Here is an article that discusses the issue: https://sound-au.com/biamp-vs-passive.htmAs for "blocking the power amplifier from taking maximum control over voice coil motion", I thought that this was debunked. Some time ago I was doing some reading on back-EMF and how passive XO's prevent the amplifier from "seeing" the driver's back-EMF directly. I asked an amplifier designer if this was true, and he said it isn't. Again, not arguing - trying to learn and see some discussion over these points.
I'm done with passive crossovers.aren't most people going to use dsp once you stick it in a room?...seems like the days of passive crossovers are done, for cost, convenience, and quality...
You could try educating him, but that may not be successful, depending on how much he already is brainwashed.The question is how to convince such a guy that his id is stupid.
So it's too hard and too expensive to have better and more stable sound quality even in music transients?I know all the disadvantages of passive crossovers, but reality is, most speakers still have them because (good) dsp is still to expensive for the average customer. And the hassle to have several amp, a lot of cables and so is too much for them.
That i could explain to him (thanks also for the cap test of Amir to steer him away from expensive snake oil caps). He will get Dayton PMPC film caps and Dayton DPR10 non inductive resistors (those are 1% tollerance) and big custom made (precision) aircoils of 15AWG OFC. But even then, those aircoils costs about 400€ a side, and other parts still add about 100€, that is a +1K crossover... You can buy a lot of dsp for that.You could try educating him, but that may not be successful, depending on how much he already is brainwashed.
Since the system is going to be in a garden, it seems unlikely that it will be used for critical listening. If he insists on staying analog, passive filters probably will be sufficient if you use heavy gauge air core inductors in the crossovers. Also, metalized film capacitors tend to last longer than electrolytics, so I probably would stick with those as well.
I fully agree.But even then, those aircoils costs about 400€ a side, and other parts still add about 100€, that is a +1K crossover... You can buy a lot of dsp for that.
FYI, the use of non-inductive vs sand-cast resistors in the woofer filter definitely will not be audible - you already have moderately high series inductance in the circuit, and the amount of inductance added by the resistors will be negligible. You can model this in your circuit if you know the inductance of the resistors.Dayton DPR10 non inductive resistors (those are 1% tollerance)
I might try saying that since the complexity and cost of the passive is high, I'd like to try to be as sure as possible the passive sims xover points, etc, are going to measure well.The question is how to convince such a guy
The question is not if dsp is better or not for this purpose. Off course it's better. The question is how to convince such a guy that his id is stupid.
Waxx, you can also sell him the end all amp. Usually called a "big assed amp". He needs that to go with his analog filters. I'm thinking 500 to 800 watts per channel? Plus you can take the name off the amp and say you custom built the amp just for him! I see money to be made.........That i could explain to him (thanks also for the cap test of Amir to steer him away from expensive snake oil caps). He will get Dayton PMPC film caps and Dayton DPR10 non inductive resistors (those are 1% tollerance) and big custom made (precision) aircoils of 15AWG OFC. But even then, those aircoils costs about 400€ a side, and other parts still add about 100€, that is a +1K crossover... You can buy a lot of dsp for that.
I wonder how many active speakers are "pure" DSP though? Say the DSP can only handle 4 IIR filters, then they might decide to use a passive crossover to get it in the ballpark, then 1 to improve the crossover, and then 3 to improve the response. In that scenario you don't get the benefit of "maximum control", but how does the consumer know?from Siegfried Linkwitz: "They block the power amplifier from taking maximum control over the voice coil motion."
I don't use passive crossovers in my 5.1 setup or on other temporary setups that I've used.I wonder how many active speakers are "pure" DSP though? Say the DSP can only handle 4 IIR filters, then they might decide to use a passive crossover to get it in the ballpark, then 1 to improve the crossover, and then 3 to improve the response. In that scenario you don't get the benefit of "maximum control", but how does the consumer know?
My current (DIY) setup is. However, I'm actually planning to try adding some passive parts soon for two reasons: 1) to make the setup less demanding regarding DAC/amp noise (the sensitivity of the compression driver + waveguide is ~110dB/2.83V@1m), and 2) to see if I can reduce further reduce distortion in the midrange.I wonder how many active speakers are "pure" DSP though?
That would be awfully convenient and practical indeed, even without battery (what's that good for, except portability?).I envision a day when each loudspeaker has only one cable attached to it -- a power cable to charge the batteries.
An all-digital signal is sent wirelessly to each loudspeaker, which is processed by an onboard DSP and sent to individual battery-powered Class-D amplifiers, one per driver.
