Sony STR-AZ7000ES AVR Review
Rate this AVR:
    Votes: 139 76.4%
    Votes: 35 19.2%
    Votes: 2 1.1%
    Votes: 6 3.3%
This is a review and detailed measurements of the Sony STR-AZ7000ES Audio/Video Home Theater Receiver. It is on kind loan from a member and costs US $4,199.
The unit was easy to navigate through front panel controls (didn't use the remote). Can't say the same about transporting it as weighs a ton! OK, it is 48 pounds but for me, that is heavy. So much that I could not bear rotating it to show a picture of the back side. Here is the stock image:
I focused my testing on Front Left and Right channels. Used the pre-out for DAC measurements and speaker terminals for the amplifier. I reset the unit to factory. Firmware revision was 1.44 I think with the latest being a couple minor ones later.
Sony STR-AZ7000ES Measurements
I connected using HDMI and tried to set the output to 2 volt. I say "try" as there seemed to be a ghost in the machine. I would set the output to 2 volt, only to have it drop down. I would turn up the volume, and the cycle would repeat. I power cycled and this got me closer to the first setting but then the cycle started again. I quickly grabbed a snapshot:
This ranks the Sony in our poor category:
I went to run the frequency response, only to fail at that for the same reason:
Sony STR-AZ7000ES Home Theater AV Receiver AVR pre-out frequency response bug level measurements.png
I ran one more test and then gave up on the DAC testing:
Sony STR-AZ7000ES Home Theater AV Receiver AVR pre-out THd vs Level measurements.png
There is a glitch visible around 0.7 volt which is likely due to same level shifting.
I tested the amplifier with analog CD input and same problem existed. I switched to HDMI, and strangely and fortunately, it resolved the problem! So here is that dashboard:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI measurements.png
The amplifier is good for the class:
Good and very good is the adjective for the rest of the tests:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI SNR measurements.png
It was strange to not see higher than 98 dB SNR. Usually that scales a lot more with output power (really voltage).
We are dealing with class AB amp so no load dependency:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI Frequency Response measurements.png
Intermodulation results are very good:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI 19 20 kHz intermodulation distor...png
This is a powerful amplifier when driven in stereo:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI Power 4 ohm measurements.png
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI Power 8 ohm measurements.png
Yet another very strange response:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI max and peak power measurements.png
How could a sine impulse on the right produce so little power? Some kind of amplifier limiter protection setting in? I repeated that test and regardless of volume control setting, it would just show that 3.5 watts.
The transfer function is very unique:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI Power 4 ohm vs frequency measure...png
Distortion at higher frequencies sets in very early. And noise floor increases at 15 kHz+.
Finally, there is likely an audible pop on power off:
Sony STR-AZ7000ES Home Theater AV Receiver AVR Amplifier HDMI Power on off noise pop measureme...png
Power on also exceeds my 1 mv target.
There are some serious bugs in this Sony. And they are the type that require instrumentation to find so likely poor owners don't know about them. The last Sony ES AVR did well. I don't know how the company has gone backwards and introducing such odd behavior.
The only bright light is the amplifier. Oh wait, it too had that odd peak response. :(
I can't recommend the Sony STR-AZ7000ES AVR. You will break your back getting it inside your home, and then again back out should you discover what I found.
Reserved for @RickS to kindly post the specs.
Specifications
AUDIO POWER SPECIFICATIONS
POWER OUTPUT AND TOTAL HARMONIC DISTORTION
(USA Models Only):
STR-AZ7000ES
With 8 Ω loads, both channels driven, from 20 Hz – 20 000 Hz; rated
140 W per channel minimum RMS power in stereo mode, with no more
than 0.09% total harmonic distortion from 250 mW to rated output.
Amplifier section1)2)
STR-AZ7000ES
Rated Power Output at Stereo Mode
(8 ohms, 20 Hz – 20 kHz, THD 0.09%): 140 W + 140 W
Reference Power Output
(8 ohms, 1 kHz, THD 0.9%)
FRONT: 150 W + 150 W
CENTER: 150 W
SURROUND: 150 W + 150 W
SURROUND BACK: 150 W + 150 W
HEIGHT 1: 150 W + 150 W
HEIGHT 2: 150 W + 150 W
HEIGHT 3: 150 W + 150 W
Dimensions (width/height/depth) (Approx.)
430 mm × 194 mm × 440 mm (17 in × 7 3/4 in × 17 3/8 in) including
projecting parts and controls
Mass (Approx.)
STR-AZ7000ES: 21.8 kg (48 lb)
Please see Sony website for more information.
Thanks for the testing on this Amir and to the member for sending same. A shame it's a bit of a fail...
Pics;
JSmith
The unit was easy to navigate through front panel controls (didn't use the remote). Can't say the same about transporting it as weighs a ton! OK, it is $48 pounds but for me, that is heavy. So much that I could not bear rotating it to show a picture of the back side. Here is the stock image:
Together with the other test - Amir's expensive AVR/AVP chainsaw massacre days are here :cool:
I guess I’ll stick with my STR-za5000es after all. Maybe these are firmware bugs which need to be ironed out. However, the az7000es has been out for a while so you would think the kinks would have been ironed out already.
Voted “not terrible” as the amplifier performance is pretty good while the DAC is a massive fail with these bugs.
Imagine paying upwards of $4k for this thing, putting on the weight belt, and shlepping it home from Best Buy, hooking it up and having the vague impression that everything up top seems a little dead and closed in. If you don't know how to run Amir's test, do you just live with this compromised level of performance? Or do you notice that when things hit a peak, everything just shuts down. Maybe that's the best feature of this thing. That peak output at least tells the naive buyer this thing is not performing up to snuff, necessitating he put the weight belt back on and take it to the "service desk" at Best Buy.
Thanks, again for the very fine review, Amir. Hope your back is ok.
The previous generation za5000es which I own is really f—-ing heavy too. Almost like moving a tube amp. These Sony’s have serious iron in them. I guess you can’t say they skimped on the power transformer!
Would be nice to get a comment / feedback from Sony....
It looks like it might have decent core circuitry, which is being sabotaged by something in the firmware
Seems like AVR's continue to be the weak link in audio.
And, interestingly, even the "big name" manufacturers don't seem to be able to do better.
Maybe until a less big name company comes and does better...
And that's why my Pioneer VSX-LX503 is for Dolby Surround and Atmos material only. I just use it as an AV processor and make its front left and right channels a "stereo source" on my more purist 2-channel system. All the other channels live on the AVR and are only called into duty when needed. During stereo listening, it's just a dormant audio-for-video "side chain."
Yeah I know what you mean in general, but specifically Denon seem to be able to, so in the case of this Sony and the recent Emotiva review it's coming down to lazy design;
Denon AVR-A1H
Denon AVR-X4800H
Denon AVR-X8500H
Denon AVR-X3700H
JSmith
Agreed
The Harman press release confirming the acquisition of Sound United mentioned Sound United would be a separate business unit within Harman.
I hope this means the person(s) at Harman who signed off on the performance of the JBL MA7100HP AVR will not be overseeing the design of future Denon-branded AVR's.
Lexicon did a very good job... then got bought out by Harman....
Is this one faulty? I expect better from Sony.
