respice finem
- Joined
- Feb 1, 2021
- Messages
- 2,949
- Likes
- 5,506
Just my two cents: What may be acceptable in a 400 $ AVR, is not acceptable in one costing 10 times as much.
Now I have 2 Yamahas and both are very musical, and "Sound" quite good to me.
I think there is a bit of a expectation bias with some measurements, and many have not even heard an AVR, to make a qualified judgment on the audibility.
Do you really think that would matter? Not a chance.Amir I have a complaint.
Why did you not update to the latest firmware, even if the release notes are minor?
Same for me. After owning AVR's from 1997 to 2022, I went back to stereo.One of the little annoyances that made me revert to stereo.
Please wait for the next customer assistant!I have a complaint.
I am in the midst of a major redo of my lab. The ethernet plug is buried behind cabinet. I tried to get wifi working on it but would not.Amir I have a complaint.
Either way, it sounds like a firmware issue.But it can't be the entire system because it was shown to work well with HDMI as long as the volume wasn't near max.
What was shown is that analog pure direct is bugged, and HDMI pure direct is bugged (buggered?) as well.
It was around that time... but would need to research the timeline... gut feeling says it was during the early post Harman buy out period - when most of their range was still the true Lexicon stuff, but Harman influences were coming in.Was the buy-out before or after they got caught sticking a much cheaper Oppo player in a pretty case?
I think a product should be tested in it's best version, with the most recent updates. It removes questions about the current state, and removes another variable.Do you really think that would matter? Not a chance.
The LexiCON occurred post-Harman. They dropped an Oppo BDP-83 into a fancier case, put a blue filter over the display, substituted Lexicon for all references to Oppo in the GUI, and jacked up the price by $3000. There is a little more to the story—evidently, Oppo did work with Lexicon engineers to address issues they found during testing. See here:Was the buy-out before or after they got caught sticking a much cheaper Oppo player in a pretty case?
Of course this is correct. Several years ago I bought what I only later learned was a truly sub-par AVR (NAD 758) based on features, subjective reviews, and brand reputation -- the way most people do. I wasn't aware of this website then. (And to be fair, the NAD's Dirac Live is such a useful feature that it partially rescues the purchase.)Im not defending mediocre measurements, but do you ever ponder WHY most AVRs measure this way?
Some will claim cost savings, which could be part of it?
Or have they determined going better results in no more actual sells, and the 90% of customers would not audibly hear a difference?
Simply saying they measure not so great over and over will not determine the how, what why and where of this.
I have read on other forums, where some believe, the complexity of many components internally interfere with each other, and if separated, they would behave differently, but have no concrete evidence of this.
Time . I would guess. Plus if the details say it's only minor alterations than that is all it should be - and irrelevant. If not that's Sony's problem...Amir I have a complaint.
Your comment seems mostly for dramatic effect.Thank you Amir for the measurements
Never been a fan of "home theater" thing nor understood it honestly but from what I can gather from my friends that are into that these kind of results are not that bad considering state of the AVR game. It just IS THIS BAD across the board more or less. But then again considering how many bad STEREO amps are out there making a great 5 or 10 channel amp together with processing requirements is likely much harder than many of us think. At least for SANE money that is
Not all AVRs are made the same. In this price range look up Marantz C30 or Denon 6800H that perform well. As noted, lower SINAD is generally acceptable for AVRs as you do have multiple channels and focus is not the same as for 2 channel audio, plus most soundtracks are not really that great to start with. Not excuse and AVRs should still be judged on merits of their performance.Steer clear of AVRs. There must be a reason they cannot put together a DAC, a preamp section and an amplifier without messing up, but I wonder why. Is it because new gen do not listen to high quality sources, so even a failed design does have a market? Yes, this Sony sounds better than the iPhone or the BT boombox playing MP3s. Hardly a good investment though, considering that for the same $ I could set up an SMSL PL200, an Hypex Nilai 500 and a decent set of stereo speakers with some money to buy CDs. It is time for a willing company to review the whole blueprints for AVRs and come out with something worthwhile. Thank you Amir for showing beyond doubt why you shouldn’t trust brand names anymore.
