Hi
This is a very interesting subject. A bit of a background: I came from the other side. It wasn't 10 years ago that I started saving for a speaker that would have cost me, used, close to $20,000.oo. Amir invited to join ASR. I have never derived so much pleasure, learned so much and enjoyed such great end results, from joining an Audio forum. My current system, one that is truly full range and follows the Toole curve, cost me less than $5000.oo.. I had a DAC at one point, yes! A single DAC!! that cost more...
Yet there is a curve, there is a learning curve. One learns to appreciate the little differences and somewhat you no longer can unhear them. Once you are exposed to a certain level of quality audio reproduction, then you .. just ...know. But the differences are not as marked as many would want you to believe, past a certain degree of "faithfullness" . IOW the Sonos 5 is good and it might be good enough for many people, even audiophiles. I daresay that I have found some SONOS systems more enjoyable than audiophile ones.. especially the SET amplifers+ so-called "Full range" driver nonsenses that some audiophiles hail as the Graal... And yeah, also, better than some ridiculously priced 2-way "mini-monitors" too... I will not names but ... eh...
So I can understand that the SONOS 5 might be satisfying, especially if the limits aren't pushed, and/or if the Genelecs aren't
optimized for the environment in which both speakers/brands are playing. I would even think that the SONOS app, TruePlay is easier to work with than GLM...
But I am certain that if both are optimized... all bets are off. The 8361 shall win in a landslide, even for the un-initiated.
Peace.
Peace.
