audiofooled
- Joined
- Apr 1, 2021
- Messages
- 756
- Likes
- 805
To me at least, what @Floyd Toole answered to this question concerning mono listening tests here was more than satisfactory:
I'm not happy with how the term "resonance" is used. It isn't a solely physical resonance in its original meaning. But this term is fundamental for the explanation, me thinks. I’ll just leave it like that, so as not to put words in anyone’s mouth.To me at least, what @Floyd Toole answered to this question concerning mono listening tests here was more than satisfactory: ...
Excellent, we're getting somewhere!I'm not happy with how the term "resonance" is used
There is still a fundamental misunderstanding of how and why monophonic listening has been employed in our research. It was never used in subjective evaluations of an "absolute" kind, judging the merit of the sound as reproduced by one loudspeaker in a small listening room, and never sighted. We did our best to avoid using downmixes with problems, but even if they had problems they probably would not affect the results because the test employing the mono listening was a multiple-loudspeaker (3 or 4 at a time), loudness equalized randomized comparison with program in 30 s loops. Whether the signal was music, pink noise or impulses the results were the same - loudspeakers without audible resonances were preferred. The music was merely a test signal to energize resonances so they could be heard, and some music was much better than others. Pink noise was the most revealing, but it was unfamiliar to most listeners. It is all in my papers, books and YouTube lectures. The most preferred loudspeakers were the most technically accurate ones.To add to that .. generalizing all music for the purpose of this thread is not helpful. You have to Choose reference material carefully. Not all stereo recordings are produced equally. Some will downmix to mono very well, others won't. This is why Amir has tracks that he chooses, and Dr. toole posted some examples as well.
You can measure mono compatibility in stereo recordings with a DAW like reaper or audacity, and something like isotope insight or even the built-in tools in Reaper. It can give you some ballparks on mono compatibility of recordings.
Or just use known high quality recordings that work well in mono. And again as it's been proven mathematically and practically, when a single loudspeaker measures well in mono it's going to sound excellent in a stereo pair or multi-channel.
But as Dr Toole put it, music wasn't ever used in an absolute way (in their testing) to determine the quality of a speaker. It was more a way to contextualize resonance in a speaker so that people could understand what they were hearing.I haven't read through the entire thread, so apologies if no one has mentioned it before.
One issue with a mono sum is that in the analog world, summing L+R causes material in the center to increase relative to the other material. This is because power is proportional to the square of the voltage, so taking a voltage sum causes a 3db increase vs. the power sum that occurs when you send the signal to two speakers.
This has been known for the entirety of stereo recordings, and back in the day when AM radio ruled engineers would create and distribute mono versions of songs on special "DJ records" often with the mono version on one side and the stereo version on the other.
Of course, there are far worse things that can happen when summing to mono such as phase anomalies. And since your typical mono listening device is not particularly high-end, a bit of boost to the foreground material is not really a bad thing.
Tounge in cheak one might argue that the "technically better" speaker was used to evaluate and optimize the recording in the studio to begin with. So, later when playing the record and evaluating it--the recording, the "technically better" speaker would be optimal for this purpose. That renders the "technically better" speaker the technically better speaker.But this is what drives home everything: "The most preferred loudspeakers were the most technically accurate ones" ... Think about that.
This circular reasoning makes the standard, which is fair because standards are selfreferential in their logic to begin with. It breakes the "circle of confusion". If studio uses speaker type A, use speaker type A for playback also, that easy. Done. But, I once asked if their's equivalence, say type A is e/q to type B, and by which parameters the e/q is stated. As you might guess, the question wasn't picked up- It's science: open question(s) remain.That's the "audio" resonances which apparently are not real physical resonances. Physical resonances don't resonate with the audio use of that term. I won't dare to educate anyone who carries Maxwell's Equations in their aliasWhat I gather is that many speaker non-linear behaviours (assuming they are not being overdriven) are discerned as resonances. ...
Tounge in cheak one might argue that the "technically better" speaker was used to evaluate and optimize the recording in the studio to begin with. So, later when playing the record and evaluating it--the recording, the "technically better" speaker would be optimal for this purpose. That renders the "technically better" speaker the technically better speaker.This circular reasoning makes the standard, which is fair because standards are selfreferential in their logic to begin with. It breakes the "circle of confusion". If studio uses speaker type A, use speaker type A for playback also, that easy. Done. But, I once asked if their's equivalence, say type A is e/q to type B, and by which parameters the e/q is stated. As you might guess, the question wasn't picked up- It's science: open question(s) remain.
You said, "Tounge in cheak one might argue that the "technically better" speaker was used to evaluate and optimize the recording in the studio to begin with. So, later when playing the record and evaluating it--the recording, the "technically better" speaker would be optimal for this purpose." I only wish this were true. The abundant measured evidence displayed in my books indicates that recording studio monitor loudspeakers have historically been as variable as their consumer versions. This is the origin of the circle of confusion. Slide show 6 in the companion website to the 4th edition of my book shows many examples of where things stand now - we are much better off than not many years ago. Timbrally neutral loudspeakers are appearing everywhere at all prices.Tounge in cheak one might argue that the "technically better" speaker was used to evaluate and optimize the recording in the studio to begin with. So, later when playing the record and evaluating it--the recording, the "technically better" speaker would be optimal for this purpose. That renders the "technically better" speaker the technically better speaker.This circular reasoning makes the standard, which is fair because standards are selfreferential in their logic to begin with. It breakes the "circle of confusion". If studio uses speaker type A, use speaker type A for playback also, that easy. Done. But, I once asked if their's equivalence, say type A is e/q to type B, and by which parameters the e/q is stated. As you might guess, the question wasn't picked up- It's science: open question(s) remain.
That's the "audio" resonances which apparently are not real physical resonances. Physical resonances don't resonate with the audio use of that term. I won't dare to educate anyone who carries Maxwell's Equations in their aliasI could analyse the above statement word by word to show by what degree it is typical audio talk.
But briefly: resonance is not bad. Resonance is necessary to transform energy from electrical to mechanical, especially when talking about speakers. Thing is, how the resonance(s) are designed, or controlled as the engineer might put it. It might take a minute or two to think about it (sic!).
Every acoustic signal is resonant by nature, its description respectively. Remeber: resonance can be aperiodic, or composed of many, at least the physical description goes that far. When using a speaker, you feed resonance into another (necessarily) resonant device as to replicate the original resonance as an acoustic event.
It is not so, that resonance lives for itself, waiting to gain enough energy, statistically, to become objectional. That's simply not how it works.
It is more about perception by a human mind (not: brain), that motivates test listeners to check a box on the evaluation sheet. It's a concious decision making, that depends on other parameters than the mathematical overlay of resonant processes. Good/bad is based on subjective, basically unknown preferences. We better leave it as that - stop blaming resonance. There is simply no layed out path from math/ to pref/.
Add.: think of the previously ventilated idea of not using a single speaker for evaluation (necessarily mono), but a pair in stereo arrangement, but fed with a mono signal. What you then would get is funny intereferences aka comb filter effect. By what is comb filtering different from resonance, or "resonance"? Me rethinking might conclude that single speaker assessment outrules extra comb filtering that is a permanet compagnion in stereo? While the 'extra' is extra to the Head Related Transfer Function.
You see, on topic, mono isn't just mono. Me as a scientist would have investigated further to clarify my foundational assumptions.
So, you say that I'm confused, like the other guys?You are confusing psychoacoustics with speaker design. And you are describing what the subjective reviewers do - they ...
I'm a not a believer. And I'm proud of it a little.But in the case of the work of Audio Luminaries like Dr. Toole and others, ...
I never talked about measuring. I was asking if the cause for less dicriminating powers of listening with comb filter effect present (stereo arrangement, mono signal, phantom center) was the ruffled frequency response, and conversely, that "resonance" is just another audio word for frequency response aberrations. You derailed it... only one speaker for measuring is necessary. You can't use two - because then you're measuring an acoustic array, not a speaker.
I understand that we are, by and large, in complete agreement, even on details left unspoken. Elaboration: With an assumed budget, I would have examined whether the (missing) accuracy in the evaluation of loudspeakers might not, after all, be related to comb-filter effects. This relates to the experiment described, using mono playback over a pair of loudspeakers arranged in a stereo triangle. That was all—provided we can agree that resonances are, in essence, subjectively noticeable primarily through amplitude effects.I would welcome elaboration on your closing comment: "...
It seems like you are conflating terms and misunderstanding some core ideas.So, you say that I'm confused, like the other guys?
There it is. Being proud won't get you anywhereI'm a not a believer. And I'm proud of it a little.
Speaker Resonance is mechanical, physical and measurable and hearable.I never talked about measuring. I was asking if the cause for less dicriminating powers of listening with comb filter effect present (stereo arrangement, mono signal, phantom center) was the ruffled frequency response, and conversely, that "resonance" is just another audio word for frequency response aberrations. You derailed it.
This has been done, as described in AES papers and my books. When the signals delivered to the two loudspeakers are identical, resonances are well detected, when there is added large venue spaciousness, the resonances are more difficult to detect. Multichannel audio delivers even more persuasive recorded spaciousness and detection is even worse. It is not related to acoustic crosstalk comb filter effects. You need to read up on the science.This relates to the experiment described, using mono playback over a pair of loudspeakers arranged in a stereo triangle.
Dr Toole, I've a qualifying degree in nat/ science. This, though, is a hobby. I will never ask you again, sorry for the uncenvenience.You need to read up on the science.
I read this in the book, but IIRC identical signals with two speakers (in stereo triangle) were only tested with technical signals. Then resonances were readily audible.When the signals delivered to the two loudspeakers are identical, resonances are well detected, when there is added large venue spaciousness, the resonances are more difficult to detect.
exactly means.”when there is added large venue spaciousness, the resonances are more difficult to detect."
Yes, and resonances normally correlate with a "bump-up" in the frequency response which is more apparent than any ringing/resonating because even bad speakers rarely resonate THAT badly. Speakers don't ring like a bell or a plucked guitar string, etc.Has this (audibility of resonances) also been tested with music? That is, with identical signals (aka music in mono) through two (or more) speakers?
You raise a number of good points, and the following is an overly long response that came out as a stream of consciousness - I may have gone on a bit . . .I read this in the book, but IIRC identical signals with two speakers (in stereo triangle) were only tested with technical signals. Then resonances were readily audible.
It is not clear to me, what
exactly means.
Does this relate to the case of stereo music (as described in the 4th edition)?
Or does this relate to mono music over two speakers, too?
I know that "large venue spaciousness" is mainly transported via stereo, but a little bit (temporal) will be present even in mono.
