Yes, I save a preset on device by long-pressing the button (or via the web interface), but when I turn on this preset, the corresponding equalization profile is not actually applied (although it is displayed on the screen)PEQ presets are stored in the remote control by long pressing the C1, C2 and C3 buttons. Then the switching works correctly.
TL;DR: When switching presets C1-3, the corresponding EQ profiles are applied incorrectly. To activate the correct profile, you need to activate presets C1-3 twice.
I saved profile C1 with preset EQ1, and profile C2 with preset EQ2 (whether holding the button on the remote or via the web interface makes no difference).
I intentionally created presets EQ1 and EQ2 this way, so it would be obvious which profile was applied.
When I apply profile C1 (using the remote or via the web interface, but the problem doesn't always reproduce via the web interface), the device's screen displays EQ1, but I can clearly hear that preset EQ2 has been applied.
If I open the web interface (or refresh the page if the web interface is already open), I see that preset EQ2 is actually selected.
However, if I apply profile C1 again, EQ1 is applied correctly.
The situation is similar with the C2 preset, but the EQ1 equalizer is turned on there by mistake.
UPD: To clearly demonstrate this issue, I made this short video.
