The L/R cables after the split isn't long enough to reach a pair of active speakers though.
See it as an adapter, just use longer XLR cablesThe L/R cables after the split isn't long enough to reach a pair of active speakers though.
This particular listing goes from 0.5m up to 3m.The L/R cables after the split isn't long enough to reach a pair of active speakers though.
Unless I'm not seeing the right listing, all DX1 II currently on any EU amazon are sold & shipped by LEAUDIO or HIFI COLLEGE store in China so you might as well order it cheaper from authorized dealer storefronts like Shenzhen Audio or wait for actual EU based dealers to receive stock. Those CN based stores will eventually get stock in Amazon warehouses and sell as fulfilled by Amazon, but warranty service (through EU 2 year guarantee rather than manufacturer warranty) still isn't handled by Amazon.they showed up on amazon(dot)it yesterday![]()
To answer my own questions, the USB interface explicitly supports hot-plug so it shouldn't be a problem. The other DAC that apparently disallows channel balance adjustment is the Fiio K11 R2R due to the internal hardware, judging by an official Fiio forum post. Whereas I would expect the DX1 II not to have that issue given the PEQ feature supports independent channel profiles.Noob here. Are there any concerns about hot-plugging the USB power? There doesn't seem to be a power off function on the device, only a standby mode. I currently have an AudioEngine D1 DAC and I hot-plug it all the time.
Further questions. I have the Linux/Windows channel balance adjusted. With the DX1 II, is the channel balance still adjustable? I could be wrong but I recall a report of another DAC where the channel balance can't be adjusted in Windows. Even better, am I right in assuming the PEQ preamp gain can be used to adjust channel balance? Is conversion of the Linux/Windows balance percentage to Topping Tune as simple as turning the volume down to figure out the minimum, then calculating an equivalent dB percentage of the volume range?
headphones + powered sub1. Yes. There's pure line out, pure HP out, and simultaneous line out + HP out mode (BTW why is this mode even here? Entirely pointless), each with their own digital volume memory.
2. Prolly 1 meter. But I'm super OCD in keeping unused stuff in stock condition so I never bothered to actually unpack it though.
Thanks for the link. Need to keep looking. My speakers have balanced TRS input so I need to find an adapter for it.
headphones + powered sub![]()
Regarding the Web software, Can you control the microphone gain? Maybe there is no option for the microphone.Topping DX1 II + Pioneer VM-50
4.4BAL to 6.35(L/R): https://item.taobao.com/item.htm?id=868089972370
Updated to latest FW. Issues with 384kHz, but 192kHz works fine. Could be due to my 2m USB cable.
View attachment 535679View attachment 535680
I couldn't find the Mic Gain adjustment menu on the web app, but it can be adjusted via Topping USB Audio Device Control Panel.Regarding the Web software, Can you control the microphone gain? Maybe there is no option for the microphone.
An opened Topping DX1 II box.What's the Topping inside the sealed box?
It's hard to call it disappointing, regardless of the price of the device.I couldn't resist and ordered it. It's a bit disappointing that the PEQ is limited to 192 kHz. But for the price...
Well, I wrote, what It's a bitIt's hard to call it disappointing, regardless of the price of the device.
Thanks to some secret heretical knowledge, I am quite happy listening to music at 48 kHz sampling rate.Well, I wrote, what It's a bit. The DAC itself is already somewhat limited in its price category and has a maximum sampling frequency of 384 kHz. It would have been ideal if the PEQ had worked at all DAC frequencies.
