misterdog
- Joined
- Dec 7, 2018
- Messages
- 514
- Likes
- 402
Is that in dispute also???
In this hobby everything is in dispute
There are a few things to be said about SGD1 testing:I noticed that there aren't any measurements for the SGD1 post IMD hump fix, so i sent my unit to Golden One for measurement and here are the results. These seem to correspond with those posted by Purr1n at https://www.superbestaudiofriends.o...ncoz-sgd1-vs-geshelli-jnog.10955/#post-347268 . Seems like the IMD hump fix has resulted in worse SINAD performance.
Conclusion first: the unit under test is most likely not Upgraded(OTA) to the latest firmware (there are a small number of early units in Europe), as I judge from the output amplitude of the test.The unit output amplitude of the test was around 4.4Vrms, while the unit output amplitude of the upgrade to the latest firmware should be around 4.2Vrms.
Everyone is doing the right thing, both media and users, who want SONCOZ to bring good audio products. The SONCOZ team is truly grateful for your trust and support.
I arranged time to randomly check and test our products again. Finally, I found the worst test result in a group of tests:
Test environment and conditions:
1)Test instrument: AP555 A series;
2)Wire: standard accessories, ordinary wire;
3)Power supply: non-isolated power supply;
THD+N:
FFT:
SNR:
IMD:
Updated firmware around early April.When was this firmware update released? Could there be a problem with the firmware update tool?
This appears to be the result of an unsuccessful upgrade. Hold down 6s to reset the entire system, and then use the phone hotspot to upgrade.Has anyone had issues with their SGD1 restarting constantly?
It will work for the latest iOS.So I wonder if the update method still works for the latest iOS?
Resetting works!! ThanksIt will work for the latest iOS.
If can not work, please reset SGD1 and try again.
This is a restart upgrade attempt due to an unsuccessful upgrade.Hold down the knob for more than 6 seconds to reset the entire system, and then the phone's hotspot upgrade is the most convenient.This has been going on for quite some time. Anyone experienced this before? Is there a way for me to do a factory reset for the soncoz and restart the wifi procedure? Or is there just that many firmware updates? Thanks
Was it purchased in 2019? Contact the person who sold you and send it back to replace the hardware.Hey. I have an original version of this DAC without the IMD hump fix. Is it still possible to get the unit replaced? How does the replacement process work?
Yeah that fixed my issue a while back.This is a restart upgrade attempt due to an unsuccessful upgrade.Hold down the knob for more than 6 seconds to reset the entire system, and then the phone's hotspot upgrade is the most convenient.
Hello,Mute for about 10 minutes and go into standby mode. In standby mode, all the lights will go out, and the digital part of the peripheral circuit will go off except for the analog power supply. Anlalog part of the power did not drop, mainly because, when out of standby mode may bring the simulation output of the impact, damage equipment.
SGD1's power consumption mainly comes from the analog part, the digital part of the power loss to reduce the power consumption is not much, about 2W, that is to say, the power will be reduced when the sleep about 2W.
This may not be the ideal result of stand by, but it protects the peripherals and it does look like it's sleeping soundly.
