correct, this was NTSB first lawWhat is the old pilot line? Any airplane landing that you can walk out of is a success?
I agree we are both guessing, but probably you are ahead of meI said most continuous, not heaviest. While the speaker does need to support an OS, the continuous demands from that are relatively modest (no active browsers, no display, no significant UI, etc). The "networking" functions, while continuous, are not computationally demanding. The DSP demands are continuous and computationally heavy in realtime.
Or if you're suggesting the MT8521 is not doing DSP, what might you suggest *is* doing the DSP processing then? The DAC is a PCM1690 which has no DSP resource. I see no other processor on the board.
We're both speculating of course. A power consumption per process/function chart would tell the true story, and while Sonos no doubt has such a document, we'll surely never see it.
I wanted to measure it the way it is usually used.Having said that, wouldn't the best way to measure this speaker be in it's vertical orientation and set up as a "stereo pair" with another unit?
With age comes wisdom. As an ASR Mandalorian would say: this is a way.For a long time I, like many audiophiles, dismissed Sonos gear as middle of the road performance designed for the uninformed convenience market.... I recently convinced myself that 16/44.1 was more than adequate for my needs (I'm 68 in 2 weeks) ...the old Sonos Connect streamer was bit perfect... second hand at ... only US$50 each ... great results.
here you go - Sonos Play 5 vs Genelec 8361A - this was the thread that really made me surprised there weren't better measurements of the Five. Hats off to @amirm!... in a thread where someone was comparing these to Genelec Studio Monitors....
What model of trash do you have? How much do you want for your trash?We have a couple Sonos speakers and I consider them trash. Now that I think about it I think I will replace them.
Hi Amir,The long latency rules out any movie use.
SONOS Five Listening Test
I chose to listen to the Five in near-field at about 2+ meters/5 feet. First impression was most impressive. We are talking almost the same accuracy of a studio monitor! Sound was clean, and tonality was right on the money. Bass notes were deep and so much so that they activated the room modes, sounding a bit tubby at times. I made an attempt to reduce that by lowering the hump at 180 Hz and that helped a bit. Forgot to save it though.
Unfortunately, I bought them for my wife. Sonus 1, I think I paid about $200/each. They'd have to be shipped from Canada but if you are interested make me an offer and I will try to convince her to sell.What model of trash do you have? How much do you want for your trash?
Peace.
I believe those scores are heavily impacted by the difficulties in measuring the Five's performance about 10KHz. As a result (I think) the Five's preference scores are deceptively low.It’s curious that the Apple Homepod bested this in the Olive Score…just bass extension?
?????Say what you want but this is some incredible garbage going on when looking at the distortion chart. It doesn't produce any bass, it produces harmonic distortions below 100Hz.
Typical case of trying to achieve the 'with sufficient thrust, pigs fly just fine'. DSP doesn't fix physics.
