- Joined
- Nov 25, 2021
- Messages
- 40
- Likes
- 31
1. Bass extension: low shelf 70Hz Q 0.7071
2. Bass texture: peaking 100Hz Q 0.85
3. Note thickness: peaking 200Hz Q 0.6667
4. Voice: peaking peaking 650Hz Q 0.4
5. Female overtones: peaking3000Hz Q 1.414
6. Sibilance LF: peaking 5800Hz Q 1
7. Sibilance HF: peaking 9200Hz Q 1 (these were two guesses at where sibilance might happen in a recording, in actual fact it can occur pretty much anywhere ~3-12k. One could even imagine opening up the frequency for adjustment and just fix the Q for the most simplicity that actually makes sense)
8. "Impulse response": peaking 7500Hz Q 0.4
9. Air: high shelf 10kHz Q 0.7071
We're just missing the number of dB each step out of 100 stood for, and I don't have record of this at hand anymore, but we can reverse engineer by measuring each slider at full tilt, or I can ask for it back.
The temperature slider would have been implemented by a series of low Q shelf filters.
However, on at least the R Androids, the specified filters "dry run" on a K-delta impulse, and the result is measured by FFT. The overall volume of the impulse is measured via a weighted average of bins, and the final filter is a volume adjusted version, which reduces the volume when there are big bass boosts (but not with a strict below-zero rule).
