are class-A with loads > 2kohm)maybe, can be crossover
Thanks for the random speculation.To me you are wrong
if you do not look under never knowNO, as I explained.
S/N ratio.|
What do you mean with this ?if you do not look under never know
