SOVOX Minimax3 Monitor Review
Rate this monitor:
    Votes: 2 1.6%
    Votes: 64 52.5%
    Votes: 47 38.5%
    Votes: 9 7.4%
This is a review, listening tests/EQ and detailed measurements of SOVOX Minimax3 3-way coaxial speaker with passive radiator. It was donated to me by the company and costs US $325 each.
This is one stout metal enclosure with so much stuffed in it. It has an integrated stand as you see and at the bottom, there is a down firing passive radiator. The top driver is coaxial midrange+tweeter.
Back side impressed me with rather clear menus on the small display:
SOVOX MiniMax3 3-way monitor PC stereo studio speaker LCD XLR back panel review.jpg
I tested the unit in "Free standing" setting.
I like that despite being so small, the power supply is built-in and we have XLR inputs indicating it is truly a "monitor" as opposed to "PC Speaker."
Note: I tilted the speaker back fare enough for measurements so that the front was 90 degrees to reference plane of the measurement system.
SOLVOX MINIMAX³ Monitor Speaker Measurements
As usual we start with our anechoic family of frequency response measurements as computed by Klippel NFS:
SOVOX MiniMax3 3-way monitor PC stereo anechoic frequency response measurement.png
Macro level view shows rather flat response from 50 Hz all the way to nearly 20 kHz. There are however, many micro deviations with some bunching up between 1 and 2 kHz. Directivity is variable which naturally hurts early window response and predicted in-room:
SOVOX MiniMax3 3-way monitor PC stereo early window frequency response measurement.png
SOVOX MiniMax3 3-way monitor PC stereo predicted in-room frequency response measurement.png
Slope is rather flat as well indicating likely bright sounding. But note that the last two graphs are statistical in nature and apply to far field listening.
Directivity as noted is somewhat uneven:
SOVOX MiniMax3 3-way monitor PC stereo horizontal beam width measurement.png
SOVOX MiniMax3 3-way monitor PC stereo horizontal directivity measurement.png
But coaxial nature gives you somewhat similar vertical and horizontal response.
The highest level distortion I could dare to run was 91 dBSPL:
SOVOX MiniMax3 3-way monitor PC stereo relative THD distortion measurement.png
Step response for fans of that:
SOVOX Minimax3 Speaker Listening Tests and EQ
First impression was rather bland here. Not because the Minimax3 is bad but rather, its max performance right below the bar at which my reference tracks shine. Cranking up the volume I wanted would cause the red clipping light to come on. At lower levels, bass was too faint, taking away dynamics.
Looking at the response, I initially just dialed a high shelf above 1 kHz to bring the highs down. This gave me a much needed warmth in exchange for some air and detail. I liked it better but wanted to see if a machine generated one would do better. So I asked ChatGPT Pro to create 4 PEQ filters with only one decimal place. It created this:
FilterTypeFrequency (Hz)Gain (dB)Q
1Peaking259.0+1.10.8
2Peaking1088.0+2.64.7
3Peaking7925.0−1.00.5
4Peaking9810.0+2.53.5
Preamp: −5.0 dB
Its pre/post graph (zoomed) looks like this:
I wish it had taken down the peak around 1.5 kHz but maybe it stopped because I told it only 4 filters. What it produced was inverse of mine in the way it boosted the lows. It also made small, localized corrections. The result was better than mine, with more subjective detail than my crude single filter.
With this filter in place, the threshold of performance went up high enough that now I could enjoy some of my tracks. There was just enough bass to have a somewhat even spectrum.
Wanting to know what a size up speaker would do, I swapped in the Neumann KH80 DSP ($595). The transformation was massive with the Neumann getting substantially louder, with fuller bass and wider spatial image.
From engineering point of view, there is a ton here stuffed in a low cost, but not cheap package. We have DSP, 3-way, coaxial design with passive radiator, built-in stand and power supply. I am left though thinking if fewer components but at higher level would have done better. As is, the minimax3 really needs a subwoofer to be usable. Fortunately with some EQ, you can pull its performance high enough that it becomes good enough by itself.
Anyway, it is nice to test such an unusual speaker.
02Acoustics46 Hz – 20 kHz · 97 dB
Frequency response49 Hz – 20 kHz−3 dB
Frequency response46 Hz – 20 kHz−6 dB
Max SPL @ 1 m97 dBShort-term · 100 Hz – 6 kHz
Max SPL @ 1 m95 dBLong-term · IEC 60268-5
Crossover240 Hz / 3.6 kHz3rd order
THD @ 80 dB / 1 m< 1 %240 Hz – 20 kHz
THD @ 80 dB / 1 m< 2 %100 – 240 Hz
Signal-to-noise ratio105 dB
03Drivers
3.5″ + 3″ + 1″ + passive radiator
Woofer3.5″ carbon-fiber cone30 mm voice coil
Coaxial midrange3″ carbon-fiber cone26 mm voice coil
Coaxial tweeter1″ silk dome25 mm voice coil
Passive radiator3.5″ × 6.3″5″ equivalent
04Amplification & DSPClass-D · 80 W per speaker
Output power40 / 20 / 20 WLF / MF / HF
Power amplifiersMA12070P Class-DPBTL bass · BTL mid / high
ADC / DSPPCM1804 / ADAU1701
Op-ampsOPA1678 × 3
Master clock24.576 MHz
05Inputs & control
XLR · RCA · 4 placement modes
Analog inputsXLR +4 dBu · RCA −10 dBV
Max input level+12 dBu XLR · −2 dBV RCA
Volume range−30 dB to +6 dB0 dB reference
Treble+2 / 0 / −2 dB
Bass−4 / −2 / 0 dB / Dynamic
Placement modesFree · Desk · Wall · Desk & Wall
USB-CFirmware updates onlyNot an audio input
06Physical & power4.1 kg · 192 × 108 × 199 mm
Dimensions (H × W × D)192 × 108 × 199 mm7.56″ × 4.25″ × 7.83″ · stand excluded
Weight4.1 kg9.0 lb
EnclosureUnibody aviation-grade aluminum
Power100–240 V AC · 50/60 Hz
Consumption52.5 W max3.5 W standby
i also enjoy the offbeat reviews. Christmas is coming and we all need something different to try.
I guess the videos have slowed because they take a lot of time. but maybe some more tutorials on Roon EQ or Sub integration.
good evening all
If one have a DSP at hand, these there points, circled in green, should have ben merged into one point in time. At least on axis - and off axis, the 2 leftmost should still be time aligned thanks to the used coax.
Thanks for the review, Amir. :)That was a cool speaker.
Now we have another one we can recommend.
I think the most common request for speaker recommendations here on ASR is for bookshelf speakers in this price range. Correct me if I’m wrong, but that’s how I perceive it, at any rate.
Not bad at all, price and feature set considering. I wish the distortion performance was better. Not surprised that a Neumann trounced it because, well, Neumann.
I bet my Videoton Minimax II speakers from the early 80s weren't as ruler flat as these. They were a staple of UK HiFi shows, the presenter placed them on top of a giant speaker, switched between the two & then asked the audience which they preferred? A bargain at 40 pounds/pair on sale. I used them corner loaded in my 8ftx12ft bedroom system. I blew out (then replaced) a bass unit playing Dark Side Of The Moon too loud. Sold them when I left the UK, the're probably still playing music somewhere. Happy days!
Ok so I could have better performance for 10% less money with the Adam D3V
The D3V is rather half the price, maybe you confused its pair price with the single price of the Minimax3?
Yeah, not great, they're still $650 a pair, and there's no real bass. But they look lovely with those very professional grids.
Wow, what a nifty thing, desktop users will enjoy it!
Thanks for the interesting review @amirm!
Meh. 3way where a 2way would work fine. Phase seems off. In-room response sub-optimized. There's probably fixes for most issues here, but at this price - why bother.
I really like the styling, and it's a good performer. $650 for a pair plays with the big boys, though.
If you align the first 2 youll get a wiggle in the transient. There already so close you will not hear a difference. The only way to align the woofer peak with DSP is to delay the mid and tweeter, than youll get the woofer starting its transient before the mid/tweeter and instead of fast rise on the step youll get the slow transient of the woofer for the first 2 msec instead of the .1 msec transient of the mid/tweeter. Youll kill the attack of drums ect.
