Sonus Faber Piccolo Solo Spinorama measurements (CTA-2034)
What are your thoughts about this speaker?
  • Very good
    Votes: 0 0.0%
  • Above average
    Votes: 3 23.1%
  • It's ok
    Votes: 7 53.8%
  • Below average
    Votes: 2 15.4%
  • Poor
    Votes: 1 7.7%
Ageve
Sweden
Here are some measurements of the Sonus Faber Piccolo Solo center speaker.
The MSRP was $595 back in 2000 ($1,084 in 2024).
Specifications:
System: High speed two-way center channel (whatever that means)
Tweeter: 20 mm silk dome ferrofluid
Mid-woofer: 140 mm multicoating paper cone
Crossover: First order attenuated
Sensitivity: 86 dB/1W/1mt
Impedance: 8 ohms nominal
Power handling: 30W-150W without clipping
Frequency response: 50-20000 Hz +/- 3dB
Cabinet: Black leather
Dimensions: 170x485x235 mm (HxWxD) 6 3/4 x 19 x 9 1/4 " (HxWxD)
Weight: 10 kg (22 lbs) packaged
My measurements are quasi-anechoic, with nearfield woofer response, corrected for baffle edge diffraction, combined with gated measurements. This speaker was measured indoors. Unfortunately it's not possible to measure outside in Sweden this time of year. ;)
The only measurement I could find online was from Sound & Vision:
Here are the results:
Horizontal directivity is poor, as expected (MTM design and no waveguide).
Horizontal directivity:
0-90 deg, for comparison with Stereophile measurements:
0-90 deg:
Vertical directivity:
0-90 deg:
Distortion:
Less than 0.5% distortion > 120 Hz.
The small woofers were moving a lot at 86 dB / 1m, so I didn't measure at higher SPL.
This is a typical MTM center. Horizontal directivity is less than stellar, but the vertical directivity is better than expected, and distortion is quite low as well. No bass below 80 Hz.
It sounds... ok. Quite "boxy" when used as intented (horizontal) and better when used vertical. No soundstage to speak of.
This is how Sound & Vision described the sound:
Dialogue was extremely natural—men sounded like men, and women sounded like . . . you know.
Other than the 1.5 kHz bump and a very small horizontal directivity, it is ok. Could be a lot worst tbh.
For a first order crossover that is shockingly good.
I think with impedance data this review would be ASR homepage worthy. Maybe a picture of the crossover and cabinet interior if you are feeling generous.
Here is an mtm design that was pretty even off axis horizontally.
I seem to recall mtm working better with 3rd order crossovers. I wonder if this Sonus Faber has the tweeter connection in the wrong phase.
I have three points.
1) SF is far from 1st order acoustically, Nearfield measurement looks like LR4 around 3kHz. Hor. directivity hints to that too and is typical for horizontal mtm with high xo.
2) Vertical response is OK, due to small woofers. Typical for horizontal MTMs
3) Hales speaker is a vertical MTM, that's why hor.resp in Stereophile is ok. JA says that in vertical plane at a woofer's height spl has a notch.
Conclusion: SF is suitable for only a single listener/HT wathcher, sitting at the peak of triangle.
Here's a new measurement with reversed tweeter polarity:
Yeah, I don't really believe the specification. The measurements look too good for a 1st order crossover.
I'll take a few pictures when I restore the tweeter polarity.
edit: Here's a teardown:
Woofer and tweeter crossovers on separate PCBs.
It looks like 2nd order.
They sure like black glue. I've seen it in other SF speakers as well.
No sand cast resistors = GR approved? ;)
Just found an official measurement of this speaker:
100 db scale, and (probably) 1/6 smoothing. Bass response looks like they interpolated it from a gated measurement (very inaccurate).
This is how it looks with a 50 dB scale, compared to my on-axis measurement (with 1/6 smoothing applied):
If this was the only measurement available, you would think that my speaker is down a couple of dB > 2kHz, but that's not the case, as it matches the Sound & Vision measurement from back when it was new:
