- Thread Starter
- #21
Yeah, I might need to go after this microphone calibration process. Will try to enlist some local help for that.The very first thing i would get is a calibrated measurement microphone (like the UMIK1), a laptop and REW. That should give you good insight in how your speakers interact with your room. Only then i would start thinking about upgrade.
Your stuff seems to be fine overall, i would like to listen to some tunes with it. However, i only know the Yamaha and Sennheiser HD650 myself.
Maybe you can lend an integrated amp from someone to verify that it is or is not the preamp/power amp combination? Before buying stuff
Thanks for the kind words, happy to see there's someone who'd like to listen to some music with my setup!
Yeah, better to test more and get some equipment before allowing the upgrade bug to take over.
