Sony ubp-x700
davidebond
Italy
Hi,
can I use this player to listen to music with a headset without connecting it to a TV?
Is it worth purchasing it? Can you suggest me a budget cd player which could reproduce various formats?
Thanks and best,
Davide
staticV3
Yes, but you have to use an external DAC + headphone Amp.
For example:
-Topping DX3Pro+
-SMSL C200
-Khadas Tone Board + JDS Atom Amp+
JaccoW
The Netherlands
I have used the UBP-X800 blu-ray player with bluetooth in the past which sounded fine. (even though I could hear a difference compared to a good DAC).
You will either need a receiver with HDMI or a DAC/headphone amp through Coax like Statis mentions above.
There are many, many good vintage CD, Multi-format and SACD players available that could work for you.
What is it you want to listen to and with what kind of headset?
davidebond
davidebond
Italy
I own a Topping dx3 pro (without plus... :)). But you can suggest a different choice.
Thanks and best,
davide
staticV3
It's got analog and digital output, so you can either use its built-in DAC (likely not very good) plus an external headphone Amp to listen to music, or you can use your DX3Pro via S/PDIF or Toslink.
Again, no TV required.
davidebond
davidebond
Italy
Do you mean that using an external dac, with the Sony (see above) or the Yamaha the result is the same?
davidebond
davidebond
Italy
From this point of view is best sparing and purchasing the Sony... :)
Thanks and best
davide
