VientoB
I think DMS compared them in one video. They’re not much different iircI'd bet the drivers inside are the same ones used in the 7506 and that they sound roughly the same.
Personally, I like the 7506, and I don't find a noticeable lack of bass. Of course, my ear pads aren't degraded.
To be fair, Crinacle's measurements indicate that the Yaxi pads are adding treble and midbass (depending on the model). This should push them into "fairly decent" territory, especially considering that there are not a lot of low-price options that sound decent and have good build quality.The deviations from the target are similar to AKG K712 FWIW
I'm not sure this headphone should have been considered for content consumption in the first place. Clearly it can't be competitive with it's FR. DMS should not have talked about it other than a quirky curiosity.
It's hard in practice to recommend a product based on it's modified state with third party accessories, also drives up the price. While alternatives are not super numerous, I'll give that, it's not zero.To be fair, Crinacle's measurements indicate that the Yaxi pads are adding treble and midbass (depending on the model). This should push them into "fairly decent" territory, especially considering that there are not a lot of low-price options that sound decent and have good build quality.
That’s kind of harsh toward the person who loaned it, don’t you agree?- what is the address to ship it back?
- throw it in the trashcan
Having experience with 45CA, you shouldn't use seal on the fixture as a consistent indicator of on-head performance.If there are such obvious leaks in 45CA, then for people, this headset has lost the need to wear it seriously.
Not me. I appreciate that someone loaned them to Amrim for testing.Not really, but if it was you and you feel so I apologize.
Look at the sensitivity, its easy to turn up loud, which singers want during tracking. The FR will tire your ears less as a bonus, your analysis is spot on.I don't really see the point of these for recording vocals (and I see one in something like NS10s). It's probably less fatiguing cause the plosives/sibilance is reduced? that could make sense for longer recording sessions as raw vocals can be ear-piercing.
Theyre different, people have posted about it and theres lots of modders for these. 7506,v6,&cd900ST all have different drivers. The film/membrane materials and coils are all different.I'd bet the drivers inside are the same ones used in the 7506 and that they sound roughly the same.
These are mine. I have lent Amir all sorts of gear, ranging from golfing panther to headless panthers.
I have always believed in the value of measurements, but many underestimate the consequence of the circle of confusion.
Macross Delta is one of my favorite anime shows. (2015). Here, you see one of the singers using the CD900ST while recording.
The final mix is done at
(which uses Genelec).![]()
HIROSHI KAWASAKI | ENGINEERS | FLAIR
victorstudio.jp
If you take a look at this song from the album, try listening it on a Harman target headphone versus something with the high/low rolloff and tell me what sounds more accurate …
The power of measurements is that if we KNOW the MDR-CD900ST is being used in production, we can take a neutral/flat Harman target and roll of the HF and LF aggressively and see if it’s a preferred rendition.
J-pop is often “bright” but live J-pop concerts on Blu-Ray don’t seem bright. Now we have an inkling that a good reason is that the mixes are done with headphones which are crazily rolled off!
This is why I have never truly felt that “faithful to the recording” made sense unless dealing with home theater, where there are a lot more standards.
That being said I still really like the CD900ST despite its flaws. Compared to the V6 & 7506 it sounds a lot nicer to me. (Obv subjective) but these are like 30-40 year old designs now. A lot of artists are really accustomed to the sound of the CD900ST in asia
I think Crin's graph shows the CD900ST a lil nicer to look at in comparison. I think the 1-2K dip is fine, i dub this like the hifi-esque tuning which most audiophiles tend to like some minor dip in this region and its common among alot of headphones. The slower roll off after 4K is subjective, but the midrange really is nice on these imo. Bass is pretty much like every other headphone from this era. Otherwise its still good as a mixing/production headphone if your used to this kind of sound.
I forget the name, but the Sony engineer who designed their monitors (even in the newer monitor MDR-M1ST) said that the seal is imperative for these as they're attributed to their tonality so they were designed to have the response that they do. It wasnt accidental, they have really thin pads on purpose, you can get bigger pads and it gives it more resonance in / around your ear boosting both the highs and lows. You can get them much closer to harman if you want. I own 2 pairs of the CD900St one that has the Yaxi pad mod (thicker) and another that is just the OEM stock thin pads, tbh I find myself going toward the OEM sound pretty often.
