1niltothe
- Joined
- Jun 27, 2021
- Messages
- 60
- Likes
- 31
Apologies if this is a discussion which has been had elsewhere. I will delete the post if so.
I just went through the calibration and measurement process on the latest SoundID Reference programme. I wanted to check:
-> the process which locates the microphone in 37 positions. The programme suggests I just hold the microphone. It seems very difficult to do this without my body affecting the measurement. In some cases my body came between the mic and L or R speaker. At the very least, holding the mic rather than using a stand seems likely to have effects, no?
-> the animated 'echo location' software which positions the microphone prior to each measurement. First, the CIA should use it to break prisoners instead of Deicide. Second, in some cases, the app would only accept the microphone position if I pointed it in some bizarre direction like at the back wall or whatever. Seems a bit messed up.
I just wondered whether other people had found ways to optimise the process, or does the sheer number of measurements mean such things don't matter?
