Sony UBP-X700/K Review (Blu-ray/DVD/SACD/CD Transport) (NTTY)
Rate this universal transport
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 2 2.2%
  • Good (***)
    Votes: 9 9.9%
  • Excellent (****)
    Votes: 80 87.9%
I bought one too for euro 299. Just in case my Sony SACD player breaks. Hopefully I can connect to an i2s DAC using an audio extractor box
Crutchfield is now "out of stock, no known arrival date" on the Sony UBP-X700U. If you bought from Crutchfield, you may have gotten the last one.
At that price point, the best option now is probably the Panasonic DP-UB450, which you can still get via Amazon for $313. Crutchfield doesn't seem to carry the Panasonic DP-UB450. They have the Panasonic DP-UB420 at $369, but no Dolby Vision with that model.
For an HDMI audio extractor, I'm using the iArkPower HDMI-to-Optical extractor (Amazon $30) with good results + small footprint.
I'm using my XBox SeriesX as a quasi gaming PC at my computer desk (my PS5 & Switch2 are connected to my 5.1 home theater).
The XBox is HDMI out only, so my XBox setup: XBox SeriesX (HDMI out)-->iArk (Optical Out)-->Fosi ZD3 (Analog RCA out)-->Yamaha HTR-5960.
I also have an M4 Mac Mini (USB out)-->Fosi ZD3 (Analog RCA Out)-->Yamaha HTR-5960. I'm using my ancient Yamaha HTR as a desktop stereo amp to drive external speakers (ELAC UB52) and headphones (Pioneer HDJ-2000).
Awesome measurements, Flo. Hard to beat bit perfect SPDIF output and proper de emphasis support at this price point
I am in the Netherlands. I bought it at Mediamarkt:
It should arrive today
I was plannning to order this device:
Not sure if the quality of this device matters for the end result
I asked Grok if it would work., This was te reply (hope it is right...):
Yes, this Audiophonics HDMI/MHL to I2S/Coaxial/Optical extractor is a realistic option for getting native DSD from the Sony UBP-X700K, provided your DAC has a compatible I²S input.
What the device does​
It is an HDMI audio extractor based on the EP92A3E chip. It takes a standard HDMI signal (including the Sony’s HDMI OUT, preferably the audio-only HDMI OUT 2) and extracts the audio stream to:
  • I²S (via the HDMI LVDS connector in PS Audio format, plus a 6-pin XH 2.54 mm connector and solder pads)
  • Coaxial S/PDIF
  • Optical Toslink
  • Pass-through HDMI (for video if needed)
The manufacturer explicitly states it supports LPCM, HD audio & DSD Audio.
Real-world reports with SACD / DSD​
Multiple user reviews on the product page confirm it successfully extracts native DSD64 from SACD players (including Sony Blu-ray/SACD units) to I²S:
  • Users report clean DSD extraction from SACDs when feeding the I²S output into DACs that accept I²S (examples mentioned include Denafrips, Holo Audio May, Topping models, etc.).
  • One review specifically notes extraction of DSD 2.8 MHz from a Sony UBP-X500 (very similar player generation) when combined with an additional interface board.
  • Higher-rate DSD (DSD128+) is often reported as falling back to PCM (typically ~176 kHz).
This matches the common limitation of many such extractors: they reliably handle DSD64 (standard SACD rate) but may not pass higher rates natively.
Requirements and caveats for it to work well​
RequirementDetails
DAC sideYour DAC must have a true I²S input that accepts the PS Audio pinout (or be configurable to match it). Many modern DACs (Denafrips, Holo, Gustard, SMSL, some Topping, etc.) support this; ordinary USB/coax-only DACs will not.
ConnectionConnect Sony HDMI OUT 2 (audio only) → extractor HDMI input. Then extractor I²S output → DAC I²S input. Use a good HDMI cable for the I²S link.
PowerExternal 5 V DC supply is required (not included). HDMI power alone is often insufficient or unstable.
Player settingsDSD Output Mode = Auto, Digital Audio Output = Auto, BD Secondary Audio = Off.
Mode switchThe extractor has TV / AMP / DOU modes. Use AMP (stereo) or DOU (multichannel) as appropriate.
LimitationsReliable for DSD64. Higher DSD rates may convert to PCM. I²S pinouts are not fully standardized—match the PS Audio mapping or check your DAC’s settings. Some users report needing careful cable quality or additional filtering for best results.
Bottom line​
This is one of the more commonly recommended inexpensive solutions specifically for extracting DSD from Sony (and Oppo) players over HDMI when your DAC only has I²S (not native HDMI One Bit Audio). It has solid user confirmation for SACD/DSD64 use cases.
If your DAC already accepts I²S in the PS Audio format, this should work. If it doesn’t have I²S, this extractor alone won’t help—you would need a different path (or a DAC that does support DSD-over-HDMI natively, which is rarer).
  • Coaxial S/PDIF
  • Optical Toslink
RequirementDetails
Bottom line​
I generally hate agentic AI, but when it doesn’t act like a godlike authority but surveys specific information sources that it carefully cites like this result does, I can grudgingly admit its limited usefulness as an automation tool.
It is very offtopic, but I had some computer parts from 2019 still laying around.
  • ASUS ROG STRIX B550-F GAMING
  • Ryzen 5 PRO 4650G
  • 2 × 8 GB Corsair Vengeance LPX in A2 + B2
  • Samsung 970 EVO Plus 1TB in M.2_2
  • CPU cooler → CPU_FAN
  • Case fan → CHA_FAN3
  • 24-pin ATX
  • 8-pin CPU/EPS
  • HDMI → motherboard
  • Integrated graphics from the 4650G
  • RX 6650 XT
  • Fractal Design Define R5 Black Midi Tower
For some reason I never got to assembling it. Just used my laptop from work. But now I am retired and had to give the laptop back. I used ChatGPT to put everything together and it gave me very good tips (eg raising the memory speed to 3200Mhz, install new chipset drivers). Saved me a lot of time and worries.
It is a bit scary though. Also used Claude to (help me) learn programming in Python (eg implementing branch & bound algorithm to solve the traveling salesman problem).
NB. I programmed in Algol, C en Pacal before, but that is centuries ago...
Sorry very offtopic, only want to say, it can be very helpfull especially if you don't have detailed knowledge (yet). Oc there is also a danger
My Sony UBP-X700U arrived yesterday. Surprisingly small footprint--about 1/3 smaller than my 1st gen Panasonic DMP-BD35.
The X700 is really lightweight, almost too light for my liking. I like sturdy electronics, something with weight. My new WiiM Amp is a good example:
it feels heavy when you unbox it. The WiiM is about the same size as the X700, but feels twice as heavy. Like if I dropped the WiiM, I'd bet money it would survive with a few scratches. My X700--I'd hate to drop it. I think it would break like glass.
Anyway, I connect the X700 to my home theater and go through the settings. I turn X700 upscaling off because my Sony Bravia OLED TV has a better upscaler. At least that's what Google's Gemini AI tells me. Let the $1300 television upscale instead of the $300 4K player. This is pretty important because I have a large 1080p Blu-ray library and quite a few 480p DVDs. My demo test is a 1080p Blu-ray disc--my current fav, Prey (2022). There's a scene where the Comanche hunt a mountain lion at night, which tripped up my Panasonic DMP-BD35: artifacts everywhere and then it stalls. The night hunt plays beautifully on the X700. Also load time on the X700 is blazing fast compared to my 1st gen Panasonic. I haven't gotten around to watching an entire disc yet. Will post here if anything interesting happens.
The X800-M2 version had Bravia mode and I think that was exactly what it did. Turn off the upscaling because the TV had a better upscaler. Sony TVs have always had tremendous upscaling so you are better off letting it handle it.
The X700 definitely does feel less robust, but I have used the one I got quite a bit and haven't had an issue with it playing a 4K, regular blu-ray or DVD discs.
I just ordered the Sony UBP-X700U to replace my ancient Panasonic DMP-BD35. Amazon bumped the price on that player from $330 to over $550 (don't believe their "price history" info, I've been looking at this player for a couple of months now). Crutchfield still has it for $328 along with a "low stock" warning.
Update on this: Amazon just dropped the X700 price to $328 after listing it for $558 just a few days ago. And Amazon's "price history" doesn't show this huge spike, then drop. Honestly, I'm not sure WTF is going on here. This may sound paranoid, but Amazon may be engaging in "dynamic pricing", based on my buying history, zip code, etc. I may be getting a different price than others. I wish I had taken a screenshot of the Amazon X700 page a few days ago, so people don't think I've lost-my-everloving-mind. Crutchfield is still out-of-stock of the X700.
Sony UBP-X700U (Amazon)
Log out of your Amazon account. Completely clear all related cache and cookies. Then log back in. You will find a lot of prices that change for the better. It doesn't affect everything, but it does affect all sorts of odds and ends of their marketing.
Edited to add: the things you are looking at cannot be in your saved lists or saved for later. They track those differently.
Initial impressions of the X700: nothing scientific here, but a few subjective takes on my new X700 that I picked up a few days ago. It’s connected to my Marantz Cinema60 via HDMI (8K cable) that drives my 5.1 home theater. Television: Sony Bravia XR-48A90K OLED; Speakers: Wharfedale 5.2 EVO front/center; Wharfedale 12.1 Diamond surrounds; SVS SB-1000 sub. Speaker settings configured with Odyssey room calibration.
X700 Settings: 4K upscaling turned off, so that my Sony OLED does 4K upscaling. All other settings left to factory default. My first two tests are with old media: DVD and DVD-Audio (unsupported by X700).
DVD Performance: For Halloween, I’m going with one of my scary favs, Darkness (2002) DVD starring Anna Paquin. For DVD upscaling, the X700 upscales from 480p to 1080p. With 4K upscaling turned off, the player then sends a 1080p signal to my Sony OLED, which upscales from 1080p to 4K. I start Darkness and get jaw-dropping, gorgeous video. A DVD can’t possibly look like this. Razor sharp image with vibrant colors and deep, deep blacks. Absolutely no grain. The Marantz automatically picks up the Dolby Digital 5.1 signal. Excellent surround performance with rumbling thunder from both surrounds. My only complaint is muddy dialog (pretty sure this is a disc issue), so I bump my center channel from +3 to +6 and turn on Marantz “Dialog Enchancement”. Overall an amazing performance, Grade = A+.
DVD-Audio performance. The X700 doesn’t natively support this format and I have a few DVD-Audio discs. I throw in my Fleetwood Mac Rumours DVD-A to see what happens. Playback goes to Dolby Digital 5.1 and the disc artwork is displayed on the screen. Overall impression—I’m not getting the instrument separation that I got with my Panasonic DMP-BD35, which supports DVD-Audio. Nevertheless, I always hear something new when listening to a 5.1 mix. In Lindsey Buckingham’s beautifully acoustic "Never Going Back Again", the first verse is followed by a steel guitar that overlays Buckingham’s acoustic guitar. I check the album credits, no steel guitar listed. I’m guessing that was Christine McVie’s synthesizer emulating a steel guitar. (Note: If you pick up Rumours in any format, make sure you get a version that includes Stevie Nicks "Silver Springs", a beautiful ballad--incredibly omitted in some album versions). Overall the X700 provided an immersive, enjoyable listening experience of a '70s masterpiece. As stated in NTTY’s review here, the X700 transport is ghostly quiet. Grade = B+
I'll try to post again with different use cases with the X700.
Try playing SACDs
Thank you for you, based on that excellent review
Hello Everyone,
This is a review and measurements of the Sony UBP-X700/K, Blu-ray, DVD, SACD, and CD Transport.
Sony UBP-X700/K - Presentation
This is a universal Transport meaning that it does not have internal DACs. I got it for around $300, which is a reasonable price considering all the formats it can play.
Note, though, that it will not play DVD Audio, for those of you who still have some.
As you can see, this unit is very simple. It is not a desktop product and the foot print is 320 x 45 x 217 mm (12 3/5 x 1 4/5 x 8 1/2 in.) for 1.4kg (3Lbs 9 / 10 Oz). Please refer to Sony's website to know more about all specs.
The front is very simple, and when powered on, it displays nothing, meaning a TV is mandatory to setup but also use it.
As a transport, the back is equally simple:
We get 2 HDMI outputs (one dedicated audio for backward compatibility, if I understood) and one Coax output (SPDIF).
User Experience
This one is fast at skipping one (CD/SACD) track but relatively slow at multiple and impossible to know where you are unless the TV is turned on to display the actual track... FFW/REW are available but skipping 16sec at once, and the audio output is disabled in that, so there’s no audible feedback of the progress (annoying) again forcing to rely on an external display.
The drive is totally silent when playing a CD which I think is really nice for a universal transport. It does not spin stupidly fast and if it does, well it is super silent!
It will not “circle” from last track to first one and displays “This operation is currently prohibited for this disc”. Pressing Stop button will not resume to track 1 but exactly where it was. Since there's no pad on the remote to go direct to a track, it can be painful to go from the last to the first track.
You know me, I love my CD Players/Transports, and I'll be focusing a lot on that feature. I leave the video ones to those of you who know much more than me.
Never a Sony Player disappointed me, and it won't start with this one. And I know you want to know asap, it is gapless playback! :) It also applies de-emphasis on Audio CDs that require it, in digital domain (more about that later). This is a proper CD Transport, thank you Sony!
Sony UBP-X700/K - Measurements (CD Transport)
Yeah, that's the primary reason for my review, to know if it can play the CDA as we want to, replying to the question: Is it "bit perfect". We have reasons to doubt that because as a video player with HDMI output, it is mandatory to output max 16bits/48kHz from the coax output (because it does not offer copy protection security). And some brands go the easy route of processing that output via an ARSC, without bypass even when the signal is originally 16bits PCM. That could cause distortion.
All measurements performed with a Motu UltraLite Mk5 for digital output.
First things first, it outputs 16bits/44.1kHz when playing a CDA, this is a good start.
Let's start with my standard 999.91Hz sine @0dBFS, without dither:
The above is exactly the WAV that I used to create the CD, so I can’t see any modification here.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
No surprises that I can't see any trace of digital modification here. This is the expected perfect 3DC test.
My ultimate proof of "perfect" digital output is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent (by an ASRC for instance), it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distorsion. So here we go:
We get the over, as expected, no distortion, no added noise, and so meaning perfect digital output on my perspective.
And for the fun, but also as a reference, let me share a little more than usual, so you get to see what the CDA is capable of.
The below is our beloved Multitone test:
This is more than 19bits distortion-free range, because there's no distorsion in digital domain, besides the quantization noise.
The Jitter test is nailed:
There's absolutely no trace of jitter, again this is the same as the original file, we can very clearly see the stressor, that 1 negative LSB square wave (for more info on that, I encourage you to read the SMSL PO100 Pro review).
Bandwidth is almost flat, as I got an interesting little attenuation of -0.04dB at 20Hz. I suspect this is a software limitation or the way the file was created. I'll keep that in mind for future testings:
The two channels are shown and perfectly overlay, of course.
I like to show the THD (only) vs Frequency at -12dBFS:
This is what REW can report at best, from that test file it created. Again the two channels are overlaid, and we see only one trace.
Other measurements (not shown), to use as a reference of what the CDA can achieve (and REW too):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -126.5dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -126.5dB
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -120.3dB
  • IMD DIN (250Hz & 8kHz 4:1) : -110.9dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -126.1dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -111.4dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -132.4dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -135.7dB
  • Dynamic Range : 98.9dB (without dither @-60dBFS)
  • Crosstalk: not measurable (below 139dBr limited by quantization noise and FFT gain)
  • Pitch Error : 19'997.00Hz (19'997.00Hz requested) ie below 0.5ppm (I should say not measurable)
  • Gapless playback : Yes!!!
The above can serve as a reference for any CD Players with integrated DAC to see if they can replicate the above .
I always add a "max DAC resolution" measurement test, when I review a CD Player. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Of course the Sony replicates the max digitally possible, because its SPDIF output is unaltered, so it is at the top of my ranking chart:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
Sony UBP-X700/K18.7bits100%
SMSL PL200 MKII18.7bits100%
SMSL PL20018.7bits100%
OPPO BDP-9518.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Denon DCD-900NE18.5bits98.93%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
Appreciate again the good old Oppo that achieved the best too here, a while ago, and from analog outputs!
Sony UBP-X700/K - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)3mm
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmPass
Successive dropoutsFrom 2x0.1mm to 2x3mmPass
Almost best in class! It will read CDs with holes into them :p It's not a first that I see from universal drives, but it is to appreciate. The Sony will read very heavily scratched CDs.
Sony UBP-X700/K - USB drive input (24bits PCM)
I briefly tested the USB input with 24bits PCM files I created. I did not keep many just because I saw the same at the output of the Coax as the WAV files I put on the USB drive.
The below is the 1kHz sine @0dBFS with dither, WAV directly analyzed vs the same played by the Sony and captured at the Coax output:
The difference between the two is run to run differences due to the dither noise I added, which varies over time (because random).
I kept also the jitter test at 24bits/48kHz:
Again, this is the original WAV file, it does not add jitter when processing it. Note the scale that goes down to -190dBr :cool:
Basically, you can trust this Sony to replay perfectly all files you put on a USB stick.
Sony UBP-X700/K - SACD measurements
Well, I kind of teased you, but I can't test that. Only the HDMI will output DSD from a SACD disc. The coax is restricted to 16bits/44.1kHz PCM, unfortunately, as per the rules of Sony.
That said let me give it a try, using the Denon test SACD. It has a 1kHz sine @-16dBSACD, yes not dBFS, but dBSACD. The booklet of the Denon disc says that this -16dBSACD test tone is aligned with -16dBFS, but when I play it via the Sony, it outputs a -19dBFS sine, meaning Sony adds a little headroom. I think this is a very good idea since the SACD can go over 0dBSACD, but not the CDA (well not without generating lots of distorsion). So, here we go:
I kept the scale in dBFS, not dBr, as to show the -19dBFS level. Are you afraid of the mess at low level? Don't be, this is an effect of the quantization noise, rounding errors. This is a not well chosen 1kHz test tone that generates only a few unique subframe codes. These generate recurring rounding errors showing that way of grass. The lower the signal, the more the rouding errors are high compared to the fundamental, increasing the digital distortion. With a 997Hz test tone, it would have been much better. I suspect Sony did not add dither for that conversion from DSD to PCM and they should have, else there's another reason that escapes me.
To better illustrate what I said about quantization errors, let me overlay to the above a 1kHz @-19dBFS without dither, from a PCM 16bits/44.1kHz:
As you can see, the rounding errors accumulate a little more with the file I created directly at -19dBFS. I'm surprised Sony did not use dither, but hey, not a big deal. Again, that 1kHz test tone is not reflecting well reality as it artificially accumulates rounding errors. So, let me use my standard 999.91Hz test tone, again @-19dBFS, no dither:
As you can see, the rounding errors are less because there are much more unique PCM subcodes. So, maybe Sony was right not using dither?
Sony UBP-X700/K - CDA De-emphasis Final note
I kept the best for the end (my perspective).
Since this is a Sony, and Sony being co-inventors of the Audio CD, they could not do anything else but respect their red-book. I already mentioned it is gapless playback (of course it is!!!), but it also applies de-emphasis in digital domain, so that when you'll connect it to a modern DAC that does not know what de-emphasis is (such as the latest ESS DACs, shame!), it will still be properly decoded. Nice.
The below is a sweep with and without pre-emphasis which allows me to verify the potential deviation of the decoding (via a DAC that has no clue of what is de-emphasis):
The Sony applies the exact desired correction, no surprise, but still happy yeah!
Conclusion
From this long review, you can tell I had fun with the Sony UBP-X700/K.
This is a Sony, and as such it is text-book CD Transport. I am so happy to witness and report that. Some say Sony stopped doing CD players... really? :)
This little and non expensive universal transport can play much more than just CDA, and it does it very well too. I could not find any flaws, on measurements perspective.
As usual, and it's been the same for 40+ years, well done Sony. Never you had one wrong. I'm impressed.
I hope you enjoyed this review and I wish you a nice weekend!
Flo
Thank you so much for your hard work and review!
Based on your analysis I just purchased one from WalMart as a backup to my OPPO UDP-205 in the event that it dies on me in the future.
Having a + 3000 collection of 4K Blu Ray movies and concerts and +400 Multichannel SACDs, I am concerned about Sony dropping out of the market of physical media!
I am not willing to spend two or three thousand dollars on a Magnetar that is no better than the Sony when using it as a transport, while letting my processor do all the heavy lifting!
I'm curious why you did not purchase one of the Panasonic models (e.g., UB820K) instead, given the size of your collection.
My concern on the Sony UBP-X700/K is that I've read it will occasionally have trouble reading the highest density 4K Blu-ray disks. Also, that you need to manually change it to Dolby Vision and then back again based on what you are playing.
Panasonic players have gone up considerably in price. I have a watched triple layered BD100 discs on my X700 and X800-M2 and never had one freeze. I don't think it is a given they will freeze on every Sony. The Dolby Vision thing is the annoying though a minor inconvenience. I've heard of people having freezing issues on Panasonic players as well though it does seem to be rarer. I wonder if it is a slight calibration issue from the factory or the laser going slightly out of calibration over time that causes it. I did have a UHD freeze on my Series X four or five years ago before I bought stand alones and it was repeatable so I know how frustrating that behavior can be from a player.
I already have a Panasonic 9000, I needed a player that supports SACD multichannel as I have over 400 SACD and 95% of them are multichannel 5.1.
If only Panasonic would support SACD!
Interesting. So am I correct?
  • SACD: Panasonic DP-UB820-K = No. Sony UBP-X700/K = Yes.
  • DVD Audio: Panasonic DP-UB820-K = No. Sony UBP-X700/K = No.
Edited: did a quick search to realize the Panasonic comes up negative for both formats.
