Sony SCD-555ES Review (SACD & CD Player)
Scytales
France
Hello to everyone.
This is a review and test of the Sony SCD-555ES SACD and CD player. This is an European and Japan model. It was released at the end of 2000 and cost around 1,830 euros at the time (about $1,650 of 2000). It has no US equivalent.
Part I: Presentation
The Sony SCD-555ES is a stereo only SACD and CD player, without any digital output for DSD data, only for 16 bits @ 44.1 ksps PCM data. There is one set of RCA (unbalanced) output and a front phone output jack with volume control. The Sony offers 5 different digital interpolation filters for CD data to choose from.
This player belongs to the very first generation of SACD players from Sony. It is a direct hair of the SCD-1, the very first SACD player, and the almost identical SCD-777ES. In fact, the SCD-555ES is the last Sony player to have used Sony's own "Pulse Length Modulation" (PLM) digital to analogue conversion system that had been introduced in 1989 in the seminal DAS-R1a. NTTY has already reviewed two other CD players that use a Sony DAC chip of the same family: the CDP-X333ES and CDP-X559ES. Please go read the review of the former, where the Sony system is discussed in some length.
Those of you that are interested by technical design would be happy to know that the service manual of the SCD-555ES is readily available and, above all, that the theory of operation of the first generation of Sony SACD players has been very comprehensively described in a patent granted in 2001. As I have always found the ideas herein described very neat, I cannot resist to elaborate a bit on some core aspects of the design. The main goal of Sony was to get a conversion system that has as much commonalities as possible between CD and SACD replay circuits. Actually, it is not an exaggeration to say that Sony's first SACD players were actually regular Sony CD players that had somehow been hacked to also play DSD programs with minimal changes.
The heart of the player is the Sony CXD8762 digital signal processor (figure 1):
This chip takes the serial interleaved left/right PCM input (which can goes up to 24 bits depth, although only 16 bits are used in this player, no re-quantization being made inside the DSP), it de-interlaces the left and right data-stream in a parallel format and performs 8 times digital interpolation (1) to increase the sample rate to 352.8 kHz. Sony advertises some exotic optional "slow roll-off" filters that are user selectable. Apart from the usual high frequency roll-off associated with that kind of filters, the most interesting aspect of at least some of them is that the interpolation is not done in successive cascaded FIR filters, but in a single-stage FIR filter thanks to the processing power available on-chip. A standard interpolation filter based on a 3-stages FIR filter is nevertheless provided. After this first interpolation, a further 8 times oversampling is performed by a (2) linear interpolator (i.e. the computed additional samples follow a straight line from one original sample to the next original sample). A this point, the sample rate becomes 2.8224 MHz. Not coincidentally, this sample rate is the same as DSD. Then, the digital data are re-quantized to 15 levels coded with 4 bits in a 2-complement forms by the (3) noise-shaper (probably third order, as many other Sony chips are). The (4) PWM block is an actual digital to analogue converter which gives the option to use the chip as an integrated digital processor and DAC, but this converter stage is not used in the Sony SCD-555ES. The on-chip converter is by-passed by (5) solid-state logic switches and the 4 bits data are put out in a parallel format at the (6) stereo outputs of the chip. This switches also select the data coming from the DSD signal path. Incidentally, when this chip has been used as an integrated digital processor and DAC in some players, Sony gave it a different part number, CXD9556, but the chips bearing both designations are actually identical.
In the SCD-555ES, the D/A conversion is done in a following chip, the CXD9521. The conversion is a double differential method, i.e. the digital data are converted by four D/A working simultaneously to produce complement and inverted signals that are successively differentially subtracted in the analogue domain. The output waveform of one pair of D/A stage is as shown on fig. 2 (the other pair shapes the inverse of the shown waveforms). T corresponds to the period of the master converter clock, which is 45.1584 MHz, 16 times the rate of the noise-shaped data.
The (1) first D/A of the differential pair converts the 4 bits input data in a pulse length proportional to the input data, the (2) second D/A of the pair produces a pulse length that is the complement of the the first one and the two pulses are (3) differentiated to produce the waveshapes shown on the right. The resulting output can take the form of 14 different pulse widths above and under a "0" voltage step.
DSD data are inputted to the CXD8762 processor through a different digital interface, the data being already separated in a left and right serial format associated with a clock signal line by the DSD decoder chip, which also decrypts the various copy-protection of the SACD disc format. On fig. 1, the (7) on-chip DSD receiver called "SERIAL TEST" actually performs some signal processing on the DSD data to transform them in a format that is suitable to be used by the CXD9521 (or the built-in PWM converter inside the CXD8762). The process is clever and generates many additional opportunities. As seen just above about PCM data, the D/A converter has to be driven by 4 bits data. In order to use the same D/A converter for DSD, which have only two states, either "1" or "0", 1 bit data are translated by the digital input receiver in a 4 bits code. The 4 bits code is associated either to a pulse in the positive direction, or the same pulse but in the negative direction. As can be seen on fig. 3, the receiver (1) takes the 1 bit input DSD data and (2) translates all "1" into "0111" (+7 in decimal) and all "0" in to "1001" (-7 in decimal). This 4-bits translation lets the D/A converters produce in the analogue domain the desired pulses that correspond to each DSD sample. (3) One pair of D/A works differentially to produce a pulse length and its complement; (4) the other pair produces the inverted versions of said pulses. When differentially subtracted, the two pairs of signals respectively produce the final wave shapes shown in (5).
You may have noticed that the conversion of DSD data to analogue is not done according to the archetypal scheme of a string of pulses that are simply low-pass filtered. In the archetypal form seen everywhere else to explain how DSD works and is converted to analogue, the DSD bitstream produces an analogue waveform that only takes two alternating values, one positive, one negative (as can be seen in [1] on fig. 3). In the Sony system described in the patent, the analogue waveform have three states: one in the positive direction, one in the negative direction and one neutral state (at 0 V). According to Sony, this advantageously produces a systematic pattern of a leading edge and a trailing edge (or vice-versa) at each data clock cycle, whereas in the simplest canonical conversion process of 1 bit data, leading or trailing edge only happens when there is a transition from a 1 to a 0 or a 0 to a 1, but never when successive 1s or successive 0s follow each other. In other words, a signal-dependent switching distortion associated with 1-bit data becomes an evenly distributed switching noise that is decorrelated from the signal content and that is easier to be dealt with in the following analogue stages.
But that's not all.
As seven pairs of 4 bits codes are available, Sony has thought about using them as a digitally controlled analogue volume control. Because the mean analogue voltage at the output of the player is proportional to the width of the pulses after they are low-pass filtered, it is possible to use any of the seven available pairs of 4 bits codes to obtain seven different pulse widths, hence seven different gain settings, from 1/7 (lowest gain: pair of codes 0001 and 1111) to 7/7 (highest gain: pair of codes 0111 and 1001). Sony also envisaged to take the opportunity of the conversion of 1 bit DSD data in a 4 bits code to process DSD data digitally under the form of a very simple moving average low-pass filter to remove part of the shaped quantization noise. This very simple filter has three delay cells. Simple math shows that the decimal values that can be obtained by summing 4 successive samples having the value of unity (modulo the + or - sign) can be (if we begin from the bottom of the scale) -4, -3, -2, -1, 1, 2, 3, 4, i.e. eight different values, each corresponding to one of the fourteen available 4 bits code other than 0. That still leaves six other free 4 bits code than can be use to scale the output of the digital filter to form a 4-steps gain control. The output of the filter can thus be scaled to the values of -5, -4, -3, -2, 2, 3, 4, 5, or -6, -5, -4, -3, 3, 4, 5, 6, or finally -7, -6, -5, -4, 4, 5, 6, 7 to increase the output gain.
If we return to fig. 1, we can see that the CXD8762 has (8) two pins called PLMGAIN1 and PLMGAIN2. This pins are used with external DC voltages to hardware control the gain in the DSD receiver. The DC voltages can be either High or Low at each pin to form a 2 bits word, i.e. four different binary numbers, enough to realize a command bus to control the gain at the output of the digital low-pass filter just described. Therefore, we can confidently assume that the CXD8762 performs both the digital low-pass filtering of DSD data and the gain control described in the Sony patent.
There are many other interesting design aspects to discuss about this player, but I think I have already been to long. It was useful to share the main points to counterbalance so many inaccurate descriptions of the way DSD conversion and processing work in the early Sony SACD players.
Let's get to the review !
I will do my best to adhere to the following general framework, when it is possible with the various test discs available to me:
1. Dashboard @ about 1 kHz, 0 dBFS
2. Frequency response related measurements
3. Noise and distortion related measurements
4. Linearity tests
5. Special tests
6. Disc readability tests
Part II: Measurements of the Sony SCD-555ES as a CD Player
All measurements were taken with an Audio Precision System One+DSP SYS222A. Unless otherwise stated, the tests were performed with NTTY’s Test CD Version 7.2. The Audio Precision has always been given the 30 minutes preconditioning period mandated in its calibration procedure and the device under test the 5 minutes mandated by the AES-17 standard.
1. Dashboards
As said earlier, the Sony SCD-555ES gets five interpolation filters to choose from. Unless otherwise noted, all measurements below are performed with the "Standard" digital filter.
Keep in mind that the old Audio Precision System One has no dual analogue to digital converter per analyzer channel, hence cannot display a recombined representation of both the test signal and the distortion residual. Contrary to Amirm's reviews, you will only see the distortion residual with a “notch” on each side of the leftover of the test signal: this is where the analyzer band-reject filter has removed the test tone prior to the digitization and measurement of the residual signal.
The output level is in the vicinity of 2.15 V RMS. The levels of the two channels are matched to within 0.03 dB. The tests has also revealed a relatively close matching in performance metrics between the left and the right channels, but you nevertheless get 2 dashboards for the cost of one to appreciate that for yourself.
The mean SINAD of 96.5 dB is actually dominated by the 16 bits quantization noise. You may have noticed the complete absence of visible power-supply related noise (mains frequency in Europe is at 50 Hz). The harmonic distortion spectra of the two channels are consistent with measurements made by a German laboratory in 2001 that I have reported elsewhere: the THD alone (noise excluded) was about -108.2 dB (0.00039%).
I find it interesting to show a dashboard of the most peculiar optional digital filter, numbered 2 :
The harmonic distortion pattern and overall THD+N do not change, but the output level is slightly lower and it can be seen that the notch due to the band-reject filter is less deep. Moreover, the THD+N bar-graph shows a wider standard deviation. I have seen similar effects with DSD sine signals. I think this is partly due to the DSD high frequency noise that lets the active notch filter enter slew rate limiting, but I can be wrong.
To comply with the practice set by NTTY in his exceptionally thorough CD player reviews, here are dashboards of the two channels configured the same but at -6 dBFS:
At -6 dBFS, the respective THD+N (inverse of SINAD) of the two channels are almost the same and are noise dominated. It is worth pointing out that the output level of the two channels matches perfectly, which is excellent.
Let's see how the five available interpolation filters of the Sony act on the player’s frequency response (only one channel shown). The two following measurements have been made with a glide tone at -15 dBFS from the Denon Audio Technical CD:
Filter 3, 4 and standard share more or less the same overall response, obviously imposed by the analogue output stage of the player (see also SACD measurements below for confirmation), save for the rate of attenuation of very high frequencies, whereas filter 1 and 2 roll the high frequencies more. Filter 4 has some ripple at the high frequencies. Another important effect is that filter 4 is down 0.25 dB in level compared to filter 1, 3 and standard, and filter 2 is down a good 0.125 dB more. This level differences alone will be audible during comparison.
Here is a high-resolution frequency response and inter-channel phase deviation plot of the player with the Standard digital filter:
The frequency response is tailored by the analogue output low-pass filter, with about -0.1 dB at 10 kHz and slightly less than -0.5 dB at 20 kHz. There is no significant deviation of phase response between the two channels.
Another way to look at the effect of the digital filters is to trace the wideband response with white noise up to ultrasonic frequencies (in this case 85 kHz).
The most interesting filter is number 3. Yes it attenuates more than the standard one at the top of the audio band, but it remains relatively sharp indeed and have a lower out of band noise floor. Sony says this is a single stage FIR filter.
The SCD-555ES decodes emphasized tones at -20 dBFS from the Stereophile Test CD2 at almost correct levels:
Decoding of emphasized data has also been assessed with tracks at -10 and -60 dBFS from the HiFi-News and Record Review Test CD II (HFN 015). The levels with this test tone are also correct.
Crosstalk evaluated with spot tones from the Denon Audio Technical CD is better in the right to left than the left to right direction, but is good in any case:
3. Noise and distortion measurements
Let's start with some Left/Right single point measurements about noise and distortion before proceeding with more graphs. All measurements are done with standard Audio Precision tests:
The signal to noise ratio is consistent with the dynamic range. That indicates that, contrary to an old practice followed by Sony until the SCD-555ES, the DAC does not mute its outputs when it is fed with a digital signal containing only zeros. The reason why the signal to noise ratio is greater than the dynamic range is because a digital signal containing only zeros does not exercise any quantization level above or below the 0 level, hence no quantization noise is generated at the output of the DAC.
The standard digital filter has no headroom to reproduce inter-sample overs, as do the 4 other optional filters. For the record, digital filter 2 degrades the intermodulation test figures rather dramatically (about -55 dB measured on both channels with DIN test signals at -10 and -1.68 dBFS), whereas the other optional filters remain more controlled.
To go further in the analysis, Audio Precision provides some standard tests to assess the noise performance of a CD player.
First test is to look at the FFT spectrum of an “Infinity Zero” signal from the Denon Audio Technical CD up to 80 kHz:
Please take into consideration than this measurement is free from any influence of the digital processing since the test signal contains only zeros. It only shows the analogue components of the noise. A variation of this test suggested by Audio Precision is to restrict the measurement bandwidth to the low frequencies and to lower the sample rate in order to narrow the bin frequency width. That way, it is possible to search for mains frequency interference and power supply related noise with great resolution:
As you can see, the FFT spectrum is very clean, with only 50 and 100 Hz tones present on both channels at very low levels, especially in the right channel.
The other tests use the analogue analyzer to plot 1/3 octave curves of the noise with the same "Infinity Zero" signal. Although this method has less frequency resolution than the FFT analysis (the higher the frequency, the wider the noise bandwidth that each point of the curve represents contrary to an FFT analysis where each “bin” has equal bandwidth; that is why the curve obtained with the analogue analyzer regularly increases towards higher frequencies), it takes advantage of the greater dynamic range and the wider frequency response of the Audio Precision System One’s analogue analyzer over its ADCs.
A good correlation can be seen on both the FFT and the wideband analogue noise spectrum.
The same test restricted to the audio bandwidth will be useful to compare to a special test that will be shown below:
Lastly, I add a test inspired by NTTY's practice to show an FFT spectrum up to 1 kHz when the player is reproducing a 1 kHz tone at 0 dBFS in search of power supply spurious noise. For this test, I set up an FFT at 8 ksps in order to improve bin frequency resolution to look after the output of the notch filter. Here I have to make a choice about which signal to use. I have chosen the 999.91 Hz sine with noise-shaped dither, which produces the lowest noise floor. The FFT is almost free of any power supply related spurious except at 250 Hz, but we can also see a smidgen of 100 Hz side-band at the left of the remainder of the test tone:
THD+N vs frequency has been assessed with spot tones at 0 dBFS without dither from the Pierre Vérany Digital Test CD. First within a 20 kHz bandwidth (i.e. the audio band):
There is no increase in distortion in the bass, but the THD+N is higher towards the high frequencies. The sharp downward slope of the curve above 10 kHz is due to the fact that the second harmonic at 10 kHz and above falls outside the pass-band of the test, hence there is no longer any harmonic to measure, only noise. The upward curve from about 15 kHz most probably indicates an increase in the noise (including quantization noise) or distortion due to imaging above the 22.05 kHz Nyquist frequency of CD folding back into the audio band when the player has to reproduce high frequencies at high level.
Second, here is the same test, but with a wider measurement bandwidth up to 80 kHz:
The increasing THD+N at higher frequencies is now more obvious.
THD+N in function of levels has also been assessed with the help the 999.91 Hz test signals from NTTY CD test disc. First with dithered tones (which gives a typical performance curve, because CD production is almost universally done with dither):
The flat curve up to a level of about -15 dB indicates that the measurement is dominated by the dither noise and that minimal excess distortion begins to appears at signal levels above -15 dBFS. It is possible to see a truer picture of the level of performance of the player with the same measurement but this time with the sine tones without dither:
Here, the two curves stay at or below -98 dB THD+N up to -15 dBFS level or so. That means that the Sony SCD-555ES is capable of 16 bits accuracy over almost a 45 dB wide dynamic range, and above -15 dBFS, little excess noise or distortion begin to appear.
Audio Precision provides a standard test to evaluate more qualitatively the SMPTE intermodulation distortion by looking at the digitization of the output of the analogue analyzer filter that removes the 60 Hz and 7 kHz tones to observe the actual distortion products:
And here is the same test with digital filter #2, which shows a much worsened distortion pattern:
The old 16 bits Burr Brown PCM78 ADCs of the Audio Precision System One probably limits the usefulness of FFTs of high level CCIF twin tone signals, because of the high dynamic of this signal relative to the noise floor. Here is an FFT of a -3.02 dBFS twin tones in a 23 kHz bandwidth:
Pairs of odd order distortion products (at 18 and 21 kHz, 17 and 22 kHz and 16 and 23 kHz) are visible, the highest pair being at about 90 dB under the level of each twin tones. The even order distortion at 1 kHz is some 100 dB under the level of each twin tones.
For the same reason already explained about the dynamic range of the old Audio Precision ADCs, I do not think an FFT of the multitone signal from NTTY's test CD can give much detailed information. Moreover, the maximum FFT length that the System One is capable of restricts the bin frequency resolution in the bass. Anyway, here is the FFT spectrum of such signal, but from 100 Hz only:
Lowering the sample rate of the FFT to 8 ksps and restricting the analysis to a lower 4 kHz bandwidth in order to observe only the lower part of the multitone signal gives a bit more resolution (not shown), but there is not much more to report.
4. Linearity Tests
With the kind help of NTTY, who has created a custom linearity test track with noise-shaped dithered spot tones down to -130 dBFS, I am able to assess the player's DAC deviation from linearity with the System One's software-implemented selective voltmeter:
I have used the same scale than the one Amirm uses for its own tests to ease comparison. The yellow curve (right channel) stops at -110 dBFS because the right channel of the Audio Precision is unable to settle to any reading under that level. Nevertheless, we quite certainly get an almost perfect linearity down to -120 dBFS on both channels as can be seen on the left channel, the worst case deviation down to that level being at most +/-0.1 dB. This is roughly 20 bits of accuracy! The deviation from linearity of the left channel at -130 dBFS assessed with NTTY's custom test signal is +1.3 dB, but that is not stable and does vary from one measurement to another, because the signal lies deep in the player's analogue noise. So, the exact level at which the player's output deviates significantly from linearity lies somewhere between -120 dBFS and -130 dBFS.
The above results have been obtained from measurements that I made only several dozens minutes after the player had been switched on. But on one instance, I made an FFT analysis of the -130 dBFS sine signals after half a day of operation and here is the outcome:
I don't know if the fact that I managed to randomly take a snapshot at the precise moment when the level of the two signals fell simultaneously almost exactly at the correct value was due to sheer luck or if there actually is an improvement of the linearity at extremely low levels due to thermal stabilization, but at least we can appreciate the cleanliness of the signal.
(To be continued in message #2)
(Continuation from message #1)
5. Special Tests
Here is a capture of the waveform of a 997 Hz sine at -90.31 dBFS without dither from NTTY Test CD:
The waveform is a bit noisy, but the three discrete voltage steps are clearly visible.
The Sony DAC is perfectly monotonic, i.e. increasing digital codes produce consistently increasing analogue outputs at the lowest levels. Most probably this characteristic is no longer difficult to get nowadays, but at least it let us see a pretty picture:
Non-monotonic DAC can also be revealed by another special test which was proposed by Audio Precision in 1991 to check the absence of modulation of the noise floor of D/A converters at different levels (Richard C. Cabot, Noise Modulation in Digital Audio Equipment, AES preprint 3021). This test consists of accumulating on the same graph a third octave analysis of the quantization noise after the removal of a low frequency test signal at different levels from -50 to -100 dBFS. Any change on the shape of the noise floor would signal a modulation of this noise in function of level. Audio Precision quoted experiments previously conducted at Dolby Laboratories that had shown that noise modulation of as little as 2 dB may be audible. Nowadays, this test may have no longer relevance with modern D/A converters, especially sigma-delta converters, but maybe it can still be useful to check ladder type converters. In any case, here is this test performed on the Sony SCD-555ES as proposed by Audio Precision:
The noise floors at different levels overlap almost perfectly, save for small "blips" that look like there are not significant. It is enlightening to compared this graph with the noise in the audio band between 500 Hz to 20 kHz obtained with the same 3rd octave band pass filter when the DAC is fed with an "Infinity Zero" signal (see Part II, 2 above). The elevated noise that can be shown on the graph above compared to the graph in Part II, 2 is due to the fact that the noise coming from the digital processing adds to the noise of the analogue circuit of the player.
The noise modulation test can be performed in a more modern way by accumulating FFT spectra of the different test signal levels:
The noise generated by the different test signals overlap perfectly, confirming the absence of any noise modulation.
Finally, I used special dithered signals made by NTTY on the model of the Pierre Vérany Digital Test CD, which contains unique (non-dithered) tracks to perform a peculiar test called "intermodulation by crosstalk". The theory of operation of this test is as follows: the channel under test plays a 5 kHz tone and the other channel simultaneously plays a 1 kHz tone, both at 0 dBFS. If there is a significant crosstalk between channels, the 1 kHz tone can theoretically intermodulate with the 5 kHz tone to produce on the channel under test a difference frequency of 4 kHz and/or side-bands at 4 and 6 kHz due to amplitude modulation of the 5 kHz tone by the 1 kHz crosstalk tone. This test has been designed at a time when most CD players have only a single digital to analogue converter for two channels for cost-savings reason. These CD players had to demultiplexe the left channel from the right by routing the output of the single DAC alternatively to each one of the two channels at twice the CD sampling frequency.
I looked for the intermodulation product after I had the Audio Precision notched out the 5 kHz tone to increase resolution. I found nothing in the right to left direction, but in the left to right, I have found small 4 kHz and 6 kHz side-bands at about -120 dBr (after the attenuation of the notch filter has been compensated for):
The relevance of this measurement as an intermodulation distortion assessment is debatable, but a case can perhaps be made that it is in some way a more stringent crosstalk test than the one I performed and have shown the result above. In an usual crosstalk measurement, one channel only plays back some signal whereas the analyzed channel remains silent. In this case, many D/A converters may mute the channel under scrutiny. When the test signals designed for the Pierre Verany Digital Test CD are played back, on the contrary, both channels are very well alive because they have both a tone at maximum level to reproduce.
6. Disc Readability
To end the first part of this review dedicated to CD replay, I have used the famous Pierre Vérany Digital Test CD2 to check the ability of the Sony SCD-555ES to play damaged discs or disc pressings that are not compliant to the Red Book (RB) specifications. The criteria of failure on a test is either glitches, warping of the output waveform or an increase of THD+N from the nominal value. The last one is the most stringent: if it were relaxed, the player would have passed more test steps for it actually proceeds to produce a stable output with only moderate increase of THD+N on some tracks. As NTTY obviously uses the same disc to perform its own tests, I will borrow his table:
Test TypeVariable parameter(s)Results
Variation of linear cutting velocity1.4 then 1.2 to 1.4 m/s in 0.05 m/s stepsAll tests passed
Combined variations of track pitch and velocityFrom 1.2 m/s to 1.40 m/s combined with 1.5 µm & 1.7 µm pitchAll tests passed
Variation of track pitch1.5 µm to 1.7 µm in 0.05 µm stepsAll tests passed
HF detection levelVariation of the pits/lands ratio from +2 to +18%All tests passed
Drop-outs tests0.05 to 0.2 mm (RB spec.) and 0.3 to 4 mm (non-spec.)All RB spec. tests passed - Pass to 1.25 mm Fails from 1.5 mm
Combined drop-out size variation & minimum track pitch1.5 µm + 1 to 2.4 mmPass to 1 mm Fails from 1.5 mm
Successive drop-outs2x0.1 mm to 2x3 mmPass to 2x1 mm Fails from 2x1.5 mm
Part III: Measurements of the Sony SCD-555ES as an SACD Player
Measuring an SACD disc player presents two challenges.
The first is the lack of availability of proper test disc. Only two test SACDs designed to assess performance of disc players have ever been made by Sony and Philips and they have been out of print for a very long time. The only available SACDs with some more or less useful test signals that are procurable are designed to set up stereo or multichannel Hi-Fi systems, not to measure the performance of the DACs of disc players. Nevertheless, I will try to make good use of the test SACDs that are available.
The second is the high level of out-of-band noise generated by the sigma-delta modulation. This out of band noise may upset wide-band analogue audio analyzer. The Audio Precision System One does not escape this problem. Thus, the measurements I am able to perform are limited for now, but I will proceed to work on the challenge.
For this part, I can use only one test disc that has been designed mostly to set up multichannel audio systems but that also gets some stereo test tracks : the Denon Audio Check SACD.
1. Frequency response
The Denon SACD has no 1 kHz or so sine tone at the nominal 0 dB SACD level, but it gets several sine signals at -16 dB SACD that are precisely aligned with the level of PCM sine signals at -16 dBFS. It is thus possible to calculate the nominal output level of the Sony by measuring the signals at -16 dB SACD and adding 16 dB to the measured level. The output is exactly the same (2.15 V RMS) as with corresponding PCM sine signals and the channel matching is identical.
That means that the SCD-555ES is a perfect candidate to compare CDs and SACDs at matched levels if you are able to find music program materials that are mastered identically in both formats.
Due to the lack of 1 kHz sine at full 0 dB SACD level, I cannot show a "dashboard". All I can report is measurements made elsewhere by a third party with an Audio Precision System Two and a proper SACD test disc that has revealed a very low harmonic distortion of (worst case) -115.4 dB (0.00017%), only made of the second and the third harmonics.
The frequency response has been checked with a glide tone signal from 5 Hz to 30 kHz at -20 dB SACD from the Denon disc:
You can see that the response is tailored exactly the same way as with CD replay (beware of the different horizontal scale on the above graph when comparing!). This confirms the fact that the frequency response is imposed by the player's analogue output low-pass filter. Again, this made the SCD-555ES a perfect player to compare CD and SACD editions of the same program material contrary, for example, to the Pioneer DV-868AVi, which has both different output levels and frequency response between PCM mode and SACD mode.
It is possible to explore the response of the SCD-555ES much higher in frequency with the pink noise tracks of the Denon SACD. It is well known that a 1/3 octave analysis of pink noise should show a flat response. Let’s check that with the Audio Precision analogue band-pass filter:
Now that is interesting. The usable frequency response extends to somewhat 55 kHz with a gentle roll-off. From 55 kHz, the response flattens a bit: this is where the noise is no longer pink in nature: it is the shaped quantization noise typical of DSD that overcomes the pink noise. But the noise level quickly goes down following a regular slope. Compared to the Pioneer DV-868AVi I already reviewed, the Sony SCD-555ES has much more effective combined digital and analogue low-pass filters. In fact, I have measured more than 4 times less noise above 100 kHz with the Sony than with the Pioneer. The performance of the Sony is by design: its active analogue low-pass filter is one of the most potent I know of among disc players. It would be interesting to compare this performance with devices using modern D/A converters which rely more on digital low-pass filter and less on analogue filters for DSD replay.
Another way to view the pink noise, though in a more restricted bandwidth, is to make an FFT at the maximum sampling frequency the Audio Precision System One is capable of. Moreover, as the Denon Audio Check SACD pink noise tracks get signal on one channel only at a time, we are going to see what is actually on the muted channel:
As you can see, the pink noise effectively extends to 60 kHz before it is overcame by the shaped quantization noise. The most interesting thing is that the quantization noise is also visible on the muted channel (the fact that the HF noise of both channel doesn't overlap seems to be due to the Denon test disc). That means that the silence is actually an analogue mute signal and that the DAC of the player stays alive, as what happens with an "Infinity Zero" signal. This gives the opportunity to measure the true signal to noise ratio of the player thanks to this DSD analogue mute signal.
2. Noise measurements
To compute the signal to noise ratio, one must measure the noise floor in the audio band when playing an analogue mute track and refer the result to 0 dB SACD. Bear in mind though, that 0 dB SACD is not the maximum signal level that SACD is capable of: as I have explained on another thread, the SACD audio specification allows short term peak excursions at +3.1 dB SACD.
Unfortunately, I encountered a strange behavior that makes me doubt the reliability of the System One analogue analyzer to measure audio band noise level of DSD signals. So, instead, we can have a look at the noise floor in the audio band with an FFT analysis, which works fine:
Compared to a similar measurement in the same bandwidth with a PCM "Infinity Zero" signal (not shown), we get a somewhat similar noise floor, except for a bit more low frequency mains interference and the small blips around 550 and 1,200 Hz in case of SACD replay. So, we can assume that, when DSD data is replayed, the SCD-555ES is capable of more or less the full signal to noise ratio measured with an "Infinity Zero" PCM signal, whereas of course the true SNR from CD data would be limited by the added quantization noise in the presence of any signals.
This ends the measurements I am able to perform in DSD for now.
I just want to add that this Sony SCD-555ES has been my main CD and SACD players for 20 years and still is. I have never found a flaw in the sound.
I hope you find this review interesting.
Whoa. Now this is what you call an exhaustive set of measurements.
Do you reckon there could be any link to NPC? This sounds like the modulation scheme used in their DACs, and the time frame would broadly line up as well. It would almost seem odd if Sony had never had any dealings with what was after all the biggest Japanese DAC maker at the time.
(I wonder what happened to NPC anyway. My guess is that they never fully recovered from the collapse of the bubble economy.)
Thanks for the review and all the work on it. My trusted Sony feels a lot better now ;)
I don’t really understand many of the measurements but try and really enjoy reading them. It amazes me that there are such dedicated smart people out there willing to create such extensive reviews. Thank you!
My Sony ES CDs and also my ES SACD are smiling!
I have a very old lower end Sony ES CD Player from the late 1980s. I do not use it not, but it works just fine. They made some good ES products over the years.
This is a very nice and complete review, thanks for all the efforts and time you’ve put into it!
I’m happy to see the System One still delivering, this is cool, and you obviously make good use of it!
This SACD player is well put together as so many Sony players. Obviously, you only measured the quantization noise of the test CD rather than the one of the Sony :p The 3DC trace is neat and is an additional indication of low noise, probably limited by the System One’s resolution. I don’t know if it has a scaler, but if not try to increase the gain at the input of the analyzer, it could help lowering the noise of the System One and get a better view. As is it is already near perfect, so…
Can you perform the "max resolution" test with shape dither from the test tone @-12dBFS with low pass filter at 6kHz and measure the resulting THD+N? Maybe the System One can’t be tuned for that test?
Thanks again anyways!
I wasn't aware of any connection between Sony and NPC. I just re-read your timeline of DACs to find relevant NPC DACs and I understand the similarities between contemporary Sony and NPC DACs you just pointed out. The DACs of both makers seems very similar indeed, especially if we took into consideration known variations of the Sony system that are discussed in papers quoted in NTTY's review of the CDP-X559ES.
Do not hesitate to ask question if some test or explanation are unclear to you. Perhaps I haven't provided sufficient explanations in some places.
I myself own a Sony DVP-S9000ES. I intend to review it at some point, including with 24 bits test signals on DVD, because this player is capable of reading them.
You're welcome, especially as I owe you so much!
To the best of my knowledge, I cannot perform the "max resolution" test with the System One software. The only method which would resembles your test would be to add a sharp analogue band-limiting filter @ 6 kHz in the analogue analyzer signal path before the distortion residual is measured by the reading meter. That may be done.
For all test, I let the System One in "Auto ranging". I try to range the input manually on few tests. Sometimes I got better figures, sometimes not.
