The xover frequency is approximate, and the actual number is not really important here.I should note however, that this cap change was accompanied by changing the burned out tweeter. Replaced the burned out 6OHm with an 8Ohm, and then had to balance with a couple of wire wound cement ceramic resistors so the rest of the cross over saw the same X-over point - so I think the cap issues probably pale in comparison to the havoc I've wreaked there
I should note, the caps and tweeter were on the 'other' speaker (not the one I took the measurements from - outside of the full setup (third graph) which was both plus sub.
That's an interesting point - would it be possible from the circuit diagrams and the info I have to take an educated stab at the X-Over frequency as designed?
I didn't notice any swelling in the larger caps - can these degrade without showing external symptoms? Of course if i'm going to start buying better components to swap out - the bigger question would be is it worth it - or should i be investing in a better set of modern speakers.
If you have a dip, and you can not correct it by tilting the speaker a few degrees up or down, then change the 12uf cap on the bass filter to something like 10uf or a little less.
Tune by ear.
Just a little trick if the threads on the chipboard cabinet should come loose with repeated use.
Thin common wood glue a drop of water, use a straw to pickup a few drops and inject it into the holes, give it an hour or, put the screws in but do not tighten fully! leave it overnight, then tighten gently.
