Sony BDP-S1700/K Review (Blu-Ray/DVD/CD Transport)
Rate this BR/DVD/CD Transport
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 2 1.9%
  • Good (***)
    Votes: 17 16.2%
  • Excellent (****)
    Votes: 86 81.9%
An outstanding review, adeptly mixing left brained and right brained reactions to a no brain(er) product!
I am particularly pleased to see I am not the only one drawn to anachronistic uses (no offense meant, @NTTY) of modern products. ;)
No offense taken, on the contrary :)
And thank you!
I have 2 players: Sony BDP-S6500 and Pioneer DV-610AV. Both play multichannel DSD over HDMI. I think players can convert it to multichannel PCM too.
The BDP-S6500 will also rip your SACDs for you, if you wish.
All SACD players will play via DSD conversion to analogue .
If you want a DSD output to another DSD capable dac .. then no, it is strictly prohibited via the SACD licence for any player (unless in a proprietary transmission format to a manufacturer's own dac).
However, for certain Oppo players, there are circuit boards available that extract the DSD signal from the internal HDMI signal.
Such boards are also available as universal units to extract the PCM or DSD signal from an external HDMI source and output it via I2S.
Hello everyone,
This is a review and measurements of the Sony BDP-S1700/K Blu-Ray/DVD/CD transport.
Sony BDP-S1700/K - Presentation
A number of you have expressed their interest for recent Sony Blu-Ray transports, to know if they could act as decent CD Player. Two weeks ago, I was at the shopping center and saw that one at a very reasonable price (below $100) and so I went for it.
You can find all details about this device on Sony's website, and the elements of interests for me, that I took from the community, were:
  • This is a (CD) transport
  • It has a Coax (SPDIF) output to use with modern or older DACs in a "standard" HiFi environment
  • It is reasonably priced
I will be testing it on CD Transport perspective, and I will also have a quick look at higher resolution sources. The principle is to use Coax output only because I'm not equipped to measure digital HDMI output. I would probably need to invest into an AV preamplifier with HDMI input, but that's not planned.
So, it is a transport, no DAC inside, meaning that the back is very simple:
We have one HDMI output and one Coax. It is not documented in the User Guide, but because SPDIF is not HDCP (Digital Content Protection) compliant, copyright holders do not allow high-quality, high-resolution audio to be passed through it. That means this Coax (SPDIF) output should be restricted to "CD quality", and that is max 16bits/48kHz. We'll check if that's the case, and since it implies an ASRC is in the digital chain, we want to know what's the impact of that on the PCM data (especially from CDA). In other words, and that's the main concern, can we get "digitally perfect" output from an Audio CD.
User Experience
No display on the front, you'll need a TV to see anything. Only two buttons, one to power on/off and one to open/close the tray, rest requires the remote control.
The good news is that, out of the box, there's no need to configure anything to listen to a CD. Plug in, insert the disc, press play on the remote (CD playback is selected by default after it recognizes there's a CD in the drawer), and you're good to go. Not even needed to connect it to a TV for whatever setup, provided you only intend to listen to a CDA.
It's not fast to skip a track, less so multiple, but is that a real problem if you're into listening to a full album at once? FFW/REW are available from the remote control but painful as it will skip 20sec at once and you get no audible feedback. But well, I survived it.
The drive is relatively noisy (50cm next to me), especially when reaching the outer section of a CD. It is difficult for me to tell you if you'd be annoyed as we don't have the same sensitivity to that type of noise. I could not hear it with my Beyer DT770Pro on my ears.
It had no issue reading 70min+ discs, CDR nor the CD layer of an SACD. I dreamt it would read the SACD layer and propose a downmix to PCM, but no. Anyways, most of the studios are now producing and releasing a CD layer made from the same mix than the one of the SACD master, so the quality is the same, only bit depth is decreased and proper shape dither applied to compensate for it, so I'm not too worried. A "stupid conversion to PCM" in the Player could be much worse.
Last before I go into the measurements blah blah, is that I must admit I spent unusual time listening to it (via the Topping D50III and A50III with my good old Beyer DT770 Pro), pushing the volume always more and more. I surprised myself, as I typed this review, to stop sometimes, close my eyes and listen to what I hear, or play air piano/drums/guitar. It made this review particularly long to finalize :)
That is, I had surprising pleasure and I guess it already tells you about what I'll soon report on quality perspective. The foot print of all my messy setup is reasonable as per the below picture (on top of Sir Accuphase DP-70):
You can't trust my old ears, anyways, but we are talking about a Sony, the masters of CD, and if Sony decides a device is to play a CD, it will play it per the Redbook. So yes, I am happy to report it is gapless playback and applies de-emphasis when required (in digital domain). This is a proper CD player! In a world of where many actors have forgotten about the Redbook, or just don't care, this is reassuring. Thank you Sony!
I'll be dividing this review in 3 sections:
  1. CD digital measurements + Drive tests
  2. High-res digital audio measurements (from USB and DVD-A)
  3. Analogue measurements from the Topping DAC (CD source only)
Sony BDP-S1700/K - Measurements (Coax out, CDA as source)
All measurements performed with an E1DA Cosmos ADCiso (grade 0), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the SMSL PL-200 review. I used the commercial version of my Audio Technical CD for all measurements. Over time, this will help comparing the devices I reviewed.
The Sony BDP-1700S/K came with Firmware version M47.R.0011. I could not find a more recent one on Sony's website.
As a transport I only have the digital output to measure to verify it is "bit perfect". They are the same tests that I perform with all the CD Players I review when they offer a digital output.
This is my standard 999.91Hz test tone @0dBFS (without dither):
It is the same as if I run this test directly from the original WAV file that was used to create the CD. So it is "perfect".
Same with the good old 3DC test from Stereophile (undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal):,
It is the expected square view that we want to see, with the Gibbs Phenomenon showing itself. That means no modification of the digital signal.
Of course, jitter is absent:
This the exact graphical representation of the test.
In the end, my ultimate proof of "perfect" digital output is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent, it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distortion. So here we go:
No changes when compared with the WAV file, again. We get the expected +0.69dB overshoot and no distortion whatsoever. So if there's an ASRC on the digital path (and there is one, see below), it works here in bypass mode.
The only small issue I could find with he Sony is a small imprecision of the internal clock that travels through the SPDIF. If you use a converter that has a very low phase noise clock, this variation will be filtered out by the PLL. If not, then you'll get a reasonably low -25ppm deviation (good luck to hear that).
I won't be adding more unnecessary measurements, it is every time the same story: I get the same as the original WAV files. It means the coax digital output of this transport is unaltered from CDA.
Sony BDP-1700S/K - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)Pass
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmPass
Successive dropoutsFrom 2x0.1mm to 2x3mmPass
Yeah! Best in class! Not only a handful of drives achieve this performance, the Sony is also the least expensive transport (new) that I tested! I saw the Sony SERVO starting interpolating at high dropouts of 2.4mm and I could not hear anything up to 4mm. Drill a tiny hole in the CD, and the S1700 will continue to read it with you noticing :p
Sony BDP-S1700/K - Measurements (Coax out, USB and DVD-A as sources)
So we stay in digital domain for these measurements.
For the sake of simplicity, I'll show you only the standard dashboard with my pseudo 1kHz test tone.
First, from USB key (1kHz @0dBFS 24bits/48kHz):
As per the HDCP regulations, the signal is reduced to 16bits depth AND 48kHz output. I tried with 96kHz and 192kHz sampling rate test files, and got the same output 16bits/48kHz. We are indeed limited by 16bits/48kHz. At least the decrease of bit depth does not come with significant distorsion, but SNR is now limited to 99dB, as you can see.
Now, from a DVD-A, it is not the same story at all. Look at the same test tone (24bits/48kHz):
If the dashboard shows 16bits resolution, it is because of the distortion, and not limitation from the noise floor. Looking at the noise floor level, we are close to 18bits resolution. This is not the 24bits recorded on the DVD-A. So there is again significant processing here, and that does not to comply with 16bits/48kHz output. Strange.
Problem is that the situation degrades with lower levels of output as the distortion is roughly constant, and not level dependent (not shown). This is weird but means I can't recommend using it to listen to DVD-A, if you still have some. I could not find a firmware update to potentially fix this issue.
In the end, don't expect anything high resolution from the Coax output, use it for CD playback only. And note that a WAV file 16bits/44.1kHz, played from the USB stick, outputs the original unaltered PCM data stream.
Sony BDP-S1700/K - Measurements (CD source with Topping D50III as DAC)
Let me finalize this review with few tests from the output of the high precision DAC Topping D50III, the Sony BDP-S1700/K being the source, from CD audio. I used the RCA outputs of the Topping.
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (RCA out of the D50III):
As I reported with the test of the SMSL PL200, this is near perfection, so close to the original WAV file, and thanks to the high resolution of the Topping. Some distortion (at -135dBr!) might be due to my ADC, by the way, with that high-level test tone.
Let's try at -6dBFS:
Peeeerfect! You can't dream for more. The limit in the PCM 16bits format here, not the Topping and of course not the Sony!
I'll spare you with more measurements, but just a last one. Look at this magnificent Jitter trace:
It looks like the one done directly from the WAV file, but no, here we indeed have the Sony feeding the D50III and the result is nothing else but absolutely perfect. Impressive.
Now, one very interesting thing here, about the "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz). But let me lower the Topping output by 3dB, since we have so much headroom with 16bits signal:
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-X333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
Sony CDP-597-30.4dB-24.7dB-16.5dB
SMSL PL100-53.1dB-31dB-19.1dB
OPPO BDP-95-39dB-28.8dB-19.2dB
OPPO BDP-95 (vol -2dB)-95dB-97.5dB-32.7dB
SMSL PL200-94.8dB-97dB-39.5dB
SMSL PL200 (vol -1dB)-94.8dB-97dB-58.7dB
Orpheus Zero-88.7dB-87.3dB-56.8dB
Azur 640C V2-89.8dB-91dB-64.5dB
NAD C540-34.1dB-26.3dB-20.4dB
Consonance CD120B-84.3dB-39.6dB-20.9dB
Fosi Merak-38.8dB-28.5dB-18.5dB
PROCEED PCD 3-29.7dB-23.9dB-15.8dB
Sony BDP-S1700/K + Topping D50III (vol -3dB)-95.1dB-97.1dB-97.2dB
Best of the best! Actually I never performed this test before with a transport and the D50III. And it means what it means: this combo provided me with the best analogue output I ever witnessed! Even the star SMSL PL200 started to slightly clip with 3dB overs. And if you're worried that -3dB output volume might decrease max performance, let me reassure you:
Actually the third harmonic, that we could see from my initial test, is gone :cool: So that is the equivalent of measuring the original WAV file!
Conclusion
You get here one of the best CD Transport ever made at a very low price, from a highly praised brand. I was expecting nothing special from this Transport, what a biased mistake that was!
Not only the digital output is untouched, the drive resistance to borderline pressed CDs or those that suffered a very busy life, and that many CD Players would have difficulties to read (or fail to), is a HUGE plus.
Only the small clock deviation could be improved. Probably Sony thought about leaving something to please the DIY community?
With a well chosen DAC, you'll be able to benefit from what most of us never had: absolute transparency -- a SOTA CD Player of all times.
And note that all my measurements were performed with the HDMI output feeding a monitor. I tried also without the cable connected, and I saw the same perfection, of course, what more to expect?
Remains the ergonomics, clearly not the best, but if you accept to turn on the TV, it's more than ok. Fact that it plays, OOB and without setup required, a CDA with absolute perfection is something I particularly appreciate.
Never one Sony CD Player failed me, in my reviews. As a CD lover, I can only praise Sony for keeping up with the CD, giving it careful attention. Sony left the market of pure CD Player, but did they, really? I think this Blu-Ray tells us that no. More than 40 years later, their engineers still care about their baby. I love it.
Somewhere deep down at Sony, there is a piece of code, know as the Primary Gene, that rules everything out, its internal code name is CDA :p:cool:
The conclusion of the conclusion is that what I measured, with the Sony and the Topping acting together, made me want to listen more to them. And that is the pleasure I was talking about in the introduction. What if you'd know that after inserting a CD and pressing play, the only thing you'd need to care about is sit, relax, listen, and enjoy? Because what you get is exactly, precisely to the last bit, what the artists wanted you to hear. What a delight...
Enjoy your weekend!
Flo
I've got, and recommended, the Sony BDP-BX-57 Blu-Ray/SACD/CD/DVD player, crappy analog audio outs, regular display for CDs, not so regular with SACDs and Blu-Ray Audio, HDMI, Coax and optical digital outputs, similarly cheap compared to the Sony BDP-s1700-k. Have mine hooked up to my Topping E30/L30 combo, the sound with 7Hz x Crinacle Zero:2 IEMs is uncanny. I'm using the optical out. The sound of streaming from a good source is also good, I can't hear a difference assuming I'm dealing with the same mastering. Maybe the DAC has something to do with it, maybe having everything good has something to do with it, maybe having septuagenarian ears has something to do with it. Whatever, no intention of upgrading. If I need to replace it, I can find a replacement at EBay.
Ah yes.. My thinking didn't make sense in the wider scheme of things.
I know the SACD licencing is strict and prohibits easy transmission of the DSD layer such that it could be ripped directly from a digital output.. but I'd not considered how time has moved on and dacs with HDMI inputs do now exist , not just on A/V receivers (which I wasn't considering as DACs).
But surely universal players that deliver the correct format to a receiver/dac, do exist and are plentiful enough ?
Maybe some recent offerings by Fiio, SMSL or Shanling would fit your needs.
I've been looking at SMSL PL200T and DUNU Concept R since they both look absolutely beautiful.
But quite pricey :)
I had bad luck with a few of the cheap ~$100 top-loading players (such as Moondrop discdream 2), there's a particular IC that some of those use which does not provide unaltered digital out and appears to always apply some sort of de-emphasis filter for all discs.
You’ve misunderstood that: the DSD signal is extracted from the HDMI signal and output via I2S. Many DACs feature an I2S input capable of processing this directly.
This has nothing to do with the handful of DACs that actually possess an HDMI interface.
Some of these interfaces are also capable of outputting S/PDIF.
However, the protection measures regarding SACD ripping have effectively been obsolete for a few years now.
Due to a security vulnerability, it is possible—using specific Sony PlayStation consoles, 13 Sony Blu-ray players, and over 15 other Blu-ray player models—to rip any SACD directly onto a USB stick or over a network.
Thanks for the review, NTTY.
With regard to SACD playback, it's worth noting that the Sony UHP-H1 can output SACD stereo content via the coax digital output at 16/48, so it might well be that the BDP-S1700K can do likewise. Moreover, the UHP-H1 can output multichannel SACD content via digital coax, but as a 16/48 stereo downmix. Even so, whether you're playing stereo or multichannel SACDs, the UHP-H1 will give you a 16/48 version via digital coax. Oh, the same applies to the analogue ouput with regard to downmixing multichannel to stereo: the stereo connection on the back of the unit will give you a stereo downmix of the multichannel content. It would be interesting to know whether the S1700K has the same functionality on these points.
Love this review.
One quibble... What you hear is, what the artist intended. Unfortunately what you hear is what the mastering engineer intended. That may be what the artist intended but it too often is what the record company prescribed which often is compromising of what the artist desired.
That said all we can ask of our equipment is it to be transparently accurate to the recording and that is what you found.
Love this review.
To expand on that many popular music recordings are victims of the 'loudness war'. They're compressed to the point that all the instruments are the same volume. That's great if you want to hear those cymbals normally buried in the mix, but it also it leads to sonic fatigue, i.e. " it's too loud, but when I turn down the volume, it's not loud enough." My sense is that most musicians are not as interested in the recording process vs. live performance and in any case have limited control since the record company is in charge of the recording.
Is it even possible to buy a universal blu-ray player and AVR set up that plays all formats as intended? SACD as DSD, DVD-A and blu-ray both at 24/96. I guess there's no such thing as universal.
I believe that the Sony X800M2 will do this. DSD output is via HDMI only, and it is a setting in the preferences (to output DSD vs PCM.) So far as I can tell, it is outputting DVD-A and blu-ray audio at whatever the source is.
Upon reflection: I'd be tempted to go for maximum irony if I switch to one of these as a transport. I'd invest into a converter (there must be one, right‽) and use something like this as a display.
EDIT: I actually have a GE Portacolor in the basement. It is semi-functional but would need a full going-through to actually reproduce video. ;)
or maybe even go de luxe...
I used a 13" Trinitron for my display when I had an OPPO CD/SACD/DVD-A player to scroll through the DVD-A menus. Also had some performance videos in Dolby surround and the Wacky Beck "Guero" 5.1 DVD-A with visual programs that change on the fly. I think the TV set me back all of $15.
Thanks a lot for a great review! Makes me feel good about buying this player a couple of months ago. The only downside is the lack of a display.
That's a bit big to sit on top the S1700?
I had ugly electronic boxes spread across my mancave/experimental sound laboratory, an OPPO "Universal" player that maxed out with DVD-A but no Blu-Ray audio. Hooked up via HDMI to the Onkyo AVR by the "Paradise Found" record. AMVETs had various Monster A/V interconnects, long runs, good termination, prices from around $5 for short pairs, up to $15 for longer ones. The Maggies and the RBH mini-towers were free, the little Paradigm bookshelf speakers were cheap at some thrift store, $15. The speaker wire comes from the hardware store right down the block, mostly 14-gauge zipcord. The cheap Garrard 'table above the HK 330 was just for 78s, used the 330 as a phono pre, passed the signal from the Garrard through the 330 to the AVR without RIAA, there's a Strathclyde 305-M where you can't see it, fancy Scottish 'table. The OPPO player is under the HK 330, the Onkyo takes the video from the HDMI feed and converts it to coax for the Trinitron. Under the Trinitron is a very early, very cheap Sony semi-universal player. It could play DVDs but not DVD-As, though the work-around was to simply apply Dolby surround when playing a DVD-A on the Sony Player:
Too bad Sony quit making CD players 20 years or more ago, and quit making disc players with analog outputs 5 or so years ago.
I’d like to see the Sony UDP-x1100es tested, which I believe was Sony’s last disc player with analog stereo outputs.
I now see that the S1700K doesn't play SACDs, it only supports DSD playback via USB. I'm not sure how I got my wires mixed up the other day, but there you go. Show me the way to Specsavers lol
