CuriousAli
- Joined
- Nov 28, 2024
- Messages
- 102
- Likes
- 67
There are some conflicting info on Fiio KA17, so I'm providing these for those who may get confused about Fiio's KA17 features and limits:
1. It now has a web interface you can control on your computer, Mac or PC, which lets you customize the PEQ. There is still the Android app too.
2. You can only update its firmware using Windows, so far its web control panel doesn't offer this feature.
3. After one of the firmware updates, you can use both UAC V1 and PEQ.
4. You can use PEQ on the SPDIF Coaxial output too.
5. You can't use UAC V1 with SPDIF out, that's very frustrating, I needed to use it as digital out for my PS5, and now I see it doesn't work.
When you turn on the SPDIF, it switches back to UAC V2.
6. For SPDIF out they provide a schematic here:
And the ready made cables for that 3.5mm to RCA Coaxial cables are hard to find.
What I have found is you can use a simple 3.5mm to RCA adapter, just don't insert it all the way in, use it like this:
7. This one is not specific to this DAC, but a limit of macOS, on macOS can only use DSD using DoP, and it can only handle up to DSD 256 via DoP.
Not that I care about DSD, it was just an experiment.
