SounDigital SD 600.1D Nano Car Amplifier
This is a Brazilian company. I expected a lot better from SounDigital... :rolleyes:
@amirm could you please test this at 50 Hz, where it is intended to work, powering a subwoofer?
I have an Alpine PDX F4 that I haven't used in forever. I should box it up and send it in...
Please do! I use an Alpine PDX-V9 every day, they should be similar. I am curious how it measures.
V9 specs are promising:
  • THD+N (10W into 4 Ohms) for CH-1/2/3/4: <0.005 %
  • THD+N (10W into 4 Ohms) for Subwoofer: <0.006 %
  • THD+N (Rated Power into 4 Ohms) for CH-1/2/3/4: <0.03 %
  • THD+N (Rated Power into 4 Ohms) for Subwoofer: <0.05 %
  • Damping Factor for CH-1/2/3/4: >500 into 4 ohms at 100Hz
  • Damping Factor for Subwoofer: >1000 into 4 ohms at 100Hz
  • Signal to Noise (Rated Power into 4 Ohms) for CH-1/2/3/4: 112 dB
  • Signal to Noise (Rated Power into 4 Ohms) for Subwoofer: 119 dB
  • Weight: 2.7 kg
http://www.milbert.com/bam235ab
Be nice if someone could send one of these to Amir.
There were so many good bits on the milbert web site - but I really appreciated this one...
<quote>
What's the rating?
30 Watts per channel, 20 Hz -- 20 kHz, -3 dB, 3% THD Some owners have reported that the BaM-235ab's "30 tube Watts sound much more powerful" than comparably-powered amps. This is often attributed to the soft-clipping nature inherent in its design. Unlike transistorized amps which smack and crackle with abrupt distortion, the BaM-235ab exhibits graceful, smooth overdrive into clipping.
<end quote>
Spec’d at 3% THD - just think how bad it might actually measure? Seems unlikely that noise would be high enough to even be much of a factor... or maybe it is that bad...
<quote>
What's the rating?
<end quote>
It's that old tube amp tech, working on the pleasing even order harmonics. It can certainly sound euphoric I suppose, but I'd rather hear my music as it was intended, and just let my listening room screw up the rest. ;)
There are actually a few solid state companies out there, literally injecting even order harmonics into their amp design. I believe NuPrime was one of them.
I appreciate Amirm's work. However, this is not eye opening as it was expected. I would say we should look at something else that has better hope to deliver good results. Our life is kind too short to waste on such crap.
I had to do a retake on this. I thought you wanted him to test this using AC power at 50Hz, such as the UK. Perhaps that would indeed improve performance after it catches fire. ;)
Wow, 7000W PMPO! Is this the power it creates once in its life time when it goes up in fire? :D:D:D
From the Company:
"..The customers’ satisfaction comes in first place, being constructed by relations based in Ethics, Transparency and Trust..."
Mhhhh? What's there THD? Something must be wrong.
  • Weight: 2.7 kg
I've got it stacked with a PDX M6 in my trunk, which I do still use for sub duty (I just don't listen as loud in me car as I used to so the F4 hasnt been used in 3 or 4 years). When I get some time I will have to pull and separate them.
Here are specs from the Alpine PDX-F4, now discontinued, but should be the same for the 4 channels for the full range speakers of the PDX-V9, which is still current.
PDX-F4 4/3/2 Channel Power Amplifier
  • CEA-2006 amplifier ratings: 100W RMS x 4 [4/2 ohm @ 14.4V ≤ 0.05% THD+N]
  • S/N ratio; 95 dB (ref: 1W into 4 ohm)
This THD+N at 5W about 0.003% SINAD 90 should put it in the green area of the best amplifiers. :)
PDX-F6 shown below.
That was entry level. Their discontinued model had specified 35 kW RMS!
https://soundigitalusa.com/products/35000-1d-power/
TECHNICAL SPECIFICATIONS
Power @ 14.4V @ 1Ω: 1 x 35000 W RMS
Power @ 14.4V @ 2Ω: 1 x 19250 W RMS
Power @ 14.4V @ 4Ω: 1 x 10587 W RMS
THD + N (10% Rated Power): 0.3%
Frequency Response (+/- 3dB): 20 Hz – 18 kHz
Damping Factor: > 100
Max Current Draw: 2971 A
