Some notes on Fiio KA17
It is a misunderstanding that pre-amp gain reduction equals the highest point on the EQ curve. For IIR EQ, phase rotation can cause larger peaks. Even enabling a 1000Hz -6dB EQ can cause the peak to increase (originally 0dBFS)View attachment 491810
That is why having some (a few dBs) headroom in DSP is wise because it has multiple benefits. Not many devices pay careful attention to this matter...
Thank you for your clarification. What software do you use in this example for calculations?
Damn, was eyeing-up the QX13 for it's desktop-mode, 4.4mm + 3.5mm connections + switchable EQ on the device itself.
Is there anything similar with the same features more or less?
I'm using 7Hz x Crinacle Zero 2 IEMs and Moondrop Para 2 headphones for context.
I already have a DX5II (just for its headphone capabilities) but it seems overkill given the size, etc -- looking to downsize and get some cash back.
There are some conflicting info on Fiio KA17, so I'm providing these for those who may get confused about Fiio's KA17 features and limits:
1. It now has a web interface you can control on your computer, Mac or PC, which lets you customize the PEQ. There is still the Android app too.
2. You can only update its firmware using Windows, so far its web control panel doesn't offer this feature.
3. After one of the firmware updates, you can use both UAC V1 and PEQ.
4. You can use PEQ on the SPDIF Coaxial output too.
5. You can't use UAC V1 with SPDIF out, that's very frustrating, I needed to use it as digital out for my PS5, and now I see it doesn't work.
When you turn on the SPDIF, it switches back to UAC V2.
6. For SPDIF out they provide a schematic here:
And the ready made cables for that 3.5mm to RCA Coaxial cables are hard to find.
What I have found is you can use a simple 3.5mm to RCA adapter, just don't insert it all the way in, use it like this:
7. This one is not specific to this DAC, but a limit of macOS, on macOS can only use DSD using DoP, and it can only handle up to DSD 256 via DoP.
Not that I care about DSD, it was just an experiment.
Does spdif out go through PEQ?
Thats a good news actually very very good news. Thanks
You're welcome!
Now if only they made this SPDIF out working with UAC 1.0 mode for game consoles too it would be great.
You're welcome!
I am just curious. Unlike the SPDIF out, an SPDIF input is nonexistent (not that I am aware of) on portable DAC/HP amp devices---sure, there's a reason of implementation difficulty. But if either is available, which would you choose? My choice is an input. I believe it has greater utility in general. No?
I think Mojo 2 is a rare exception of having SPDIF inputs, although it is not as portable.
I already have two devices with optical input and since they act as my speaker and headphone outputs, I would have preferred this other device which has UAC 1.0 compatibility with consoles to have the SPDIF out to connect it to the one of them. Otherwise I understand the digital input has more utility in general.
The SPDIF output on the KA17 is coaxial, isn't it? Or optical?
It is coaxial, I use this little box to convert it to optical:
