Sony UBP-X700/K Review (Blu-ray/DVD/SACD/CD Transport) (NTTY)
Rate this universal transport
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 2 2.2%
  • Good (***)
    Votes: 9 9.9%
  • Excellent (****)
    Votes: 80 87.9%
NTTY
Reviewer
Switzerland
Hello Everyone,
This is a review and measurements of the Sony UBP-X700/K, Blu-ray, DVD, SACD, and CD Transport.
Sony UBP-X700/K - Presentation
This is a universal Transport meaning that it does not have internal DACs. I got it for around $300, which is a reasonable price considering all the formats it can play.
Note, though, that it will not play DVD Audio, for those of you who still have some.
As you can see, this unit is very simple. It is not a desktop product and the foot print is 320 x 45 x 217 mm (12 3/5 x 1 4/5 x 8 1/2 in.) for 1.4kg (3Lbs 9 / 10 Oz). Please refer to Sony's website to know more about all specs.
The front is very simple, and when powered on, it displays nothing, meaning a TV is mandatory to setup but also use it.
As a transport, the back is equally simple:
We get 2 HDMI outputs (one dedicated audio for backward compatibility, if I understood) and one Coax output (SPDIF).
User Experience
This one is fast at skipping one (CD/SACD) track but relatively slow at multiple and impossible to know where you are unless the TV is turned on to display the actual track... FFW/REW are available but skipping 16sec at once, and the audio output is disabled in that, so there’s no audible feedback of the progress (annoying) again forcing to rely on an external display.
The drive is totally silent when playing a CD which I think is really nice for a universal transport. It does not spin stupidly fast and if it does, well it is super silent!
It will not “circle” from last track to first one and displays “This operation is currently prohibited for this disc”. Pressing Stop button will not resume to track 1 but exactly where it was. Since there's no pad on the remote to go direct to a track, it can be painful to go from the last to the first track.
You know me, I love my CD Players/Transports, and I'll be focusing a lot on that feature. I leave the video ones to those of you who know much more than me.
Never a Sony Player disappointed me, and it won't start with this one. And I know you want to know asap, it is gapless playback! :) It also applies de-emphasis on Audio CDs that require it, in digital domain (more about that later). This is a proper CD Transport, thank you Sony!
Sony UBP-X700/K - Measurements (CD Transport)
Yeah, that's the primary reason for my review, to know if it can play the CDA as we want to, replying to the question: Is it "bit perfect". We have reasons to doubt that because as a video player with HDMI output, it is mandatory to output max 16bits/48kHz from the coax output (because it does not offer copy protection security). And some brands go the easy route of processing that output via an ARSC, without bypass even when the signal is originally 16bits PCM. That could cause distortion.
All measurements performed with a Motu UltraLite Mk5 for digital output.
First things first, it outputs 16bits/44.1kHz when playing a CDA, this is a good start.
Let's start with my standard 999.91Hz sine @0dBFS, without dither:
The above is exactly the WAV that I used to create the CD, so I can’t see any modification here.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
No surprises that I can't see any trace of digital modification here. This is the expected perfect 3DC test.
My ultimate proof of "perfect" digital output is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent (by an ASRC for instance), it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distorsion. So here we go:
We get the over, as expected, no distortion, no added noise, and so meaning perfect digital output on my perspective.
And for the fun, but also as a reference, let me share a little more than usual, so you get to see what the CDA is capable of.
The below is our beloved Multitone test:
This is more than 19bits distortion-free range, because there's no distorsion in digital domain, besides the quantization noise.
The Jitter test is nailed:
There's absolutely no trace of jitter, again this is the same as the original file, we can very clearly see the stressor, that 1 negative LSB square wave (for more info on that, I encourage you to read the SMSL PO100 Pro review).
Bandwidth is almost flat, as I got an interesting little attenuation of -0.04dB at 20Hz. I suspect this is a software limitation or the way the file was created. I'll keep that in mind for future testings:
The two channels are shown and perfectly overlay, of course.
I like to show the THD (only) vs Frequency at -12dBFS:
This is what REW can report at best, from that test file it created. Again the two channels are overlaid, and we see only one trace.
Other measurements (not shown), to use as a reference of what the CDA can achieve (and REW too):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -126.5dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -126.5dB
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -120.3dB
  • IMD DIN (250Hz & 8kHz 4:1) : -110.9dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -126.1dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -111.4dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -132.4dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -135.7dB
  • Dynamic Range : 98.9dB (without dither @-60dBFS)
  • Crosstalk: not measurable (below 139dBr limited by quantization noise and FFT gain)
  • Pitch Error : 19'997.00Hz (19'997.00Hz requested) ie below 0.5ppm (I should say not measurable)
  • Gapless playback : Yes!!!
The above can serve as a reference for any CD Players with integrated DAC to see if they can replicate the above .
I always add a "max DAC resolution" measurement test, when I review a CD Player. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Of course the Sony replicates the max digitally possible, because its SPDIF output is unaltered, so it is at the top of my ranking chart:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
Sony UBP-X700/K18.7bits100%
SMSL PL200 MKII18.7bits100%
SMSL PL20018.7bits100%
OPPO BDP-9518.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Denon DCD-900NE18.5bits98.93%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
Appreciate again the good old Oppo that achieved the best too here, a while ago, and from analog outputs!
Sony UBP-X700/K - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)3mm
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmPass
Successive dropoutsFrom 2x0.1mm to 2x3mmPass
Almost best in class! It will read CDs with holes into them :p It's not a first that I see from universal drives, but it is to appreciate. The Sony will read very heavily scratched CDs.
Sony UBP-X700/K - USB drive input (24bits PCM)
I briefly tested the USB input with 24bits PCM files I created. I did not keep many just because I saw the same at the output of the Coax as the WAV files I put on the USB drive.
The below is the 1kHz sine @0dBFS with dither, WAV directly analyzed vs the same played by the Sony and captured at the Coax output:
The difference between the two is run to run differences due to the dither noise I added, which varies over time (because random).
I kept also the jitter test at 24bits/48kHz:
Again, this is the original WAV file, it does not add jitter when processing it. Note the scale that goes down to -190dBr :cool:
Basically, you can trust this Sony to replay perfectly all files you put on a USB stick.
Sony UBP-X700/K - SACD measurements
Well, I kind of teased you, but I can't test that. Only the HDMI will output DSD from a SACD disc. The coax is restricted to 16bits/44.1kHz PCM, unfortunately, as per the rules of Sony.
That said let me give it a try, using the Denon test SACD. It has a 1kHz sine @-16dBSACD, yes not dBFS, but dBSACD. The booklet of the Denon disc says that this -16dBSACD test tone is aligned with -16dBFS, but when I play it via the Sony, it outputs a -19dBFS sine, meaning Sony adds a little headroom. I think this is a very good idea since the SACD can go over 0dBSACD, but not the CDA (well not without generating lots of distorsion). So, here we go:
I kept the scale in dBFS, not dBr, as to show the -19dBFS level. Are you afraid of the mess at low level? Don't be, this is an effect of the quantization noise, rounding errors. This is a not well chosen 1kHz test tone that generates only a few unique subframe codes. These generate recurring rounding errors showing that way of grass. The lower the signal, the more the rouding errors are high compared to the fundamental, increasing the digital distortion. With a 997Hz test tone, it would have been much better. I suspect Sony did not add dither for that conversion from DSD to PCM and they should have, else there's another reason that escapes me.
To better illustrate what I said about quantization errors, let me overlay to the above a 1kHz @-19dBFS without dither, from a PCM 16bits/44.1kHz:
As you can see, the rounding errors accumulate a little more with the file I created directly at -19dBFS. I'm surprised Sony did not use dither, but hey, not a big deal. Again, that 1kHz test tone is not reflecting well reality as it artificially accumulates rounding errors. So, let me use my standard 999.91Hz test tone, again @-19dBFS, no dither:
As you can see, the rounding errors are less because there are much more unique PCM subcodes. So, maybe Sony was right not using dither?
Sony UBP-X700/K - CDA De-emphasis Final note
I kept the best for the end (my perspective).
Since this is a Sony, and Sony being co-inventors of the Audio CD, they could not do anything else but respect their red-book. I already mentioned it is gapless playback (of course it is!!!), but it also applies de-emphasis in digital domain, so that when you'll connect it to a modern DAC that does not know what de-emphasis is (such as the latest ESS DACs, shame!), it will still be properly decoded. Nice.
The below is a sweep with and without pre-emphasis which allows me to verify the potential deviation of the decoding (via a DAC that has no clue of what is de-emphasis):
The Sony applies the exact desired correction, no surprise, but still happy yeah!
Conclusion
From this long review, you can tell I had fun with the Sony UBP-X700/K.
This is a Sony, and as such it is text-book CD Transport. I am so happy to witness and report that. Some say Sony stopped doing CD players... really? :)
This little and non expensive universal transport can play much more than just CDA, and it does it very well too. I could not find any flaws, on measurements perspective.
As usual, and it's been the same for 40+ years, well done Sony. Never you had one wrong. I'm impressed.
I hope you enjoyed this review and I wish you a nice weekend!
Flo
Stunning work as always. :cool:
Would be cool if you could also measure this (most likely BS) tweaked version:
Hello Everyone,
User Experience
This one is fast at skipping one (CD/SACD) track but relatively slow at multiple and impossible to know where you are unless the TV is turned on to display the actual track... FFW/REW are available but skipping 16sec at once, and the audio output is disabled in that, so there’s audible feedback of the progress (annoying) again forcing to rely on an external display.
Conclusion
Flo
Excellent work, as usual! :)
Just one thing:
"and the audio output is disabled in that, so there’s audible feedback of the progress (annoying) again forcing to rely on an external display."
This should be:
"and the audio output is disabled in that, so there’s no audible feedback of the progress (annoying) again forcing to rely on an external display."
A simple mistake I'm sure!
Oh no :facepalm:
Twice the price, and 2 hours of swapping components for nothing. Shame.
BS as you said, what can be improved when the digital output is perfect?
"The kit's price of €499 is quite reasonable for the expected results, especially considering the Sony player, which costs €249."
I must have slipped into the audiophool parallel universe if €499 for this kit is deemed "quite reasonable"!
Some of them think that a multi-thousands bucks power strip is "reasonable" considering the "improvements"...
Flo did this before with another 'tuned' item, just to know ... his work can be more than highly appreciated!
Hai Flo, great review as ever.Thanks a lot.
I bought 2 Sony's 800m2 and with your experience it's safe to say that they will perform the same as even better?
Have a great weekend, greetings from Jaap
Great work once again. I've seen x800 recommended as a CD-player for quiet mechanics. I guess this is probably in the similar ballpark
It depends on what is expected (and how eagerly).
To me it's a solution without a problem. It appears to be well made though, and in that respect I can see the appeal for some users. Perhaps they could send a completed unit in for NTTY to review? If the Chassis DIY-X700 upgrade kit does as R_volution claims it does, then it would get plenty of exposure for very little cost.
Look at the claims they make:
"Thanks to its high-quality internal power supply specifically calibrated for digital audio and video transport, the R_volution Chassis DIY-X700 offers breathtaking image quality, deep blacks, vibrant colors, exceptional image sharpness and extremely dynamic digital multi-channel sound quality and precision with a wide dynamic range."
"The R_volution Chassis DIY-X700 features a high-performance power supply equipped with a Toshiba linear voltage regulator and powered by a massive 81W oxygen-free copper toroidal transformer, ensuring a noise-free signal for enhanced image quality, more accurate color grading, deeper blacks, and superior audio and visual precision."
With such confidence in their product, I'm surprised to see precisely zero oscilloscope or audio analyzer test results on their website for potential buyers to refer to. That speaks volumes, and I strongly suspect that if they did provide test results, then they would show no measurable or meaningful differences in the output data streams, etc.
To each their own! :)
Hello Everyone,
This is a universal Transport meaning that it does not have internal DACs. As you can see, this unit is very simple. It is not a desktop product
While this player does not have the typical dimensions of a "desktop" component, I would definitely consider purchasing it to connect to a 32" (or larger) 4K desktop monitor for watching Blu-ray movies, and routing the digital audio output through a DAC/Headphone Amp connected to a pair of high-quality actively powered desktop speakers or headphones for listening to CDs, SACDs, and movie soundtracks. (And of course, this model would perform admirably in a home theater system.) In the U.S. the Sony UBP-X700U is retailing for$328, which makes it one of the least expensive new SACD players on the market, and if you happen to have any vintage CDs from the '80s, this model will automitically apply the de-emphasis those discs may need. I'd say the major shortcoming of the Sony UBP-X700U is its complete lack of display (and even when it is connected to a screen it shows only the most rudimentaray program information of CD track number and elapsed time). But I think its bit-perfect performance and versatility as an all-purpose Blu-ray player/CD transport make it a useful, reasonably priced unit. I'm glad to see that Sony is still dedicated to producing transports that uphold the highest standard of accuracy. (I just wish Sony hadn't discontinued their UBP-X800M2 Blu-ray player, which is a better-built model...)
Thanks for another excellent review! ☑
They can copy paste the data from this website now, showing a perfect cd player.
I purchased two of this unit's big brother, the UBP X800M2, several years ago. They have performed flawlessly, including SACD output via the HDMI-2 (audio) port intended for AV receivers.
I cheated: I purchased a DoP (DSD over PCM) box off eBay for $89 and connected it's output to my topping DAC. Also works flawlessly.
UBP X800M2 HDMI-2 out -> DoP out -> D90 III discrete I²S in
Thank you for the excellent review. I have had the X800M2 for a few years as a workhorse for movies and all the audio formats it supports. Picked up a used X700 at a thrift store for $10 and have been just as impressed with it. Good to see this confirmation of its ability as an audio transport.
Ironically, I just sold the 800 a few days ago. It had promise as a great player, but it kept freezing on 4K discs to the point it became too annoying to work through (hard power cycle to clear the error.) I replaced it with a Panasonic and no problems since. I'm sure the 800 would have been just fine if not for my affinity to 4K UHD media.
Ironically, I just sold the 800 a few days ago. It had promise as a great player, but it kept freezing on 4K discs to the point it became too expensive to work through. I replaced it with a Panasonic and no problems since. I'm sure the 800 would have been just fine if not for my affinity to 4K UHD media.
I don't have but about 2 dozen 4K discs; and one of my two X800M2 units is only used for audio. But the one connected to my 4K monitor has never exhibited that problem.
Interesting, can you please point me to that DoP box? I’d love to be able testing HDMI output, even if that implies PCM conversion of DSD. I’d be interested to know the performances.
