Sony WH-1000XM6: Response Curve and EQ Proposal (Based on 5 Pro Reviews)
Abrise
French Expat in Bangkok
I recently purchased the new Sony WH-1000XM6 as a replacement for my aging WH-1000XM3, which I bought in 2018. The older unit is still working well after seven years and only required a battery and ear pad replacement once. I mainly use headphones on planes and in cars, and rarely at home, so my total usage has been around 900 hours. I’ve stuck with Sony after disappointing experiences with both Sennheiser and Bose in terms of sound quality.
Out of the box, the XM6 already sounds less muddy than its predecessor, with a more refined presentation. However, I feel that some improvements are still needed, especially in the bass region.
Since direct measurements require specialized equipment, I turned to several professional reviews that have published response curves:
As of today, the WH-1000XM6 is not yet listed in the AutoEQ database.
Among these sources, only SquigLink conveniently provides the raw frequency response data in .txt format. For the others, I used WebPlotDigitizer to extract the data manually from the graphs.
Response Curve Comparison
Here is a comparison of all five measurements, normalized at 1 kHz:
As you can see, while the general shape is fairly consistent, there is significant variation—especially above 3 kHz. In the bass, the SuperReview curve is clearly an outlier, showing much higher energy than the others. I decided to discard the two most extreme profiles (SuperReview and LTT) and average the remaining three: RTINGS, Kuulokenurkka, and SoundGuys.
Averaging and EQ Strategy
In front of quite a lot of variations between the professional measurements, one must EQ with modesty. The average will serve as a basis for EQ toward the Harman 2018 target. However, due to the higher variability in the treble region, I have chosen not to apply any correction above 1.91 kHz. This frequency was selected because it’s a crossover point between the averaged response and the target, making it a logical zero-correction point going forward.
Filters
In this final graph, you can see:
  • The average measured response
  • The target (based 0n Harmann up to 1.91 kHz, the response itself after)
  • The generated convolution filter
  • The PEQ filter response
Both filters were generated using AutoEQ.
  • The convolution filter can be used with JRiver, HLConvolver, or Equalizer APO (Windows).
  • The PEQ filter is compatible with Poweramp Equalizer on Android and many softwares on windows
I’ve attached both filters .
I don't understand what Sony's engineers are thinking hyping the upper bass like that. I've tried the XM3 once and those had the same problem with the bass and yet they haven't fixed it yetm after another three generations??
These are the Q values for the Sony app:
31 hz Q 0,9
63 hz Q 0,9
125 hz Q 0,9
250 hz Q 0,9
500 hz Q 0,9
1000 hz Q 0,9
2000 hz Q 0,9
4000 hz Q 0,9
8000 hz Q 0,9
16000 hz Q 0,4
I recommend trying something like this:
You get this based on my data:
In addition to personal hearing there might be some unit variation, as the EQ suggestions provided by, for example, Headphone Show and Super Review sound quite off to me.
Overall, XM6 measures quite consistently, as the seating mainly changes the upper treble. Bloated bass can be fixed easily, but after that the peak at 10 khz sounds unnatural. Harman Target, unfortunately, is too smoothed to show it well, but with these IEC711 rigs there should be a dip at the same region.
Here you can see it better:
It's what their market wants.
If you see the EQ threads on reddit r/sonyheadphones, many of the people there boost their lows on top of this, and they're rather hostile to the suggestion that these cans already come out of the box with too much mud in the upper bass.
To Sony's credit, at least they provide a decent graphic EQ to undo the damage.
Is there no fix whatsoever for the 8k drop
It would be interesting to know if the bugs of the xm5 have been fixed. I returned it for two reasons:
1. pads too small, too flat, too uncomfortable.
2. the pads caused noise when I moved my head
Sony still uses the same plastic pads, but this time even thinner. Luckily, there is more room inside the cup around the drivers. I bet you wouldn't find XM6 much more comfortable compared to XM5.
But do they really want that hypped upper bass/lower mids? Because I do get the hypped lower/mid bass, it gives everything more weight, but hyping over that has never sounded good to me, it's just aweful mud.
But yeah got to give them credit for finally delivering a decent EQ, the one for my WF-1000XM4 is a five band with the lowest band at 400Hz which is utterly useless.
3rd party EQ like Poweramp or Wavelet got PEQ.
Thank you for the measurements, they are very close to the average and will not lead to overestimating the correction.
I have been using for several years for the sony wh-1000wm3 autoeq.app based on your response curve . Would you be so kind to make available on this site your measurements of the xm6 for the community to use ?
Also your information on the q values of the sony app are very interesting . Several reviewers believe that the q values are 1.4. That is one of the reasons that I prefer to use for android poweramp equalizer where one understand what he is doing and can be valid system wide after a small ADB shot.
It could be to (over)compensate for the ANC. Blocking the lower frequencies can't be easily done as it requires more physical isolation.
I measured each band with -3 and +3 from the Sony app and used Squiglink EQ tool to check, which Q value matched with the result. I had baseline measurements with the same seating, of course. This clearly gave me the Q value 0.9, which is quite common for these kinds of apps. AKG N9 Hybrid, for example, also has most of the 10 sliders with the Q value 0.9.
The creator of AutoEQ, Jaakko Pasanen, has not been updating his database very often anymore, so I am not sure what's going on. We Squiglink people (at least most of us) have given him the permission to use our data. Luckily, you can export measurements as text files from Squiglink yourself and then use them with AutoEQ.
Here is the average of both channels as CSV file. I didn't try how it sounds, but checked that AutoEQ could read it properly.
I am thinking to buy the xm6. Any thoughts or experiennmces. I use wavelet to eq my headphones.
It would also be nice to get eq with anc off. I have only seen anc of FR on rtings.
31 hz Q 0,9
63 hz Q 0,9
125 hz Q 0,9
250 hz Q 0,9
500 hz Q 0,9
1000 hz Q 0,9
2000 hz Q 0,9
4000 hz Q 0,9
8000 hz Q 0,9
16000 hz Q 0,4
This eq really saved the XM6 for me. Sounds great to my ears now. Thank you for sharing, highly appreciated!
Even without EQ I find it to be the best XM they did til today. Best sound, best ANC.
I use an XM for outside stuff as a headphone/earprotect/anc appliance. I do that with an old XM4 as the newer ones don't sit that tight in position as the older ones. Only drawback I can think of.
I own the XM4 and XM5 and have always been impressed at the amount of tech packed into these at their price point. Their best trait is the Bluetooth connection, it is incredibly solid. I’ve left my phone playing music in my seat near the front of a 777 and walked all the way to the back of the plane and they still work! The noise canceling is rather good, they are a must-have on long flights. I also enjoy using these for phone calls, Zoom meetings on the go, etc., as the microphone array works very well. The battery life is great, too. I hear the XM6 offer incremental improvements in all these areas.
For music? Well, I wouldn’t buy these for the main purpose of listening to music. As this thread shows, they have a rather muddy signature on the low end, recessed mids, and lots of messiness at the high end. The soundstage is ok for closed back cans. The detail is ok at some frequencies, but flabby down low and a tad sibilant up high. Still, the fact that they play music and have a “fun” sound is like a bonus feature rather than the main event.
