(Continuation from message #1)
5. Special Tests
Here is a capture of the waveform of a 997 Hz sine at -90.31 dBFS without dither from NTTY Test CD:
The waveform is a bit noisy, but the three discrete voltage steps are clearly visible.
The Sony DAC is perfectly monotonic, i.e. increasing digital codes produce consistently increasing analogue outputs at the lowest levels. Most probably this characteristic is no longer difficult to get nowadays, but at least it let us see a pretty picture:
Non-monotonic DAC can also be revealed by another special test which was proposed by Audio Precision in 1991 to check the absence of modulation of the noise floor of D/A converters at different levels (Richard C. Cabot,
Noise Modulation in Digital Audio Equipment, AES preprint 3021). This test consists of accumulating on the same graph a third octave analysis of the quantization noise after the removal of a low frequency test signal at different levels from -50 to -100 dBFS. Any change on the shape of the noise floor would signal a modulation of this noise in function of level. Audio Precision quoted experiments previously conducted at Dolby Laboratories that had shown that noise modulation of as little as 2 dB may be audible. Nowadays, this test may have no longer relevance with modern D/A converters, especially sigma-delta converters, but maybe it can still be useful to check ladder type converters. In any case, here is this test performed on the Sony SCD-555ES as proposed by Audio Precision:
The noise floors at different levels overlap almost perfectly, save for small "blips" that look like there are not significant. It is enlightening to compared this graph with the noise in the audio band between 500 Hz to 20 kHz obtained with the same 3rd octave band pass filter when the DAC is fed with an "Infinity Zero" signal (see Part II, 2 above). The elevated noise that can be shown on the graph above compared to the graph in Part II, 2 is due to the fact that the noise coming from the digital processing adds to the noise of the analogue circuit of the player.
The noise modulation test can be performed in a more modern way by accumulating FFT spectra of the different test signal levels:
The noise generated by the different test signals overlap perfectly, confirming the absence of any noise modulation.
Finally, I used special dithered signals made by NTTY on the model of the Pierre Vérany Digital Test CD, which contains unique (non-dithered) tracks to perform a peculiar test called "intermodulation by crosstalk". The theory of operation of this test is as follows: the channel under test plays a 5 kHz tone and the other channel simultaneously plays a 1 kHz tone, both at 0 dBFS. If there is a significant crosstalk between channels, the 1 kHz tone can theoretically intermodulate with the 5 kHz tone to produce on the channel under test a difference frequency of 4 kHz and/or side-bands at 4 and 6 kHz due to amplitude modulation of the 5 kHz tone by the 1 kHz crosstalk tone. This test has been designed at a time when most CD players have only a single digital to analogue converter for two channels for cost-savings reason. These CD players had to demultiplexe the left channel from the right by routing the output of the single DAC alternatively to each one of the two channels at twice the CD sampling frequency.
I looked for the intermodulation product after I had the Audio Precision notched out the 5 kHz tone to increase resolution. I found nothing in the right to left direction, but in the left to right, I have found small 4 kHz and 6 kHz side-bands at about -120 dBr (after the attenuation of the notch filter has been compensated for):
The relevance of this measurement as an intermodulation distortion assessment is debatable, but a case can perhaps be made that it is in some way a more stringent crosstalk test than the one I performed and have shown the result above. In an usual crosstalk measurement, one channel only plays back some signal whereas the analyzed channel remains silent. In this case, many D/A converters may mute the channel under scrutiny. When the test signals designed for the Pierre Verany Digital Test CD are played back, on the contrary, both channels are very well alive because they have both a tone at maximum level to reproduce.
6. Disc Readability
To end the first part of this review dedicated to CD replay, I have used the famous Pierre Vérany Digital Test CD2 to check the ability of the Sony SCD-555ES to play damaged discs or disc pressings that are not compliant to the Red Book (RB) specifications. The criteria of failure on a test is either glitches, warping of the output waveform or an increase of THD+N from the nominal value. The last one is the most stringent: if it were relaxed, the player would have passed more test steps for it actually proceeds to produce a stable output with only moderate increase of THD+N on some tracks. As NTTY obviously uses the same disc to perform its own tests, I will borrow his table:
| Test Type | Variable parameter(s) | Results |
| Variation of linear cutting velocity | 1.4 then 1.2 to 1.4 m/s in 0.05 m/s steps | All tests passed |
| Combined variations of track pitch and velocity | From 1.2 m/s to 1.40 m/s combined with 1.5 µm & 1.7 µm pitch | All tests passed |
| Variation of track pitch | 1.5 µm to 1.7 µm in 0.05 µm steps | All tests passed |
| HF detection level | Variation of the pits/lands ratio from +2 to +18% | All tests passed |
| Drop-outs tests | 0.05 to 0.2 mm (RB spec.) and 0.3 to 4 mm (non-spec.) | All RB spec. tests passed - Pass to 1.25 mm Fails from 1.5 mm |
| Combined drop-out size variation & minimum track pitch | 1.5 µm + 1 to 2.4 mm | Pass to 1 mm Fails from 1.5 mm |
| Successive drop-outs | 2x0.1 mm to 2x3 mm | Pass to 2x1 mm Fails from 2x1.5 mm |
Part III: Measurements of the Sony SCD-555ES as an SACD Player
Measuring an SACD disc player presents two challenges.
The first is the lack of availability of proper test disc. Only two test SACDs designed to assess performance of disc players have ever been made by Sony and Philips and they have been out of print for a very long time. The only available SACDs with some more or less useful test signals that are procurable are designed to set up stereo or multichannel Hi-Fi systems, not to measure the performance of the DACs of disc players. Nevertheless, I will try to make good use of the test SACDs that are available.
The second is the high level of out-of-band noise generated by the sigma-delta modulation. This out of band noise may upset wide-band analogue audio analyzer. The Audio Precision System One does not escape this problem. Thus, the measurements I am able to perform are limited for now, but I will proceed to work on the challenge.
For this part, I can use only one test disc that has been designed mostly to set up multichannel audio systems but that also gets some stereo test tracks : the
Denon Audio Check SACD.
1. Frequency response
The Denon SACD has no 1 kHz or so sine tone at the nominal 0 dB SACD level, but it gets several sine signals at -16 dB SACD that are precisely aligned with the level of PCM sine signals at -16 dBFS. It is thus possible to calculate the nominal output level of the Sony by measuring the signals at -16 dB SACD and adding 16 dB to the measured level. The output is exactly the same (2.15 V
RMS) as with corresponding PCM sine signals and the channel matching is identical.
That means that the SCD-555ES is a perfect candidate to compare CDs and SACDs at matched levels if you are able to find music program materials that are mastered identically in both formats.
Due to the lack of 1 kHz sine at full 0 dB SACD level, I cannot show a "dashboard". All I can report is
measurements made elsewhere by a third party with an Audio Precision System Two and a proper SACD test disc that has revealed a very low harmonic distortion of (worst case) -115.4 dB (0.00017%), only made of the second and the third harmonics.
The frequency response has been checked with a glide tone signal from 5 Hz to 30 kHz at -20 dB SACD from the Denon disc:
You can see that the response is tailored exactly the same way as with CD replay (beware of the different horizontal scale on the above graph when comparing!). This confirms the fact that the frequency response is imposed by the player's analogue output low-pass filter. Again, this made the SCD-555ES a perfect player to compare CD and SACD editions of the same program material contrary, for example, to the
Pioneer DV-868AVi, which has both different output levels and frequency response between PCM mode and SACD mode.
It is possible to explore the response of the SCD-555ES much higher in frequency with the pink noise tracks of the Denon SACD. It is well known that a 1/3 octave analysis of pink noise should show a flat response. Let’s check that with the Audio Precision analogue band-pass filter:
Now that is interesting. The usable frequency response extends to somewhat 55 kHz with a gentle roll-off. From 55 kHz, the response flattens a bit: this is where the noise is no longer pink in nature: it is the shaped quantization noise typical of DSD that overcomes the pink noise. But the noise level quickly goes down following a regular slope. Compared to the Pioneer DV-868AVi I already
reviewed, the Sony SCD-555ES has much more effective combined digital and analogue low-pass filters. In fact,
I have measured more than 4 times less noise above 100 kHz with the Sony than with the Pioneer. The performance of the Sony is by design: its active analogue low-pass filter is one of the most potent I know of among disc players. It would be interesting to compare this performance with devices using modern D/A converters which rely more on digital low-pass filter and less on analogue filters for DSD replay.
Another way to view the pink noise, though in a more restricted bandwidth, is to make an FFT at the maximum sampling frequency the Audio Precision System One is capable of. Moreover, as the Denon Audio Check SACD pink noise tracks get signal on one channel only at a time, we are going to see what is actually on the muted channel:
As you can see, the pink noise effectively extends to 60 kHz before it is overcame by the shaped quantization noise. The most interesting thing is that the quantization noise is also visible on the muted channel (the fact that the HF noise of both channel doesn't overlap seems to be due to the Denon test disc). That means that the silence is actually an analogue mute signal and that the DAC of the player stays alive, as what happens with an "Infinity Zero" signal. This gives the opportunity to measure the true signal to noise ratio of the player thanks to this DSD analogue mute signal.
2. Noise measurements
To compute the signal to noise ratio, one must measure the noise floor in the audio band when playing an analogue mute track and refer the result to 0 dB SACD. Bear in mind though, that 0 dB SACD is not the maximum signal level that SACD is capable of:
as I have explained on another thread, the SACD audio specification allows short term peak excursions at +3.1 dB SACD.
Unfortunately, I encountered a strange behavior that makes me doubt the reliability of the System One analogue analyzer to measure audio band noise level of DSD signals. So, instead, we can have a look at the noise floor in the audio band with an FFT analysis, which works fine:
Compared to a similar measurement in the same bandwidth with a PCM "Infinity Zero" signal (not shown), we get a somewhat similar noise floor, except for a bit more low frequency mains interference and the small blips around 550 and 1,200 Hz in case of SACD replay. So, we can assume that, when DSD data is replayed, the SCD-555ES is capable of more or less the full signal to noise ratio measured with an "Infinity Zero" PCM signal, whereas of course the true SNR from CD data would be limited by the added quantization noise in the presence of any signals.
This ends the measurements I am able to perform in DSD for now.
I just want to add that this Sony SCD-555ES has been my main CD and SACD players for 20 years and still is. I have never found a flaw in the sound.
I hope you find this review interesting.
