Rosenbloom
Years ago I purchased this Belkin SoundForm Connect at Argos UK for GBP25. Today I took it out again and connected it to the DX1 II with an optical cable. It's my cheap solution for an Airplay music streamer.
I quite like that stand/box - did you making it yourself or buy it? I've been thinking of making something similar to house my desktop system (wiim amp ultra + topping dx5ii).Years ago I purchased this Belkin SoundForm Connect at Argos UK for GBP25. Today I took it out again and connected it to the DX1 II with an optical cable. It's my cheap solution for an Airplay music streamer.
How do the sound and comfort feel? There have been concerns about the risk of hot-plugging with the 4.4mm jack on the DX5II—has that issue been resolved?
Doesn't power up directly on USB from my phones, either on UAC 1 or 2 mode.
My S23U would show "high-powered USB device" connected.
Quite disappointed to say the least.
Depends, most phones do not have the enough power output for that.
But you may try some spliter cables, or usb isolator like HS02 that can separate power from digital signal, and just use an extra powerbank for the power.
Weird how the larger D50 III actually works for phones in the same use case.
Topping’s official stance is still that you shouldn’t hot‑plug, but if you mute the system or pause the music before unplugging — so there’s no signal going through the jack when you pull the plug — it’s a lot safer.
I don’t know a ton about circuit design, but imo: if you’re unlucky enough, almost any device can have that kind of short risk. You might accidentally bridge the positive and negative terminals inside the jack with a 4.4mm plug — unless the manufacturer specifically built in anti‑short protection for that scenario.
When switching between line out and headphone out, is the previous volume remembered separately for each? I'm assuming probably not since it supports an option to output simultaneously to both.
How long is the USB A to C cable?
First firmware
DX1 II version V2.46 firmware update - Topping audio
TOPPING, born in 2008, has evolved into a beloved global HIFI brand favored by users worldwide. We firmly believe that higher-quality music playback devices are essential for truly showcasing the allure of music. By investing extensively in professional technology and exceptional industrial...www.toppingaudio.com
V15.46.22.46 (May 25, 2026)
* Fixed: After automatic screen-off, sample rate changes were not synchronized on the web interface.
* Fixed: After automatic screen-off, noise could occasionally be output.
* Fixed: Under USB input, the clock did not switch when the sample rate changed.
* Fixed: Several other known issues.
V15.43.22.43 (May 20, 2026)
* Added: Support for Web Home browser-based control
V2.26 (February 25, 2026)
* Initial version.
___
Back to using exe files for updating firmware, no drag and drop
UAC 2.0 mode must be enabled
Found this on AliExpress, fwiw, never used it though. Good luck.the 4.4mm balanced stereo output but I’m have not been able to find an adapter for it.
