Some more thoughts on distance and depth perception, which to me is very important for having a "believable" illusion. Amplitude and timing cues in the recording are one thing, but how this translates in room is a totally different animal, and different rooms in my opinion require different setups. If you have loudspeakers with very good directivity and FR, chances are they will accurately present cues which are in the signal, but you still have to set them up right in accordance with room acoustics.
One thing to consider is how to achieve the preferable direct to reverberant sound ratio within the sound field. The direct sound has a precedence effect over the reflections, but loudspeakers with different dispersion patterns would give you different ratio of what's in the recording (direct sound) and different orders of reflections, early ones being the most important.
Another thing to consider is that sound pressure levels in room are not behaving the same as in free field. The farther away your listening position, the quieter the direct sound would be, but the energy of the reflections stays the same. If you take an SPL meter and go farther away from the loudspeakers, it will show less and less SPL until a certain point where, if you go any further, there would be a critical distance where the direct to reverberant sound ratio will have an effect that SPL doesn't drop any further. So listening distance does matter.
Next thing would be distance to the points of first reflections, where both the distance of the loudspeakers to the side walls, and your listening position to the loudspeakers and the sidewalls would matter. Also, how reflective the walls are.
Essentially, the setup, when done right, should never tell you how far away your loudspeakers are (granted this also depends on loudspeakers themselves, which there's nothing you can do about unless DIY like myself, or choose to buy the right loudspeakers for the application).
Still, all things considered, my own loudspeakers give a very different presentation in different rooms, regarding distance and depth. Although they never tell where they are located (property of loudspeakers), in one room (my workshop) I'm able to set them up further away from the front wall, and the sidewalls. There's also diffusion with shelves on both sides. This gives more preferable ratio of direct vs. the reverberant sound and the effect is such the all the objects within the soundstage are placed behind the speakers, achieving great depth and pinpoint image focus. Like in the map of the recording I posted previously, if I would to compare it with Geoff Martin's observations, this would be the best setup I could achieve.
The second room (my living room) is where the current setup is, I was very much constrained when it comes to placement. Not only loudspeakers/sub had to be placed near the front wall, but they are also wildly asymmetrical to the sidewalls (the left one sees the left wall within the close vicinity, and the right one sees an open space to the right, with the right sidewall being too far away to be significant to early reflections). I for one did think this would sound so bad that I couldn't do anything about it. But it isn't quite so. It's just different.
With a lot of toe in (the point of intersection of the loudspeaker axis would be 1m in front of MLP), I was able to achieve the sound field where at certain SPL, I still get a preferable direct to reverberant sound ratio. I say with certain SPL, because indeed it does change with a simple volume control. This does nothing to the left and right panning (it's in the recording), but it does to the distance and depth. With low SPL, the depth is normally constrained and everything appears to be as distant as the loudspeakers are. At normal listening levels, the direct sound starts to win over the reflections, but as opposed to the workshop setup, the depth isn't perceived to be behind the loudspeakers, but in front, with a slight image shift biased to the left, because of the proximity of the left side wall. On occasional loud listening sessions (and they are truly occasional because I value my hearing), the sound field, or the ratio is such that phantom images are within my hands reach, even though loudspeakers are 4m away, also with some anechoic effects that the images are on my left and right shoulder, also within my hands reach at 90 degrees left and right, or above my head, just never inside. The images are also becoming less and less fuzzy and regaining focus.
Even though you might say that this is surreal, it's somewhat addictive and it gives me the most believable illusion that "they are here" as well as "I am there", depending on the recording. Still, there are bad recordings which I cannot do anything about, but if I like the music, I will listen to it. It's just that I have to be responsible not to expose myself for too long and not jam my finger on the volume up button. So, there is a way to win over poor room acoustics, but sadly it involves substantial amount of dynamic capabilities, low noise and distortion, also some power.
Sorry about the long post, but I thought it might be interesting to someone.
Here are some more links for your information:
http://www.tonmeister.ca/main/textbook/index.html (a myriad of valuable information)
http://www.tonmeister.ca/main/textbook/intro_to_sound_recordingch4.html#x19-1630003.1 (part about acoustics)
http://www.tonmeister.ca/main/textbook/intro_to_sound_recordingch6.html#x24-3230005.9.2 (psychoacoustics, distance perception, etc.)
http://www.tonmeister.ca/wordpress/2014/02/14/bo-tech-but-what-if-my-room-is-scandinavian/ (nice article about reflections and comb filtering)
https://www.acs.psu.edu/drussell/Demos/phase-p-u/phase-p-u.html (phase relations of displacement, particle velocity and pressure)
And, last but certainly not least,
-Introduction- The term 'room gain' is often seen used when the topic of subwoofers and the low frequency sound reproduction comes up. As I see many explanations that are lacking or incorrect, I thought I might try and clear up the topic once and for all. In all rooms there are so-called...
www.audiosciencereview.com
I would beg to differ. A polarity flip can be readily identified in a ABX in a split second with many recordings when they contain kick-drums and/or thick bass-lines and when these signals are asymmetric around the zero line, which they often are. We don't need a study for that as it is one of...
